Place Racing Motor Mounts
does anyone know if the 95-99 motor mounts are the same as the 00-03? i need to get new motor mounts but Place Racing does not advertise the motor mounts for the 00-03...anyone know or tried before?
Re: Place Racing Motor Mounts
i'm assuming 95-01 are all the same. Same motor, same chassis. A32, A33, say what you will, but the only difference are the body panels and the rear suspension.
02-03 would of course be different with the different engine. If it doesn't work, you could probably use at least 2/3 and then fill the remaining one with polyurethane.
Re: Re: Place Racing Motor Mounts
Originally posted by joaquink
Make your own if you can afford to have the car down for a day or two.
Re: Re: Re: Place Racing Motor Mounts
you mean...is there someone who makes the poly inserts?
Re: Re: Re: Re: Place Racing Motor Mounts
Not pre se, but you can drop the mounts, fill them with some poly yourself, let them cure, and reinstall them. I used the info he linked to and his information to do my own and they rock! Here's ericdwong's write-up.
i didn't realize the PR motor mounts can cause such vibrations(not that my car is really vibration free)...
QueensMAX
09-15-2015 04:14 AM
