Go Back   Maxima Forums > Maintenance, Tech, & Care > Garage and Workshop
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-30-2011, 03:23 PM   #1
大陆弟弟
n3985's Avatar
Points: 14,324, Level: 77
Points: 14,324, Level: 77 Points: 14,324, Level: 77 Points: 14,324, Level: 77
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Air compressor CFM vs impact gun required CFM
For Xmas I decided to get an air compressor for myself to save time removing lug nuts and the occasional use around the car.
To keep things on a budget I bought the following:
http://www.harborfreight.com/25-hors...sor-67847.html
At 90psi it outputs 4.7CFM.
To go with it I bought this 1/2 impact:
http://www.harborfreight.com/12-prof...nch-68424.html
On the site it says 4.4CFM at 90psi to run, however upon purchase the actual box says 6CFM at 90PSI.
I haven't broken in the compressor yet but when I hooked it all up for testing, set the pressure to 90PSI and the gun felt....really weak. Haven't actually tried it yet on the car but when I stopped by Harbor Freight and spoke to a sales guy, he said my compressor won't cut it.
So the question is, the gun runs optimally at 6CFM @ 90PSI. If I was to use it with my current compressor which only does 4.7CFM @ 90PSI, it'll work albeit weaker than rated/designed/optimal correct?
Any insights appreciated!
__________________
n3985 is offline   Reply With Quote
Old 01-12-2012, 03:10 PM   #2
Points: 17,752, Level: 84
Points: 17,752, Level: 84 Points: 17,752, Level: 84 Points: 17,752, Level: 84
Activity: 99.3%
Activity: 99.3% Activity: 99.3% Activity: 99.3%
The impact gun will not have the power to get the really tight nuts and bolts loose (or tight) if the air compressor can't deliver the CFMs. The only thing you could do is get a air tank and run the impact gun off of the tank and the compressor re-fills the air tank. The bigger the tank, the longer you can use the impact at full power. Maybe a 10 gallon tank would be ok for your needs but I really don't know. You might have to get a 25 gallon tank. But then when you consider the cost of the under-rated compressor and an extra air tank, a higher capacity compressor might be cheaper and definitely take up less room.
DennisMik is offline   Reply With Quote
Old 01-15-2012, 02:40 PM   #3
大陆弟弟
n3985's Avatar
Activity: 0%
Well I found out I had a defective compressor, returned it for a new one and everything works fine now. You are right about the CFM however it only matters when the compressor runs out of air, but mine is more than enough to remove lugs
__________________
Old 01-16-2012, 06:11 PM   #4
Points: 8,384, Level: 61
Points: 8,384, Level: 61 Points: 8,384, Level: 61 Points: 8,384, Level: 61
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
That's way better than my setup...I've been using a Craftsman 1.5gallon? (the upright portable w/no wheels) that I use for work for the last 5 years w/a couple of Craftsman impacts and fortunately have never had issues even when taking off axle or subframe bolts.
Then again, I live around Memphis and have zero rust....I really want to get a decent upright compressor. It's no fun hearing a compressor running full tilt just to take a few lug nuts off lol!
Jeremy
niceguy is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
