Throw me a figure for what it's worth to you.
Back when these 00VI's were first becoming the "hot" upgrade for the 4th Gen Max., I sourced several of these complete setups, cleaned them up, JB Welded the cup and did whatever else was needed to make then premo and installation-ready. The one thing I remembered as being the common problem was that the mindless gorillas at the salvage yards often broke off hose nipples. My fix for that was to cut off, drill out, tap for threads, and epoxy in a brass hose-barb fitting. I don't know if those $80-120 UIM's that are being referenced may be ones that have that damage or not. But my recollection is that once that sort of problem is taken care of, the only other problem with the 00VI that's subject to deterioration over time is that cup in the VIAS. For anyone with an 00VI, if that's a possible problem you may have to face down the road, finding one of these when you actually need it may be a lot harder than you think. That's why I popped for the money to buy this one when I did. Fortunately, I never needed to use it because I JB Welded my cup before it ever became loose.
Just a thought to consider.
