VQ35 Oil Selection
#41
Seems I was being impatient when adding the new oil, good to know it helps to add oil then wait 10 minutes before starting the engine.
Darn no test tubes, beakers or flasks needed? But I get it, I over complicate things because the FSM plainly says its 4 1/4 quarts for draining the engine oil with filter change. I just need a better way to measure that 4.25 quarts.
Thanks again, I'll be offline chewing on my foot now.
Any as long as you put 4 to 4 1/4 qts. in, you really dont need to wait 10 minutes to start the engine. You can start it right away. Just wait 5-10 minutes after you shut it off to check the oil level.
I do think you are over complicating things quite a bit. I typically just use the markers on the side of the bottle or jug i am pouring from to determine how much I put in.
You'll be chewing on your foot....LOL...
#42
No need to measure, that is what the dipstick is for.
You are over complicating
Buy a jug of oil (5L or 5 quarts, whatever) and add 3/4 of the jug. Check the oil after a few min, wipe dipstick, re-insert. Add the rest as required, keep the last bit of the oil and use for top offs.
Nothing scientific about it
#46
too many bad experinces with pennzoil on our older cars, we had a ford LTD and a Toyota Corolla way back and we noticed in both cars when pennzoil was used the cars would both start burning it off, the ford had a slew of problems aside from just the oil but the we changed from pennzoil to mobil 1 and quaker state and the burn off and so on stopped.
#47
I'm assuming you were using the old dyno pennzoil? That stuff would never touch my engine either.....
But the platinum synthetic is a whole different ballgame.
#49
it honestly didnt, i cant blame pennzoil for the reason that car had endless electrical problems and the transmission never worked the way it should. what i like about it was the motor shifted the whole car when u stepped on the accelerator, despite our I30s being a **** ton more powerful then the ford they cant do that. good old iron blocks.
#50
#51
I use Rotella T6 Synthetic 5W40, so far three oil analysis have shown perfect results. Not only is it probably superior to rest of the off the shelf oil's but its also pretty cheap, $19 for a gallon at walmart.
#52
The last time I researched this topic, I thought the "European Formula" Mobil1 0w-40 was the best "off-the-shelf" oil for the VQ35DE. Has that now shifted to Pennzoil? My350Zs charts are all broken, so I can't really examine those until he posts new results sometime in the near future, but I'm changing my oil today so... Yeah.
I'm putting in the aforementioned M1 0W-40 with the M1-108 filter. I'll definitely do a UOA in a few months and see what's what. My engine is burning oil, but I'm having difficulty determining how much. Starting over with a clean slate will give me the variables I need to more accurately track it.
#53
By 3500 miles using 10w30 the engine was rattling like crazy and had consumed a ton. I picked up some GTX High Mileage 10w40 for my latest change and so far the engine seems to be running fairly smooth, about 600 or so miles on it.
I'll probably do another run of 10w40 then send it off to Blackstone.
#54
Update?
I am going to send in virgin Castrol GTX high mileage and my used oil this time, Blackstone will run the virgin oil at no charge.
I should be due to send off a batch later this week.
#55
Here is my latest oil report, still using Rotella T6 5w40, it shows a little high on chrome, which makes me worry about ring wear, possibly from cold start piston slap. I am inlove with the Rotella but they dont offer anything thicker, what oil do you guys recommend that is thicker and as good as rotella? I wanna try to get rid of the piston slap a little bit.
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
06-06-2017 02:01 PM
