Go Back   Maxima Forums > Maintenance, Tech, & Care > Garage and Workshop
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-18-2009, 06:50 PM   #1
Red face Removing RTV?
What do you use to clean off RTV? About to replace my oil pan and not sure how to get off old RTV. Does water harden it (so I should avoid using water)? Do you use alcohol or what?
I know it's a noob question but there are only 3 threads with "rtv" in the subject and I've never dealt with this stuff.
ridinwitha35 is offline   Reply With Quote
Old 08-18-2009, 07:38 PM   #2
Points: 4,534, Level: 42
Points: 4,534, Level: 42 Points: 4,534, Level: 42 Points: 4,534, Level: 42
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Acetone or lacquer thinner, available at Home Depot or Lowes, and a good quality gasket scraper. You can get one at Sears. Still, it takes time and some elbow grease to get RTV off, and you have to be careful not to gouge anything. Permatex makes a gasket remover product but I've never seen it in an auto parts store. Alcohol or water won't hurt anything but won't work either.
ATTappman is offline   Reply With Quote
Old 08-19-2009, 06:15 AM   #3
Ad·min·is·tra·tor
DanNY's Avatar
Points: 51,263, Level: 100
Points: 51,263, Level: 100 Points: 51,263, Level: 100 Points: 51,263, Level: 100
Activity: 57.0%
Activity: 57.0% Activity: 57.0% Activity: 57.0%
that gasket remover helps but you still need elbow grease.
i use a red scrubbie pad to get the last small bits off.
3M makes a gasket remover on a roloc but thats a bit of overkill for most.
Click the image to open in full size.
DanNY is offline   Reply With Quote
Old 08-19-2009, 09:13 AM   #4
Thanks for the responses ATTappman and DanNY, I appreciate them!
I'll try some acetone...can get that at Walgreens and then Sears for a gasket remover tool. I would have to avoid Roloc dics since I don't have a Roloc. Hopefully all goes well and I don't end up causing more damage.
Old 08-30-2009, 08:05 PM   #5
STFU n00b!
Points: 41,344, Level: 100
Points: 41,344, Level: 100 Points: 41,344, Level: 100 Points: 41,344, Level: 100
Activity: 25.3%
Activity: 25.3% Activity: 25.3% Activity: 25.3%
I also use fine steel wool if it's a part that I'm taking off and cleaning. (like the oil pan itself where I can wash it well with water afterwards). I WOULD NOT use it on the bottom of the engine as you may get small bits of metal on the insides of the block that you don't want stuck in a filter or bearing..
But for things like water pumps, cleaning parts off the car, etc... the stuff is great.
__________________
04 G35 Sedan 6MT- The DD
96 240SX- The race car
93 Maxima SE 5 speed- retired 1-5-09
Matt93SE is offline   Reply With Quote
Old 09-05-2009, 01:35 AM   #6
1993-VG30E-GXE's Avatar
Laquer Thinner is the WORST (but the best) of a bunch i've tried. It works but it goes right into your lungs if your not careful. I stopped spraying it. It ruined one of my engine cleaning guns, I had to return it. That said, it is the best cleaner i've used, but I need some better industrial mask to use it...with vapor protection, but I don't have one right now. Spraying it in those air engine cleaning guns creates a toxic mist cloud.
I tried those Scotchbrite Rolocs, I bought 3 of them, but they take off metal almost instantly, I'll take a photo. Maybe that wasn't the right disc? Is it a specific gasket remover disc?
1993-VG30E-GXE is offline   Reply With Quote
Old 09-11-2009, 12:50 PM   #7
STFU n00b!
Activity: 25.3%
lacquer thinner is not supposed to be used in a spray. well, not unless you've got a REAL respirator on. to use lacquer thinner, pour it on a rag and start rubbing.
but not much fo anything will dissolve RTV silicone. you must mechanically remove it. steel wool, scotch pad, sandpaper, razor blade, etc.
__________________
Old 09-11-2009, 01:39 PM   #8
Points: 5,934, Level: 49
Points: 5,934, Level: 49 Points: 5,934, Level: 49 Points: 5,934, Level: 49
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
OMFG DONT USE ANY CHEMICALS..... Use a razor blade it takes like 2mins and no effort at all.... elbow grease my ***.... its a breaze. I would recommend you buy a gasket for the new oil pan so you dont have any leaking/rust problems in the future. Im pretty sure the oil pans go bad quick simply because nissan didnt use gaskets on them...FTMFL
__________________
Injen CAI - Smoked Sidemarkers - FSTB - NWP VAIS Blockoff Plate - OBX V2 headers - CompuStar 2way Alarm/Car Starter
nzelinsky is offline   Reply With Quote
Old 09-11-2009, 03:11 PM   #9
FWIW, I used a putty knife & acetone, and used Ultra Black RTV for the gasket. So far so good though.
