Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 03-07-2003, 06:48 AM   #1
Mod her. Ate her.
phenryiv1's Avatar
Points: 74,007, Level: 100
Points: 74,007, Level: 100 Points: 74,007, Level: 100 Points: 74,007, Level: 100
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
How long can I drive with warped rotors? What other damage can I incur?
I THINK that i have one or 2 warped rotors. MOney is tight, but I want to get them fixed. How long can I drive with them warped? One week? Two weeks? I don't want to drive on them like this for months, but I am strapped for cash until close to the first of the month. Can I go that long?
Also, please check these threads:
Brake noise from high speed...Help!
Ceramic or Metal Master Pads w/ Brembo CD rotors?
Thanks for the help, guys!
__________________
Patrick Henry
2011 Subaru WRX 5DR (DD), 1988 Jeep Comanche 4x4 (Project)
Past: 2000 Maxima SE 5MT, 1997 Infiniti I30t 5MT VLSD
phenryiv1 is offline   Reply With Quote
Old 03-07-2003, 06:52 AM   #2
STFU n00b!
Points: 40,020, Level: 100
Points: 40,020, Level: 100 Points: 40,020, Level: 100 Points: 40,020, Level: 100
Activity: 3.6%
Activity: 3.6% Activity: 3.6% Activity: 3.6%
you'll be fine. just don't drive like a maniac and you won't do any damage. many people drive for years on warped rotors because they're ignorant of the vibrations (or the cause of it anyway) and don't have the car looked at until the car won't start anymore.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 03-07-2003, 06:59 AM   #3
Mod her. Ate her.
phenryiv1's Avatar
Activity: 0%
Quote:
Why would it not start?
__________________
Patrick Henry
Old 03-07-2003, 07:13 AM   #4
STFU n00b!
Activity: 3.6%
my point was that many people NEVER maintain their cars... all they do is put gas in it and drive. They drive them until they won't go anymore..
then they have it towed to a shop and spend $3000 in maintenance, then complain about how unreliable the car is because they didn't change the oil, coolant, brakes, tires, belts, etc etc etc..
__________________
Old 03-07-2003, 07:21 AM   #5
Mod her. Ate her.
phenryiv1's Avatar
Activity: 0%
I see. I should have picked up on your humor the first time!
So can I make it a month or so without doing damage to any OTHER components?
__________________
Patrick Henry
Old 03-07-2003, 07:23 AM   #6
Actually, warped rotors have been linked to worn out calipers and bolts. Normally bolts wouldn't be an issue but in this case, if the bolts/calipers are badly worn, it could cause uneven movement and binding during brake application. Is this something that you need to be concerned about right now? No, but I wouldn't completely ignore it either. Rotors are cheap compared to having to replace rotors, calipers, and bolts.
__________________
1999 SE-Limited
Crimson Blaze
Greddy catback, K&N popcharger, Stillen FTSB, Clear lenses, red/clear tails, Stillen RSB.
Freedog is offline   Reply With Quote
Old 03-07-2003, 07:24 AM   #7
Points: 13,144, Level: 74
Points: 13,144, Level: 74 Points: 13,144, Level: 74 Points: 13,144, Level: 74
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Send a message via AIM to araffio
I drove on warped front rotors for several thousand miles before I got cross drilled/slotted Brembos.
Just make sure you put new pads on with the new or re-cut rotors. You should have no damage or problems.
__________________
- 2012 Maxima SV Sport -
Eibach Springs / Ichiba 20mm Front/25mm Rear Spacers /
Vinyl Smoked Rear & Side Turn Signals / LED Interior / 20% Tint
araffio is offline   Reply With Quote
Old 03-07-2003, 09:00 AM   #8
Mod her. Ate her.
phenryiv1's Avatar
Activity: 0%
Thanks for the input, guys. I may just get a set of used OEM rotors for now, then upgrade this summer when I can replace the pads and rotors w/ good pads and brembos.
__________________
Patrick Henry
Old 03-07-2003, 09:31 AM   #9
WTF is Juice?????
deezo's Avatar
Points: 31,632, Level: 100
Points: 31,632, Level: 100 Points: 31,632, Level: 100 Points: 31,632, Level: 100
Activity: 0.6%
Send a message via AIM to deezo
Quote:
If the vibration is really bad, it would add extra stress to your ball joints/tie rod ends but this would only happen over a long period of time.
__________________
2008 White Hot G8 GT 6.0 L76 V8 - 450 miles to the tank at 75MPH w/ AC on
Superchips 87 Oct / Rotofab Tune
0-60 - 4.7 sec : 1/4 Mile 13.3 @ 104 MPH
Modded 97 GXE Auto 346,000 miles -Original Block + Internals
Tranny Rebuilt - 10/27/10 @ 305,000 miles
15.6 Stock 1/4 Mile
09/11/01
10/10/06 RIP Auntie
deezo is offline   Reply With Quote
Old 03-07-2003, 10:05 AM   #10
STFU n00b!
