Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
scary story about my dad jack failing.
Old 06-16-2009, 11:45 PM
whiteSE's Avatar
i just think it would be a good pre cation, and a lesson for me. i screwed up.
anyways, i got some 350z rims for my car, went to a tire shop to put valve stems into them, and had them balanced. pulled away into a parking area, and decided to install the rims. i jacked up my car, rear left, changed the tire, rear right, then i untightned the front right tire, jack up the car, using the same 2 ton hydralic jack, take of the old rim, and then the car started to slowly fall down, like a inch every 3 seconds, so i panic, try to put the rim back on the lugs, but the car already was to low, and also, the rim got stuck but the car was still falling. so i get the jack from the trunk and started jacking up the car up with it. luckly, the car didnt fall all the way, and the rim didnt get bent. i changed the last tire, using my factory jack. i got kinda freaked out beacasue i was supposed to change my oil soon, and i was most likely going to use that jack. now im probably going to throw it away.
i did check the locking thing on the jack, where you release the presusre, and it was closed. WTF? pep boys jack FTL. anyone have experince like this with crafstman jacks? im going to get that next.
whiteSE is offline
Old 06-16-2009, 11:54 PM
Go BUCKS!!!
SEmy2K2go's Avatar
Why didn't you give the jack a few pumps to raise the height?
SEmy2K2go is offline
Old 06-17-2009, 12:08 AM
whiteSE's Avatar
i did, but nothing, it kept on falling
whiteSE is offline
Old 06-17-2009, 12:12 AM
Leo_Koneval's Avatar
Wow that is scary, I'm glad you didn't get hurt. I mean if that happened while you were under the car taking out the transmission or whatever, it would be a disaster.
Leo_Koneval is offline
Old 06-17-2009, 12:17 AM
whiteSE's Avatar
yep. so im thinking of buying a new jack...wat do u guys recommenced?
whiteSE is offline
Old 06-17-2009, 12:38 AM
Go BUCKS!!!
SEmy2K2go's Avatar
http://forums.maxima.org/garage/5874...loor-jack.html
Old 06-17-2009, 07:25 AM
1993-VG30E-GXE's Avatar
Only an idiot would go under a car supported by a jack though.
Even for accessing the drain plug OP!
1993-VG30E-GXE is offline
Old 06-17-2009, 07:54 AM
Ad·min·is·tra·tor
DanNY's Avatar
JACK STAND!!??!! c'mon!!
DanNY is offline
Old 06-18-2009, 12:32 AM
whiteSE's Avatar
thanks
whiteSE is offline
Old 07-06-2009, 11:03 PM
Mu_036sp's Avatar
i always use my Jack stands! thank god you and your car is okay
Mu_036sp is offline
Old 07-06-2009, 11:09 PM
whiteSE's Avatar
thanks. i use stands now every time i jack up the car.
whiteSE is offline
Old 07-07-2009, 07:10 AM
mannetti21's Avatar
I guess for some people it takes one of these oh **** moments to do things the right way. I have 4 jackstands and I usually use all 4 whenever I'm under the car for anything. you gotta remember that if the car falls you probably aren't going to survive.
mannetti21 is offline
Old 07-07-2009, 07:21 AM
B_Eaze's Avatar
I ALWAYS use jack stands and if Im taking tires off I put those under the car for a back up...
B_Eaze is offline
Old 07-07-2009, 07:26 AM
nycnissans
secondtonone317's Avatar
USE THEM!!!
secondtonone317 is offline
Old 09-28-2009, 11:09 AM
Marlin's Avatar
Wow scary!!
Marlin is offline
Old 09-28-2009, 11:36 AM
Kquezada28's Avatar
lol i would have been ****ting bricks and screaming like a little girl....but definitely use like 4 jacks next time
Kquezada28 is offline
Old 09-28-2009, 12:02 PM
I need a truck
Conrad283's Avatar
Jack stands ... Always.
Conrad283 is offline
Old 09-28-2009, 01:35 PM
whiteSE's Avatar
yeah. thats what i do from now on. i never use tat jack agian either
whiteSE is offline
Old 09-28-2009, 02:20 PM
ampire's Avatar
You can also shove one of your spare wheels under the jack points on each side as a precaution. I have a set of racing wheels off of a old porsche and I throw them underneath the doors by the jack points depending on what Im doin.
ampire is offline
Old 09-28-2009, 02:43 PM
Slightly old thread....but I'll contribute that I've read the reviews for Craftsman jacks, and apparently they suck big time.
The Wizard is offline
Old 09-28-2009, 02:49 PM
vntperformance's Avatar
Talk about a funny story. Jack stands ftmfw!
vntperformance is offline
Old 10-16-2009, 11:55 AM
doublea's Avatar
This happend to me with 2 brand new hydraulic jack, both where missing hydraulic oil so you wanna check that. I have 4 hydraulic Jack ( 2 ton each ) and 4 x Jack stand so whenever i lift the car I use all of the 8 jack sometime I even put some 8 x 8 wooden pieces. Some say I'm fanatic, but at 48 I never had a single injury because of faulty jack.
