Go Back   Maxima Forums > Classifieds > Parts For Sale/Wanted > General Maxima Accessories (All Generations)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-04-2009, 09:50 PM   #1
Send a message via AIM to 98SEBlackMax
'02 VQ35 Pathfinder Engine Parts & Intake Manifold
Got a disassembled '02 VQ35 Pathfinder engine that im in need of getting rid of. I have most of the major engine parts available for sale.
I have the cylinder heads, timing covers, chains, sprokets, upper, middle, and lower intake manifold as well. The only things that are not for sale are the throttle body and engine block.
Also have the crank, piston, and rods available for anyone that wants to try to make a VQ33 stroker.
Don't know what the pricing should be, but buyer pays shipping. Local pickup get first dibs as well.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
2007 KH3 Frontier NISMO 4x4 - ??? WHP / ??? WTQ
(6 spd - daily driver)
98SEBlackMax is offline   Reply With Quote
Old 09-06-2009, 06:35 PM   #2
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Free bump.........
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
Cheap VIAS block plates
Dual-mass 6-speed flywheel resurfacing available!
NX wet kit w/digital gauge $400 shipped
KRRZ350 is offline   Reply With Quote
Old 09-19-2009, 12:06 PM   #3
Super Moderator
Send a message via AIM to nismology
Interested in the heads. Perhaps the covers and intake sprockets as well. Price?
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 09-19-2009, 02:49 PM   #4
Quote:
I have the VTCs that came with the heads. I thought about intergrating the Pathy VTCs to a VQ30 application but you have to use the VQ35 pathy heads or do some crazy machine work to the VQ30 heads.
Anyways I will part with everything you listed for $200 + shipping.
Old 09-21-2009, 05:29 PM   #5
Super Moderator
Well I planned on using Pathy heads on a 3.5 block so that's no issue. The only thing that really worries me about all this is the mods needed to be made to the outer cover to accomodate the belt tensioner and the power steering bracket on the inner cover. And from looking at the pathy heads they don't have VTC solenoids on them. Is it an on/off type of thing VE style or PWM like the 3rd gen motors?
And the pathy heads must have the same combustion chamber CC as 3.0's since they both have flat top pistons and 10:1 compression (unless the deck clearance is different, which I doubt). Why couldn't you use them on your 3.0 block?
With that said I think I'm gonna scrap the VTC idea lol. I think I can reach my goal without it. How much for just the heads?
__________________
Old 09-21-2009, 07:25 PM   #6
Yeah if you want to run the VTCs you will need the pathy heads, VTC solenoid bearing caps, valve covers (maybe I think VQ35 maxima ones would work), and timing covers. This was the 2nd problem for this swap getting the PS and other ancilleries to work with whacky timing covers. I may still do this with a VQ30 in the future but highly unlikely. My methods have changed to a more simple way of doing things to keep reliability instead of being the "first" to do something on a Maxima.
I believe these solenoids are PWM they look very similar to VQ35 Maxima ones.
Pathy pistons are flat top, but VQ30 ones have a slight dish. Both blocks have their pistons at zero deck clearance. So im not sure on the exact combustion chamber volume.
I don't see a need to run the Pathy heads on a VQ30 block, my build is going to be all VQ30.
If you still want the heads I will do $100 + shipping. You will need the bearing caps, but do you need the VTC solenoids or will you make cover plates for them?
__________________
- Joe
Old 09-21-2009, 09:29 PM   #7
Super Moderator
Quote:
@ the VQ30 piston dish. You have any up-close pictures of one? All the ones I've seen are from pretty far back. I really wish I knew the PF heads' chamber volume so I can determine the resulting C/R using Gen II 3.5 pistons.
Sounds good. I'll let you know when I can pull the trigger. In the next few days hopefully. I wonder if VQ30 cam caps are compatible with these heads...hmmmm
Edit: What's the condition of the motor in general like? Any oil starvation issues? Anything approaching the wear limit? I know I'm just getting the heads but wondering if the cam bearing surfaces and bucket shims are ok.
