Go Back   Maxima Forums > Classifieds > Parts For Sale/Wanted > General Maxima Accessories (All Generations)
Thread Tools Display Modes
Old 07-27-2008, 08:00 PM   #1
Send a message via AIM to ghostmax301 Send a message via MSN to ghostmax301
JWT style 3.5 cams with adapters
Well, I lost alot of oil due to a faulty oil psi switch and ended spinning a bearing so, new motor is going in. Cams are being sold.
If needed, i will sale the cam adapters with them so you can use them in a 3.0 or use the adapters for a 3.5swap.
its a 260/260 deg. duration with a 10.9mm lift
Selling for $500 obo with the adapters.(shipped)
__________________
Guaranteeing mid 12s before boost
http://myspacetv.com/index.cfm?fusea...deoid=47285964
http://www.youtube.com/watch?v=e1i7ZP5R-jg
13.55@103(no tune,street tires)
Should have b4 next race season:
EMU/Cutout/WBo2/Headers/NWP spacers/UDP/Fidanza Flywheel/Stage 3 clutch
ghostmax301 is online now   Reply With Quote
Old 07-27-2008, 08:20 PM   #2
Build.
Send a message via AIM to nismology
The link is broken, mate.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 07-28-2008, 12:07 AM   #3
MODS, can you move this to the general FS section please.
__________________
Old 07-28-2008, 12:12 AM   #4
Build.
Done. Even fixed the spelling.
__________________
Old 07-28-2008, 10:52 AM   #5
Send a message via AIM to NiZMo1o1
any pics ? JWT SYTLE ? so these are knock offs ?
__________________
NiZMo1o1 is offline   Reply With Quote
Old 07-28-2008, 12:42 PM   #6
no pics as of yet. They are still in the motor. Going to start on the tear down today. But yes. they are the knock offs. I had a video of the idle but something happened to the link. Going to take another video today of the idle and post it up in about 3-5hours.
__________________
Old 07-28-2008, 05:29 PM   #7
are these just regrinds or acutal company that makes jwt knock offs ? Is there more specs on these?
__________________
Old 07-28-2008, 05:57 PM   #8
Deluboz is the company.
I believe Jime had a writeup of the satisfaction with these cams.
Spec
260 Degrees Duration / .428" (10.9MM) Lift (Intake Cam.Advanced 2 Degrees)
Cold Valve Lash .010-.013" on Intake & Exhaust
link to place where they were bought from
http://cgi.ebay.com/ebaymotors/JDM-P...QQcmdZViewItem
__________________
Old 07-28-2008, 09:39 PM   #9
PM'ed ya
__________________
Old 07-28-2008, 11:11 PM   #10
videos:
this is the noise coming from TC
exhaust note on cold idle
Old 07-29-2008, 12:54 PM   #11
MMM Interested in how these cams are?
anm6 is offline   Reply With Quote
Old 07-29-2008, 02:46 PM   #12
The LandShark has teeth..
grey99max's Avatar
Spec
Hey ghost, I've got a set of those installed in my 3.5 '99, and they work very well. Were you able to bolt your cams in without changing any of the cam buckets? I was lucky with my install - everything within .001 " of spec. Used Stephen's cam adapters and no problems there.
Bad luck on your oil leak.
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
13.158 3.0 time slip
http://i48.photobucket.com/albums/f2...3/Fscn1518.jpg
12.394 @113.22 w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 07-30-2008, 10:05 AM   #13
Build.
Can you confirm that the cams have not been damaged as a result of the oil pressure loss?
__________________
Old 07-30-2008, 11:29 AM   #14
stock cam buckets and yes nismology, I will pop the valve cover off when I get home and take pics. ill have the whole cam out by.........sat-sun as long as there is no rain
__________________
Old 07-30-2008, 11:31 AM   #15
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
How do these cams fair with boosted applications? Is this lift/duration geared for a more N/A setup, or still good gains can be had with forced induction?
__________________
Moar pics of Evo5's ---> http://forums.maxima.org/tires-wheels/557747-old-school-new-look-rare-evo5s.html
In One's Own Tune, Balance Is Found In The "Area Under The Curve".....
Deckdout2 is offline   Reply With Quote
Old 07-30-2008, 01:57 PM   #16
Send a message via AIM to !PrjctMax!
Quote:
You must not have read all of it...
__________________
OEM 6th gen parts
http://forums.maxima.org/6th-generat...-out-sale.html
shocks, coil-packs, mud-flap, LIM
!PrjctMax! is offline   Reply With Quote
Old 08-02-2008, 10:20 PM   #17
bump bump bump
__________________
Old 08-15-2008, 01:10 AM   #18
and your mom
VenoMax647's Avatar
Send a message via Yahoo to VenoMax647
gemmie two weeks
__________________
95 se custom 2.5'' exhaust//high flow cat//budget y pipe//weapon R short ram//k sport lowering springs (2.2-2.0)//tokico Hp series shocks and struts//poly mounts
3.5 swap in progress.....
VenoMax647 is online now   Reply With Quote
Old 08-15-2008, 03:43 PM   #19
Play with my balls
Deckdout2's Avatar
i'm interested in these, but i would like to have my question above answer prior to moving forward. thanks.
__________________
Moar pics of Evo5's ---> http://forums.maxima.org/showthread.php?t=557747
Old 08-15-2008, 04:13 PM   #20
Build.
They are fine for boosted apps. Plenty of examples over on my350z. They are, after all, on the mild side of the spectrum no matter the application.
__________________
Old 08-15-2008, 04:38 PM   #21
Play with my balls
Deckdout2's Avatar
Preciate that. I'm not well versed in cams regarding specs and demographics. When I was looking a while back I knew different specs worked better (saw more gains) with specific applications, but couldn't recall that info (subscribed thread).
Will do more soul searching and advise decision. Thanks.
__________________
Old 08-15-2008, 05:01 PM   #22
Build.
If you do decide to get a more aggressive grind, please be advised that the price will jump up by a few hundred (at the least) since these are knock-offs.
__________________
Old 08-19-2008, 01:57 PM   #23
$400obo shipped
bumpity bump bump..Ill give a few more weeks before I decide to keep them and install on my 3.5 swap
__________________
Old 08-22-2008, 12:10 PM   #24
Play with my balls
Deckdout2's Avatar
$400obo shipped
I wouldn't need to use the cam adapters if I'm installing these directly in a 3.5 correct? Only if they were going in a 3.0 and/or 3.5 swap?
I'm still debating back and forth, looking at this thread everyday, just haven't made up my mind yet. Sorry so slow.
Old 08-24-2008, 12:10 PM   #25
