Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 10-12-2002, 03:23 PM   #1
Points: 9,391, Level: 65
Points: 9,391, Level: 65 Points: 9,391, Level: 65 Points: 9,391, Level: 65
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
HELP! Fuel door will not open?
When I was at the gas station today, I tried to open my fuel door with the fuel release trigger and I heard the CLICK, but when I looked at the fuel door, it didn't pop open! So then I got my brother to keep pulling the release trigger and I was trying to push and pull on the gas door, but it wouldn't budge!
So I went home, took a flat head screwdriver and just tried to pry it out and it popped right open! I took some WD40 and sprayed the hinges of the door and the little white tab that retracts when you hit the fuel release trigger, left it alone for a bit and shut the lid. I tried to opening the fuel door again, but it was still stuck! The little white tab doesn't retract when you raise the trigger, but I can still hear the CLICK.
I did a search but didnt get anymore more than to just lube the hinges. After many scratches and a bruised finger, I'm stumped on what to do next
__________________
98 Pebble Beige GLE
Iqb316 is offline   Reply With Quote
Old 10-12-2002, 04:02 PM   #2
Points: 34,988, Level: 100
Points: 34,988, Level: 100 Points: 34,988, Level: 100 Points: 34,988, Level: 100
Activity: 25.7%
Activity: 25.7% Activity: 25.7% Activity: 25.7%
Send a message via AIM to njmaxseltd
Is there an adjustment to the cable? Check down by the lever and see if you can make the cable tighter. Also check the latch on the car when the door is open to see if the cable actually triggers it.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 10-13-2002, 08:46 AM   #3
Activity: 0%
Quote:
Tried this, doesn't seem to work. I guess this seems to be a very unusual problem. When I get my oil changed this week, I'll get the dealer to look at this, maybe it's an electrical problem (Electric fuel door release?).
Anyways thanks for your input
__________________
98 Pebble Beige GLE
Old 10-13-2002, 11:34 AM   #4
I need a truck
Conrad283's Avatar
Points: 65,696, Level: 100
Points: 65,696, Level: 100 Points: 65,696, Level: 100 Points: 65,696, Level: 100
Activity: 99.9%
Activity: 99.9% Activity: 99.9% Activity: 99.9%
Send a message via AIM to Conrad283
crowbar ... but be gentle
__________________
Quote:
Originally Posted by NCSU_MAX View Post
8.) Theres a show in the desert called "Race Wars". We'll see how you do. Then we'll talk.
Quote:
Originally Posted by MrGone View Post
has to still be engaged, was pondering selling the prix
Conrad283 is offline   Reply With Quote
Old 10-13-2002, 12:20 PM   #5
Points: 9,447, Level: 65
Points: 9,447, Level: 65 Points: 9,447, Level: 65 Points: 9,447, Level: 65
Activity: 0%
Re: HELP! Fuel door will not open?
It sounds like your release lever cable may be broken. It happens. Had an 87 Stanza GXE and it snapped. I had to replace the cable. It is also the same cable that pops the trunk (unless you have an electric one). Check and see if the trunk pops. If you have the alarm/door lock/trunk release remote the trunk thing won't help. We had to pull the trunk interior away from the left rear fender and pull the latch with our fingers to fill up before we bought the part and fixed it. If you have a Chiltons or FSM look it up and see if it is a cable. If it is I bet that's the problem.
__________________
John
91 Maxima SE 5-spd 4DSC pkg (ABS stiffer suspenders)
PR CAI, Cattman SS Y, RT Hi-Flow Cat, SS 2.5" Cat back custom exhaust with polished SS Muffler, 20 degree timing advance, SMC STS, Courtesy FSTB, Tok Blues, DARK Tint, GTS Blackouts, Z32 N/A Rims power seats from a 92 SE Stillen X-drilled with Axxiss pads at all 4 corners Goodridge SS brake lines more to come
jwtarbaj is offline   Reply With Quote
Old 10-13-2002, 01:12 PM   #6
try having someone holding up the lever to release the fuel door while you gently pry the door open with a srewdriver.
__________________
Mods: To many to list...
max1ma97se is offline   Reply With Quote
Old 10-17-2002, 10:33 AM   #7
Activity: 0%
I took a look at the cable, I was tugging on it a little to see if it was loose or broken, but it was still pretty tight.
I got the dealer to look at it yesturday and it was just the little white tab (the piece that retracts when you pull the lever that allows the door to swing open) that had to be replaced, it had become defective or broken. They charged me for 1/2 of labour so I said OK.
My SES light was on and I had already diagnosed it myself (2 minutes with a flat head screwdriver ) and it was the Vent Control Valve. The dealer wanted $88 for just diagnosing the problem which they said would take an hour and then another $70+ to CLEAR the SES light
However, they did have one 350z there in silver. The car was GORGEOUS! Seeing pics of it is one thing, but seeing it in person is a whole new experience! And I know other people agree because there was SO many handprints on the windows from people touching and trying to look inside. It wasn't the track model and it didn't have the Navi but it was going for $50,000+ CDN
Anyways, thanks for all your help guys, it was much appriciated.
__________________
98 Pebble Beige GLE
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