__________________
Old 09-22-2009, 07:35 PM   #8
Yeah I will dig up a VQ30 piston sometime and post a photo. It has a very slight dish from what I remember.
I would highly recomend you run these cam caps. When the heads are machined the caps are bolted to the heads and then they are drilled for the cams. Nissan VQs are very tight tolerance but that is why they don't sell the cam caps as individual parts, they only work for the heads they are machined with.
I checked out the heads they definitely need a clean up. Don't think the motor was in the best shape there is a bit of sludge build up. There is some wear but I dont think its unusual for an engine of this mileage. Anyways let me know.
Old 09-22-2009, 09:00 PM   #9
Super Moderator
True, dunno how that slipped my mind. Same deal with main caps.
What was the mileage anyhow?
__________________
Old 09-23-2009, 07:31 AM   #10
im interested in the cams... how much for them
tht98maxkid is offline   Reply With Quote
Old 09-23-2009, 07:03 PM   #11
100K I think. I will pull off the cams and check it out in better detail sometime this weekend.
Old 09-23-2009, 07:04 PM   #12
Quote:
The cams have some surface rust on them from being exposed to air for so long. If you still are interested I will sell them for $50 + shipping.
Old 10-03-2009, 10:03 AM   #13
Not a GM sack rider...
Can you snap a picture of the bottom side ports of the lower IM?
__________________
1996 5spd w/DE-K/HotShot headers/Apexi WS
JWT Short Ram/VAFC2
KYB AGX/Eibach SportLine/97+ front end...
You can subscribe to a thread without posting.
DAVE Sz is offline   Reply With Quote
Old 10-07-2009, 08:42 PM   #14
Quote:
The intake manifold lower looks just like a DEK lower, swirl valves and all. Do you mean the Pathy upper or middle intake manifold?
Old 10-08-2009, 03:56 PM   #15
I meant the lower. I read that the lower ports on that are the same as a 3.5 but the upper are the same as the 00VI.
__________________
JWT Short Ram/VAFC2
Old 10-08-2009, 05:03 PM   #16
Price of one of the upper manifold shipped to 32119?
__________________
00VI | 5.5Gen BBK | 00 5 spokes | Kumho Ecsta SPT | Cleared Tails | FX retro | LED interior | SNOMAX's LCAs | Raxles
FS: Plug and Play E-manage Ultimate, E-manage Blue & VAFC/SAFC Harnesses
Florida Gators: (10-0) | CSU (62-3) W | Troy (56-6) W | Tenn (23-13) W | Kentucky (41-7) W | LSU (13-3) W | Arkansas (23-20) W | Miss St (29-19) W | Georgia (41-17) W | Vandy (27-3) W | SC (24-14) W | FIU | FSU
MOHFpro90 is offline   Reply With Quote
Old 10-17-2009, 06:58 AM   #17
Lower ports look like DE/DEK ports. The heads have DE/DEK style intake ports.
Old 10-17-2009, 07:02 AM   #18
Quote:
Oppps missed this post. Check your PM box.
__________________
- Joe
Old 10-21-2009, 07:24 PM   #19
Send a message via AIM to tyler5619 Send a message via Yahoo to tyler5619
mmm, stroker. lol...
how much for the crank, piston, rods, cams?
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
JVC HU. | 35% tint. | Blackout center caps. | Indy fogs. | Blackout Maxima badge. | Custom blackout SE badge. | Clear bumper lights. | A33 OEM clutch. | HTP MAF adapter, AMSoil cone filter. | NGK Iridium spark plugs. | eBay FSTB. | WarpSpeed y-pipe. | White & bright clock. | Custom 2.5" b-pipe. | Custom G20 sidemarkers. | E46 Bi-X, 6K D2S. | Thrush glasspack. | Magnaflow muffler. | Full tank of 93 octane.
BIRD COUNT: 2.
tyler5619 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
