Clutch Question
Old 01-22-2003, 08:10 AM
96BLUMAX's Avatar
Clutch Question
What would cause a clutch to operate fine when the car is cold but then once it heats up the clutch sticks and stays engaged which causes the car to slip? Any ideas, or is it just a bad clutch?
Thanks,
Justin
96BLUMAX is offline
Old 01-22-2003, 08:59 AM
ejj
ejj's Avatar
Re: Clutch Question
Thanks,
Justin
Rear main seal leak? As oil starts flowing better it can get onto the clutch surface. Maybe?
ejj is offline
Old 01-22-2003, 09:11 AM
kramerica72's Avatar
Re: Clutch Question
Thanks,
Justin
I'd just as soon say your clutch is worn out. If there is nothing wrong with the clutch master or slave, then you are going to have to pull it apart anyway, which means replacement.
kramerica72 is offline
Old 01-23-2003, 08:44 PM
96BLUMAX's Avatar
Its a brand new clutch. Now what?
96BLUMAX is offline
Old 01-24-2003, 07:21 AM
96BLUMAX's Avatar
The funny thing about what my car is doing is that it works very well when cold but starts slipping when warm. Eventually as the car heats up, the clutch wont disengage. Could this be a fluid problem? We are going to try DOT 5 instead of DOT 4. Should this help?
96BLUMAX is offline
Old 01-24-2003, 09:10 AM
96BLUMAX's Avatar
bump.
96BLUMAX is offline
03-12-2020 12:06 AM
BkGreen97
04-02-2016 05:47 AM
Socalstillen
09-20-2015 11:46 PM
pears
09-18-2015 05:25 AM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: Clutch Question
