Driving in 5th gear at low speeds
Old 10-03-2002, 09:59 PM
  #41
BriGuyMax's Avatar
Originally posted by Nealoc187
Dude JINX buy me a Coke. hahaha
damn you...how about some beer tomorrow when we install my MEVI??????
BriGuyMax is offline
Old 10-03-2002, 10:01 PM
  #42
MAX2000JP's Avatar
Im still waiting for that stripper that you supposedly booked last weekend.
MAX2000JP is offline
  #43
SLOW
Nealoc187's Avatar
Drunken MEVI installs are sweet. "Hey what's this 12V lead go to...?" BZZZZZZZZT. "Ow."
Nealoc187 is offline
Old 10-03-2002, 10:04 PM
  #44
BriGuyMax's Avatar
dude...the lady that runs the service called me...and since that chick didn't show up....we might get a free show!!
Old 10-03-2002, 10:05 PM
  #45
MAX2000JP's Avatar
SWEET!!!!!!!.....I bet your gay @ss booked some dude instead of Autumn. If so, I take back my "sweet" comment.
Old 10-03-2002, 10:07 PM
  #46
BriGuyMax's Avatar
Old 10-03-2002, 10:09 PM
  #47
BriGuyMax's Avatar
damn you and your homosexual comments....
Old 10-03-2002, 10:13 PM
  #48
Granny Driven
190hpKiLLA's Avatar
WHat do you consider the gears in cars that dont reach the top speed limit in the last gear? AKA VW Jetta and Cobra. Those fockers dont move no where when u floor them in 5th. Maxima does.
No the clutch in not burning when its engaged.
190hpKiLLA is offline
Old 10-03-2002, 10:17 PM
  #49
BriGuyMax's Avatar
it just means they have an overdrive gear that is a lot taller....
Old 10-04-2002, 09:55 AM
  #50
98maxse5spd's Avatar
this thread gave me a headache.
98maxse5spd is offline
Old 10-04-2002, 11:31 AM
  #51
SkyDaver's Avatar
5th is not an overdrive. Drive a mustang COBRA and you will find out what an overdive is. 5th is the gear you reach your top speed thus its not an overdrive. Cars like cobra the 5th gear always StAys at like 2500 RPM and doesnt move.
Wanna know what wear and tear? U are causing preassure on ur flywheel and burning ur clutch. Why dont you drive in 5th all the time.
I get ~250 Miles per tank in NY traffik and like 450 on the highway. aND i DRIVE ROUGH.
What do you get driving in 5th all the time???
Would it be too much to ask that you write an understandable or complete sentence?
In the 5 speed maximas, 5th gear is an overdrive. The rotation of the output shaft of the transmission is slower than that of the input shaft. If you do a search, you'll be able to find the gear ratios of all gears in both a 5 speed and 6 speed manual transmission Maxima. In the 6 speed transmission, both 5th and 6th gears are overdrives.
Perhaps you'd like to petition the Society of Automotive Engineers to redefine 'overdrive'
If, in any gear, you can't accelerate, it simply means that your engine is not producing enough horsepower at that rpm to overcome the forces of friction and inertia. That's all.
If you try to accelerate from 1000 rpm in 5th or 6th gear, you'll not do so very quickly, because you're not generating very much horsepower at that RPM.
If you're cruising down the highway at 3000 rpm in 5th or 6th gear, and try to accelerate, you'll do so much more quickly than at 1000 rpm.
In sixth gear, running in middle triple digit speeds, you won't have reached redline, but you'll be unable to accelerate because you don't have the horsepower to push the car through the air any faster.
I'm going to have to go find those gear ratios again ...
SkyDaver is offline
Old 10-05-2002, 06:50 AM
  #52
lophix's Avatar
Originally posted by SteVTEC
She probably doesn't even understand what gears are, and is just wondering why in the hell your car is so freakin slow!
