Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 01-20-2010, 03:22 PM   #1
Points: 4,918, Level: 44
Points: 4,918, Level: 44 Points: 4,918, Level: 44 Points: 4,918, Level: 44
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
What grade of engine oil should I used?
2004 nissan maxima 3.5 vq35DE
mods: Aem cai,Greddy exhasust,ecu-reflashed,timing 2 degrees for nitrous.
Stock rpm was 6,400
with ecu-refaslhed now is 7,100 rpm
plus this is my 2nd motor so I wanna keep it alive as possible n for now I'm using 5w30 PP oil with mobil one filter.
All I wanna know is what grade should i used for my engine oil?
Thank u.
rohanmax14 is offline   Reply With Quote
Old 01-20-2010, 03:28 PM   #2
Activity: 2.7%
Motor got 10,000 mile on it.
Old 01-23-2010, 04:40 PM   #3
SuPeRmOd
NismoMax80's Avatar
Points: 19,132, Level: 87
Points: 19,132, Level: 87 Points: 19,132, Level: 87 Points: 19,132, Level: 87
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
what ur using is fine.
manual says 5W-30.
some may vary a lil depending on where they live, but that weight covers a good range. unless you see they prefer something else in the Nitrous forum?
__________________
NismoMax80 is offline   Reply With Quote
Old 01-25-2010, 03:50 PM   #4
5W-30
JD05 is offline   Reply With Quote
Old 01-30-2010, 03:38 PM   #5
Activity: 2.7%
Can I put 10w40 oil?
Old 02-06-2010, 04:34 AM   #6
Quote:
well yeah sure you can. should you? no. 5w30. listen to your manual, im sure it knows best =)
Col Ronson is offline   Reply With Quote
Old 02-06-2010, 09:40 PM   #7
Activity: 2.7%
Will royal purple tech tld me to used 10w40 oil bec it shown protect engine best even mobile one tld me to used 10w40 high miliage oil.
Old 02-06-2010, 10:11 PM   #8
Send a message via AIM to Mjwompf
I think 10w40 is a little on the heavy side. 10w30 should do cool if you are not satisfied with the 5w30.
Mjwompf is offline   Reply With Quote
Old 02-12-2010, 02:28 AM   #9
Of course Royal purple technicians know way more about which oil is better for engines than the guys who actually designed the engines: NISSAN.
5W-30 or 10W-30. Listen to your manual.
Old 02-12-2010, 08:53 AM   #10
Points: 6,587, Level: 53
Points: 6,587, Level: 53 Points: 6,587, Level: 53 Points: 6,587, Level: 53
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Ask RP to produce the studies of the engine tear down results from testing the VQ with 10W40 versus 10W30.
I thought so none exist....
Stick with 5W30 or 10W30 or even 0W30 if running Synthetic.
__________________
11 G37s, Blue Slate, 7-Speed Auto
11 Cayman, Arctic Silver, 6-Speed
MaxLoverAz is offline   Reply With Quote
Old 02-14-2010, 02:44 PM   #11
Activity: 2.7%
Lookup Amsoil.com n is said all tempertare 5w30,10w30, n 10w40 for 2004 Nissan maxima.
Old 02-15-2010, 09:41 AM   #12
Points: 3,488, Level: 36
Points: 3,488, Level: 36 Points: 3,488, Level: 36 Points: 3,488, Level: 36
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
The higher weighted oils are for hotter heat engine, my ex porsche 911 took a 20-50
FenderGuy is offline   Reply With Quote
Old 02-16-2010, 07:30 PM   #13
Activity: 0.8%
Is a thicker oil better for engine protection than a thinner one?
Not usually, but sometimes. There is a relationship between viscosity, pressure, and lubrication. As viscosity decreases, or pressure increases, lubrication begins to suffer at some point. The relationship can be plotted for various oils and the resulting graph is known as the Stribeck Curve. This curve shows us that increasing levels of pressure require an increase in viscosity in order to maintain proper lubrication. Thicker oil will have higher film strength than thinner oil, and therefore withstand extreme pressure and heat better. This is why racing engines which see extremely high temps and pressures will use very high oil weights. For a street driven car, however, too thick of an oil will create more drag in the engine and can cost you horsepower and fuel efficiency. The general rule of thumb is to use as thin an oil as possible that still offers good protection from engine wear. Nissan recommends nothing thinner than a 30 weight and nothing thicker than 40 weight oil. The only way to be sure if higher viscosity oil is needed to protect your engine for the way you drive, is with a UOA.
Click the image to open in full size.