Activity: 3.6%
As everyone else said.. short term (couple weeks, a month or two) is no problem. after that, you will start having wear issues..
the slider pins on the caliper are the parts that will have the most problem. those guys should be checked when working on the brakes anyway.. as the rotor turns inside the caliper, the caliper floats on those pins.. if the rotor is warped, the caliper will "wobble" on those pins with the rotor. when you're driving 60, think of how fast those parts are moving around down there. It's reasonable to say they WILL wear out or cause problems with time, but for short term, it's nothing to worry about.
Your other option is to yank the rotors off on a saturday (or any other day for that matter) and take them to a parts store and have them turned. it'll cost about $20 and you'll be fine.. if the rotors are ready for replacement, tell them to turn them anyway so you can drive until you can get paid again and buy new rotors. they'll usually do it, but will whine and moan to you about safety.
__________________
Old 03-07-2003, 10:12 AM   #11
SLOW
Nealoc187's Avatar
Points: 32,579, Level: 100
Points: 32,579, Level: 100 Points: 32,579, Level: 100 Points: 32,579, Level: 100
Activity: 18.8%
Activity: 18.8% Activity: 18.8% Activity: 18.8%
Send a message via AIM to Nealoc187
You can get replacement rotors for $25-30 a piece from Autozone, Pepboys, etc. I've done this a few times while waiting for slotted rotors to come in if I had a race event prior to the arrival of my slotted rotors. At $25 a piece they are basically throw away equipment anyhow.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 03-07-2003, 11:52 AM   #12
Points: 21,893, Level: 92
Points: 21,893, Level: 92 Points: 21,893, Level: 92 Points: 21,893, Level: 92
Activity: 0%
Send a message via AIM to 1MAX2NV
You can pick up new ones for fairly cheap at autozone like someone already mentioned. You could take them off and get them machined for about $10 each.
__________________
1MAX2NV is offline   Reply With Quote
Old 03-07-2003, 12:04 PM   #13
Mod her. Ate her.
phenryiv1's Avatar
Activity: 0%
njmaxseltd offered me all 4 of his OEM rotors for a cheap price. They have less than 1/2 of the mileage that mine have, so I think I will go that route for now. When I get more money this summer I will do brembos. My wife offered to let me get the brembos now (no laughing!!!), but I am already in the hole because my struts are gone too, so I need to replace those. I can get by until summer on newer OEM rotors, so I think that that is the plan.
When i go to do the replacement, what do I need to go buy? A brake bleed kit, some emory cloth, new shims...what else?
Also, I have never worked on brakes before, but my father has replaced the brakes on his (original-owner) 1975 280Z, so I think that between the 2 we can figure it out.
Any tips?
__________________
Patrick Henry
Old 03-07-2003, 12:06 PM   #14
Activity: 0%
You need some high temp grease and anti squeal goob. You can manual bleed if you have two people.
__________________
Old 03-07-2003, 12:34 PM   #15
How would one know if the rotors are warped or not?
Quote:
PsyKotiC RydeR is offline   Reply With Quote
Old 03-07-2003, 05:17 PM   #16
You'll feel the vibration through the steering wheel when you brake, and pretty much your whole car will shake if its bad. Usually it'll make a decent amount of noise also, like a pulsating humm.
__________________
ch13f is offline   Reply With Quote
Old 09-12-2011, 07:09 PM   #17
Points: 151, Level: 3
Points: 151, Level: 3 Points: 151, Level: 3 Points: 151, Level: 3
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
Never thought about the rotors causing extra stress on the calipers. Good point.
landover50 is offline   Reply With Quote
Old 09-12-2011, 07:13 PM   #18
Mod her. Ate her.
phenryiv1's Avatar
Activity: 0%
Wow, holy thread ressurection...
__________________
Patrick Henry
Old 09-12-2011, 08:30 PM   #19
Points: 8,092, Level: 60
Points: 8,092, Level: 60 Points: 8,092, Level: 60 Points: 8,092, Level: 60
Activity: 21.2%
Activity: 21.2% Activity: 21.2% Activity: 21.2%
wow 8 years?
Click the image to open in full size.
__________________
asand1 is offline   Reply With Quote
Old 09-12-2011, 08:38 PM   #20
Points: 3,158, Level: 34
Points: 3,158, Level: 34 Points: 3,158, Level: 34 Points: 3,158, Level: 34
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
I seem to disagree. Do not turn your rotors. this makes them even thinnner, and if the turn is a little out the rotors will continue to wobble, causing a vibration. You should go buy aftermarket rotors. Of high grade steel and never worry about them again.
__________________
On my 4th Max. Gotta love the Nissan....Now if only i had enough for a GTR......
dee.signs is offline   Reply With Quote
Old 09-12-2011, 08:39 PM   #21
Points: 3,410, Level: 36
Points: 3,410, Level: 36 Points: 3,410, Level: 36 Points: 3,410, Level: 36
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
We've had worse...
Quote:
Originally Posted by asand1 View Post
wow 8 years?
__________________
Tyutyunnik is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