These were my tools for the pan replacement:
Old 09-11-2009, 06:15 PM   #10
STFU n00b!
Activity: 25.3%
Quote:
That's funny. Carmakers have been replacing fragile gaskets with RTV for many years because of the reliability and longevity of RTV over a cork/rubber/paper gasket, especially in the presence of oils. Corrosion isn't an issue with the pans. it's sandblasting and salt from the roadways. sand kicked up front he car in front of you sandblasts the underside of the car and then the salt attacks the fresh metal. so on, so forth.
__________________
Old 09-11-2009, 09:10 PM   #11
Wanna Go Fast?™
MrGone's Avatar
Points: 67,082, Level: 100
Points: 67,082, Level: 100 Points: 67,082, Level: 100 Points: 67,082, Level: 100
Activity: 98.6%
Activity: 98.6% Activity: 98.6% Activity: 98.6%
I use those but buy the replacement pads from harbor freight most of the time.
MrGone is offline   Reply With Quote
Old 09-12-2009, 01:07 PM   #12
Another cheap alternative is just to buy a gasket scraper...it looks like a screw driver handle with a blade on the end. It worked for me (that and laquer thinner).
Old 09-12-2009, 01:10 PM   #13
Good call on the putt knife too, this is what I used to separate it from the block, I tapped it lightly to slip between and separate the 2, in various spots. I wouldn't stick the gasket scraper in between or it could damage the flange.
Old 09-13-2009, 07:50 PM   #14
Super Moderator
Points: 15,957, Level: 81
Points: 15,957, Level: 81 Points: 15,957, Level: 81 Points: 15,957, Level: 81
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
Send a message via AIM to nismology
That's a sure way to scratch and mar the surface in my experience. The only scraper I'd ever use on pans is one made of brass.
nismology is offline   Reply With Quote
Old 11-22-2009, 09:41 PM   #15
In removing GE Silicon Adhesive Sealant and GE RTV Silicon Rubber by a Technical Center that repairs GE function boxes. They had to replace the entire box due to the inability to remove the sealants without any damage to the face plates.
__________________
Bubble bath
Oswald is offline   Reply With Quote
Old 11-23-2009, 04:03 PM   #16
Points: 26,027, Level: 96
Points: 26,027, Level: 96 Points: 26,027, Level: 96 Points: 26,027, Level: 96
Activity: 0%
I like the Roloc wheels with the rubber fingers....worked well when we did the IM on my truck....
__________________
Cutler is offline   Reply With Quote
Old 11-25-2009, 09:56 AM   #17
Points: 9,102, Level: 64
Points: 9,102, Level: 64 Points: 9,102, Level: 64 Points: 9,102, Level: 64
Activity: 0%
Send a message via AIM to MIK3
I plan on removing my upper manifold to replace my spark plugs and I have spacers with RTV on them. This is helpful thread. I'll be taking the razor-blade/chizel approach. I can't risk getting chemicals into my manifold area.
__________________
MIK3 is offline   Reply With Quote
Old 01-06-2010, 05:46 AM   #18
KRRZ350's Avatar
Points: 15,958, Level: 81
Points: 15,958, Level: 81 Points: 15,958, Level: 81 Points: 15,958, Level: 81
Activity: 0%
Send a message via AIM to KRRZ350
Putty knife run down the grooves angled one way then back down it again angled the other way, then quickly scrape the flat parts, then follow it up with brake cleaner & a drill mounted wire brush with soft bristle's. On the parts that you can't fit the wirebrush, or don't want to use it such as the parts of timing cover still on the motor or the block part of the upper pan I do the putty knife first & then instead of the wire brush I use the maroon 3m auto scuff pad. Follow it all up with a microfiber & brake cleaner so you have no traces of oil etc, tourqe to spec & use permetex ultra grey & you won't have any problems. It's also helpful your first couple times to measure the thickness of your bead per the fsm. When you're putting that pan back up don't forget to remove the dipstick & make sure the crank sensor wires are out of the way.
__________________
Maximaparts@hotmail.com
KRRZ350 is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