__________________
Old 02-17-2010, 06:18 PM   #14
Maxima.org Sponsor and Donating Maxima.org Member
Points: 12,714, Level: 73
Points: 12,714, Level: 73 Points: 12,714, Level: 73 Points: 12,714, Level: 73
Activity: 9.7%
Activity: 9.7% Activity: 9.7% Activity: 9.7%
Engineering is a compromise, and OEMs make oil recommendations which balance between optimal wear protection, fuel efficiency, emissions, and other factors. Like others have said, Nissan lists 5w-30 as the "preferred" viscosity for any temperature, but 10w-40 is also listed as an acceptable alternative if temps don't fall below zero deg F.
If you are concerned about wear protection, using a 10w-40 will not only provide a slightly higher film strength, but another consideration is that the API does not limit ZDDP additives in 10w-40 as it does for the lighter viscosities. You mentioned the AMSOIL on-line reference guide in one of your posts, and their 10w-40 premium protection oil is a high-zinc formula for outstanding wear protection. You may know this but the API has put limits on the amount of ZDDP contained in SM rated oils (generally speaking 10w-30 and lighter) as they have concluded that zinc can shorten the life of emission control systems...some people question it, but that's the logic.
I personally use AMSOIL 0w-30...its very efficient, yet it provides excellent wear protection while meeting API SM zinc limits.
talkinghorse is offline   Reply With Quote
Old 02-17-2010, 08:09 PM   #15
Activity: 0.8%
I didn't realize the API made that exception with the higher weights I'll have to look into that. The EPA has mandated that the use of Zinc dialkydithophosphate (ZDDP) for the most part be eliminated from use in automotive motor oils due to the harmful effects on automotive emissions control systems. American Petroleum Institute (API) approved motor oils currently contain less than one tenth of a percent of ZDDP.
__________________
Old 02-20-2010, 03:53 PM   #16
Activity: 2.7%
I guess I'll neither try GC 0w30 change at 5,000 , 10w30 penzoil ultra, or 10w30 penzoil platiumn oil n changed all oil 5,000 or 5 month.
Old 02-20-2010, 03:56 PM   #17
Activity: 2.7%
What'll happen if I put 10w40 of Amsoil into my engine while running nos? n do inteval 10,000 mile or 1 year whichever come first.
Old 02-20-2010, 04:39 PM   #18
Activity: 9.7%
I believe this would be an excellent oil for your application, but AMSOIL does not make extended drain recommendations for modded engines. You would probably have to rely on the results of UOA to determine the maximum service interval.
Old 02-21-2010, 02:33 AM   #19
Activity: 0.8%
I would never recommend an extended OCI for an engine running NOS no matter what type/weight of oil....
__________________
Old 02-21-2010, 01:24 PM   #20
Activity: 2.7%
Will i guess Ill used 10w40 Amsoil oil for my car but I might be spraying 5-10 time year. So I think I be okay to change at every 10,000 or year.
Old 03-07-2010, 12:17 PM   #21
Points: 5,106, Level: 45
Points: 5,106, Level: 45 Points: 5,106, Level: 45 Points: 5,106, Level: 45
Activity: 0%
Quote:
huh? What temp is your porsche termostat spec'd at?
Higher viscosity is for clearance in specific motor as much as race/street use. Porsches get driven harder in general so they burn more as well.
__________________
LTB stage II, Progress RSB, FSTB, Poly bushings, Progress/Illumina, 6th gen brakes, Forged SE-R rims KDW bfg, T1R and OBX headers
NisTech is offline   Reply With Quote
Old 03-07-2010, 01:14 PM   #22
Points: 2,120, Level: 27
Points: 2,120, Level: 27 Points: 2,120, Level: 27 Points: 2,120, Level: 27
Activity: 0%
Send a message via Skype™ to SiathLinux
That's all good and great (reading through all those nicely detailed postings, with various charts and such...
Those of us that live in Florida - we use 20W50 - and if you look at that nice chart put up by MaxLoverAz you'll see that the temp chart shows why, as we get very few truly cold days here, and almost never dip below 20F. I've used it in Every car I've owned here. The only vehicle that I didn't use it in was an 88 F150, I use Castrol Syntec in that.
__________________
http://forums.maxima.org/maxus/61991...ouncement.html
Maxus 2011 web site coming soon.
SiathLinux is offline   Reply With Quote
Old 03-07-2010, 01:29 PM   #23
Activity: 0.8%
Funny here in AZ 20W50 was used back in the 80's but with the advent of technology in motor oil formulations I don't know of any that use 20W50 because of the temperature and I believe we get a tad bit hotter than you. Thicker oil can be better for older engines in which engine parts have worn over the years but not in newer modern engines we have today.
