How to rotate unidirectional tires?
Old 11-11-2002, 11:12 AM
maximawanabee's Avatar
I have Pilot Sport A/S' and on the sidewall it has the word ROTATION with a pointed arrow. Do you rotate these to the direction of the arrow? Does anyone picture what I'm talking 'bout?
maximawanabee is offline
Vyrus's Avatar
Re: How to rotate unidirectional tires?
Front to back.
-Cyrus
Vyrus is offline
Old 11-11-2002, 11:35 AM
OG Maxima.org Member
nubiannupe's Avatar
That word "rotation" refers to what direction the tire SHOULD be going when you're moving forward. Or to put it simpler, if you're sitting still, and that arrow isn't facing the front of the car, then you've got problems, bro!!
nubiannupe is offline
Old 11-11-2002, 11:44 AM
gotcha!
Front to back.
-Cyrus
I knew that much
Old 11-11-2002, 11:45 AM
sinewave's Avatar
If the arrow is on the top of the tire, it should be pointing forward, if it's on the bottom, it should be pointing rearward.
sinewave is offline
Old 11-11-2002, 11:48 AM
I am Roid Rage
Bluebird's Avatar
Confusion
You could cause this guy some confusion. If the arrow is at the top it would be facing backwards while if it is at the bottom it would be facing backwards and vice versa. I know what you mean though.
Bluebird is offline
Old 11-11-2002, 01:23 PM
Myrv's Avatar
Re: Confusion
Um, errr... thanks for clearing that up.....?
Myrv is offline
Old 11-11-2002, 01:31 PM
I am Roid Rage
Bluebird's Avatar
Re: Re: Confusion
Sure, anytime.
Bluebird is offline
Old 11-11-2002, 03:38 PM
What's next!?..
JPMax's Avatar
Unidirectional tires should only be rotated front to back and back to front on the same side.
No swapping sides of the car.
JPMax is offline
Old 11-11-2002, 04:35 PM
sinewave's Avatar
I know some people who have the tires taken off of the rims so that they can flip the tire over, allowing a side to side rotation. Personally, I don't think it increases the life of the tires enough to offset the extra expense.
sinewave is offline
Old 11-11-2002, 07:30 PM
dwapenyi's Avatar
When you rotate your tire, you guys notice how the fronts wear ALOT, and the rears wear so little, as if they're on vacation or something? I know that's what's supposed to happen, but I would think that the rears would wear a little. Usually I rotate my tires every other oil change.
DW
dwapenyi is offline
Old 11-11-2002, 07:37 PM
Jamsan's Avatar
we do have fwd cars
Jamsan is offline
Old 11-11-2002, 09:41 PM
vicodin ... gift of life
nadir_s's Avatar
holy ****!!!!!!!! my arrows are pointing the other way!!!!!
nadir_s is offline
coolsun
Wheels/Tires
11-13-2016 05:01 PM
Garrettz459
09-28-2015 02:50 PM
Quick Reply: How to rotate unidirectional tires?