My rules of thumb is to always use at least 2 level of security but most of the time I use 3.
Good luck.
AA
doublea is offline
Old 10-16-2009, 03:23 PM
I use two jacks whenever I raise the car
But jack stands are expensive, $40 for two at Schucks. I guess $80 bucks for a set of four is not worth dying in a uncomfortable position over
Old 10-16-2009, 11:16 PM
nyana107's Avatar
no need to throw it away. just pump some new hydraulic fluid in there. while you're at the store getting some hydraulic oil, buy some jack stands foo!!!
nyana107 is offline
Old 10-17-2009, 11:09 PM
Mr. Blue Sky's Avatar
around 18 years ago my dad had his 300zx fall on him because he trusted a jack too much. Luckily it wasn't a sudden fall, it was more like what you were describing about it slowly falling, except he was busy underneath the car, so he didn't notice at first. When he started to notice that it was starting to crush him, he called out to us and we were able to get the jack to go up again. We have never lifted up a car without placing jack stands on it since(no matter if it is a simple thing that will only take a couple of minutes). I am glad my father didn't lose his life because of a simple mistake(I was 6 at the time).
I read that jacks need continual maintenance on them, and that the lack of maintenance is the most common mistake that many people make when dealing with their floorjacks.
Mr. Blue Sky is offline
Old 10-20-2009, 03:39 PM
Rood's Avatar
Funny, I have craftsman professional jack and jack stands and they work amazing. I also have cheap autozone jackstands that seem to work great too.
Rood is offline
Old 10-23-2009, 07:34 PM
What's the kind of maintenance I should be doing on my jack? I wasn't aware of that.
Old 10-24-2009, 12:43 PM
B_Eaze's Avatar
I don't believe floor jacks need regular maintenance unless you use it multiple times a day but I could be wrong..... but what I do know is that if you use jackstands it won't matter if your jack is failing cuz you won't be under the car when it does fail
jack stands
/thread
B_Eaze is offline
Old 01-14-2010, 01:58 PM
newspeed's Avatar
I can't believe there are people that would go under a car without jack stands. I sometimes even use 2 jack stands on every corner for extra paranoia... Only takes a minute or two to place them but they can save your life.
newspeed is offline
Old 01-14-2010, 10:54 PM
SuPeRmOd
NismoMax80's Avatar
wait if u paid for balancing and valve stems... why not just let them put the wheels on??
NismoMax80 is offline
Old 01-15-2010, 01:12 AM
whiteSE's Avatar
well i was working at wendys at that time. i had to save as much as possible to survive. lol
whiteSE is offline
Old 01-15-2010, 08:40 PM
SuPeRmOd
NismoMax80's Avatar
i just said bc it was included as far as i knew... i'm all about saving nickels too. if i saved a few i would do it myself bc i want to avoid air guns and over-torquing as well. getting new wheels this spring. before i didnt care bc wheels already got ruined.
Old 01-15-2010, 09:43 PM
whiteSE's Avatar
they wanted 20 to install the rims. plus that shop already screwed up my dads dodge caravan lugs and my bros tundra lugs as well
whiteSE is offline
Old 01-18-2010, 02:39 PM
Wild for Width
Fr33way™'s Avatar
It's mainly the seals and that it is filled with fluid.
Fr33way™ is offline
Old 01-20-2010, 10:11 PM
blahzace's Avatar
oh damn, becareful next time and post some pics of the car w/ the z rims!
blahzace is offline
Old 01-20-2010, 10:56 PM
whiteSE's Avatar
the car was sold like 4 months ago
whiteSE is offline
Old 01-23-2010, 05:07 PM
SuPeRmOd
NismoMax80's Avatar
lol he just wants his 15
Old 01-23-2010, 09:04 PM
whiteSE's Avatar
i guess...but we were all like that b4
whiteSE is offline
Old 01-26-2010, 05:39 AM
My axles cry for mercy...
essential1's Avatar
USE JACK STANDS FOR EVERYTHING!
I had a car fall on me because of carelesness with jackstands guys. I was doing a job that was only gonna take me between 5 to 10 minutes under the car. But thats all it takes for something to happen guys.
The car fell on my head. the control arm was sitting on the side of my face and the brake rotor was sitting on my chest. I was pinned under there for about a minute and a half before my dad and brother were able to lift the car. I had 29 stitches in my face and 3 staples behind my ear. I'm very lucky to only be left with a pretty nice scar.
But bottom line guys, JACKSTANDS JACKSTANDS JACKSTANDS. I dont wish what happend to me to happen to anyone else. Stay safe guys.
essential1 is offline
Old 02-22-2010, 11:15 AM
A-BOY's Avatar
now you will use stand
A-BOY is offline
Quick Reply: scary story about my dad jack failing.