__________________
Old 03-20-2010, 07:20 AM   #24
Quote:
20w50 is way to thick your engine will not be lubricated fully with that oil its to thick 5w30 is the best there is a reason why the manufacturer recommends that weight oil (5w30) if you use a real thick oil you engine has a good chance that certain parts will not receive the oil due to its thickness,thicker is not better unless you have and air cooled engine or you have tons of miles where your car is burning oil than you should use the thicker oil. You wont go wrong with 5w30!!! Did you ever here the saying if its not broke don't fix it?
Old 03-20-2010, 10:54 AM   #25
Activity: 0.8%
Quote:
Yes I agree if you had read that was a my response to another member in FL using 20w50 in FL which I think is nuts. I run 0w30 even better cold start protection but warms up to a nice 30 weight.
__________________
Old 03-21-2010, 10:51 AM   #26
Points: 12,776, Level: 73
Points: 12,776, Level: 73 Points: 12,776, Level: 73 Points: 12,776, Level: 73
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
I have been using Esso Extra XD-3 0w-30 full synthetic for almost 5 years with good results. It is a fraction of the cost of Mobil 1 and is a heck of a lot cheaper. According to BITOG it achieves better UOA results than Mobil 1. In the past it hasn't been available in the US, but perhaps it is now. I think 0 - 40 was available before at WalMart.
Bobo is offline   Reply With Quote
Old 03-21-2010, 11:20 AM   #27
Activity: 0%
MaxLoverAz "As a rule, overhead cam (OHC) engines typically require thinner oils such as 5W-30 or 5W-20 to speed lubrication of the overhead cam(s) and valve-train when the engine is first started. Pushrod engines, by comparison, typically specify 5W-30, 10W-30 or 10W-40. As mileage adds up and internal engine wear increases bearing clearances, it may be wise to switch to a slightly higher viscosity rating to prolong engine life, reduce noise and oil consumption. For example, if an engine originally factory-filled with 5W-30 now has 90,000 miles on it, switching to a 10W-30 oil may provide better lubrication and protection. The thicker oil will maintain the strength of the oil film in the bearings better so the engine will have more oil pressure. This will also reduce engine noise and reduced bearing fatigue (which can lead to bearing failure in
engines).
For sustained high temperature, high load operation, an even heavier oil may be used in some situations. Some racing engines use 20W-50, but this would only be recommended for an engine with increased bearing clearances. Increasing the viscosity of the oil also increases drag and friction, which can sap horsepower from the That's why 20W-50 racing oil would not be the best choice for everyday driving or cold weather operation for most vehicles. The latest trend in racing is to run tighter bearing clearances and use thinner oils such as 0W-20, 0W-30, 5W-20 or 5W-30 to reduce friction and drag."
I may not be as 'CRAZY' as you think - it's not just hot here, it's also humid, whole new ballgame compared to Arizona (nice place to live by the way - been through it a few times).
If I lived in the dry desert of AZ, I'd would probably use the thinner oils. Also, it does get MUCH colder in AZ than it does here in Central Florida, so you do need the lower starting temp rated oils.
In the years (21 of them) that I've lived in Florida, the average Winter is less than two weeks, and only in two of those years did the temp get below 20F, and rarely got below 30F... research before you 'name call'
KTHXBYE
__________________
Old 03-29-2010, 09:22 PM   #28
Points: 7,717, Level: 58
Points: 7,717, Level: 58 Points: 7,717, Level: 58 Points: 7,717, Level: 58
Activity: 0%
Send a message via MSN to CraigSE
Quote:
XD-3 is such a sleeper oil. That stuff gets such stellar UOA last time I saw one (a while ago)
I should still probably try that someday. I have an Esso bulk dealer not too far from me.
__________________
2002 Maxima SE 6MT w/LSD - SOLD
KT3 Silver. Black leather. Meridian.
Previous:
2002 Altima SE 5MT
QX3 White. Black leather. Loaded minus HID.
CraigSE is offline   Reply With Quote
Old 04-08-2010, 02:49 PM   #29
This thread had some extremely informative and interesting posts. I think I have a much firmer grasp of oil selection now, thumbsup!
But, it doesn't change my habits at all, use what the manual says, then if it's high mileage switch to 5w30 if I'm not already using it so it doesn't have to work so hard.
Negafen is offline   Reply With Quote
Old 04-11-2010, 04:59 PM   #30
Activity: 2.7%
Ok guy I put mobil one 0w40 oil in my vq35DE n I put her less than 600 miles on it. But I'm not getting good gas mileage. Anybody know y or should I change it to 5w30 oil?
Old 04-16-2010, 07:31 PM   #31
Activity: 0.8%
You'll get better mileage with 0W30, and 5W30.
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