ARR!!i didnt catch that in time! my gf drives a 5spd Z camaro that can't run low speed in high gears. Mine can! Oh! and she's a track racer and a member of the .org too! she DOES know what gears are! get that right, bish!
lophix is offline
Old 11-05-2002, 02:34 PM
  #53
SonicDust187's Avatar
What are the gear ratios of the 4th gen 5 Speed Maximas?
SonicDust187 is offline
Old 11-05-2002, 02:53 PM
  #54
living out of a maxima...
JeffesonM's Avatar
thanks for the explanation... I was wondering about that comment too. but now its all becoming clear...
JeffesonM is offline
Old 11-05-2002, 03:55 PM
  #55
MaximaMan's Avatar
Damn, that took a good 5mins to read through the entire thread...
I do the same thing as the other guys... once i get to about 40mph shifting 1st, 2nd,i just kick it 4th and cruise.... no accelerating really... keeping the same speed 40mph in 4th gear until i hit a light or something.
MaximaMan is offline
Old 11-05-2002, 04:01 PM
  #56
speedemn's Avatar
1st: 3.285
2nd: 1.850
3rd: 1.272
4th: 0.954
5th: 0.795
Reverse: 3.428
Final: 3.823
speedemn is offline
Old 11-05-2002, 04:24 PM
  #57
Then 4th and 5th gears are overdrive in our cars and not just 5th.
Old 11-05-2002, 05:24 PM
  #58
speedemn's Avatar
4th is barely what you could qualify as overdrive... but I guess in a mild technical sense, yes it is overdriven just a tiny bit.
speedemn is offline
Old 11-05-2002, 06:54 PM
  #59
Maxima.org Sponsor and Donating Maxima.org Member
VeeQueue's Avatar
Re: Re: Driving in 5th gear at low speeds
Why in the hell would you do this?
Lugging the engine like this is extremely tough on the pistons. The throttle is opened 100% and you're pushing the engine extremely hard, yet when the combustion starts, the pistons are hardly even moving and they're stuck right in the center of the combustion. It's a good way to burn up your pistons and put a lot of wear on your rings. From what I've read, it's also rough on the main bearings as well.
Lugging is definitely *not* something you want to do.
Whenever I'm below 2000rpm in a higher gear, I don't give it more than about one-quarter throttle until I get up to 2000rpm where the engine starts to make some torque and can actually pull away cleanly. Full throttle at 1000rpm in 5th is just insane.
Steve has it down. When you floor your throttle at such a low gear at such a low rpm your engine will start lugging and the shaking will cause accelerated wear on the crankshaft bearings. When the cylinder's air/fuel mixture is ignited and burned, it pushes the piston tops down and spins the crank. (This is why the engine is sometimes referred to as an "air-pump"). When you try to force the engine to work harder by flooring the gas in such low gear, the same thing takes place; the mixure burns and pushes the piston down the cylinder...except this time the crank won't be able to turn as fast. The energy created needs to be dispersed. If the crank can't spin fast enough to disperse the energy then the crank itself will have to absorb it. Absorbing means flexing on the connecting rods, crank itself, thus the bearing. This will affect any engine.
Driving around 5th gear at low speeds is fine if you can accelerate without the shaking of the motor. Not to mention the pinging that usually happens too. This means you should accelerate gradually. I like to keep the motor at least above 2500rpm at all speeds. If I'm trying to be a cheap-*** fuel miser I won't cruise below 2000rpm.
Besides, why not avoid this situation by downshifting to a higher gear? It's better to let the motor sing at 3000rpm than to lug it. You have the response and acceleration when you need it. Anyone who is too lazy to downshift to a higher gear then I would suggest that you be one of the first to try the 5-speed to automatic swap
Sorry, I think some of you driving manual trannies are better off driving a car with an automatic. Poor car
VeeQueue is offline
CorollaULEV
30
08-09-2021 08:11 PM
Finkle
09-27-2015 09:53 PM
schmellyfart
09-25-2015 04:47 PM
MaximaDrvr
08-19-2015 08:20 PM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Driving in 5th gear at low speeds
