Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-18-2009, 07:00 PM   #1
Send a message via AIM to Kevin319
5w-20, what happens?
Walked in Pepboys without my glasses and accidentally bought the Castrol High Mileage 5w-20. I did not realize until I was filling in the used bucket of dirty oil back into the quarts. What should I do now? Should I change the oil again or am I good? Will there be a drop in performance or gas mileage? It's driving me crazy how I didn't notice I bought the wrong oil for my baby
Kevin319 is offline   Reply With Quote
Old 10-18-2009, 09:32 PM   #2
It might not lubricate enough, like people use super low weight oils to flush their engines because when you get up to high RPM it won't lubricate fast enough and that cause problems.
I am not sure about 20W though, its quite close to 30 but I am having mixed feelings. I think its okay for a few days or weeks but once you start to shred that oil it'll drop down into the 18s and 17s then it would be bad.
__________________
1997 Nissan Maxima GLE
Leo_Koneval is offline   Reply With Quote
Old 10-19-2009, 04:46 PM   #3
Thanks for the quick reply. So as long as I drive under 4rpm I am good to go? I drove the car to and from work and it felt the same.
Old 10-19-2009, 05:02 PM   #4
It's factory fill for lots of cars now.
Just drive the car.
__________________
LTB II, CAI, H&R, Illuminas, ES shifter, subframe, engine mounts, sway bar bushes, Megan OE-RE, Watkins STS.
SteveB123 is offline   Reply With Quote
Old 10-20-2009, 07:01 AM   #5
Maxima.org Sponsor and Donating Maxima.org Member
Recommend you change it. 20 weight is not recommended by Nissan and it might not provide the film strength needed to prevent metal to metal contact (wear) within your engine when it gets hot and/or under stress. While other manufacturers are indeed recommending 20-weight oils, the engines they recommend it for have very close tolerances and are designed to run on that viscosity oil.
talkinghorse is offline   Reply With Quote
Old 10-20-2009, 05:03 PM   #6
Thanks for your input talkinghorse. Will definitely change the oil again once this weekend comes.
Old 10-20-2009, 05:21 PM   #7
Crusher103's Avatar
Send a message via AIM to Crusher103
I honestly woundnt worry about it, as long as u are not driving a 3.5 with oil consumption issues then u should be fine.
__________________
96 Black I30t VLSD 5spd A.K.A Big Black(has a bad attitude)
Eibach springs//Koni yellows//Koyo OE Radiator//F&RSTB//Black retro'd Cefiros w/E46 Bi-Xenon projectors/ZKW clear lense'd//Budget y-pipe//test pipe//Apexi WS2//WAI//Grounding kit
3.5 in progress
CLICK ME FOR WHEELS FOR SALE AND TIRES FOR CHEAP
Crusher103 is offline   Reply With Quote
Old 10-21-2009, 03:30 PM   #8
Haha I came up with a good analogy for oil!
Lets say that you are washing your hands and what do you use? Water right? Since its really low weight (Maybe 0W?) It cleans good. But if you use something like cooking oil to clean your hands the oil will stick to your hands because its heavier.
In engines, that only thing I can think of is when you rub your hands together really fast to warm your cold hands or whatever and if you were going to use lubricant something really low in weight like water, then all of it is going to splash off, but if you use something like grease it'll lube your hand no matter how fast you go.
Sorry completely unrelated but I wanted to share hahahah
__________________
Old 10-21-2009, 03:32 PM   #9
Quote:
Water is heavier than oil.
__________________
Old 10-21-2009, 09:27 PM   #10
Alright I guess I will keep the oil until my next oil change. Although I do feel uneasy about the lighter vs heavier oil thing.
Old 10-21-2009, 10:06 PM   #11
Send a message via MSN to lalaMAX
drive it for 6000km then dump it...
forget about the blah blah blah... VQ is bulletproof
lalaMAX is offline   Reply With Quote
Old 10-22-2009, 06:28 AM   #12
kgallerie's Avatar
If it was my car, I would change it. Like talkinghorse said, the car is not meant to run on that oil. I would gladly spend the $15 or whatever is costs to replace the oil than to take the chance of damaging the engine.
If you want to justify changing the oil so soon, you could consider it as an oil flush
kgallerie is offline   Reply With Quote
Old 11-04-2009, 08:00 PM   #13
Super Moderator
Send a message via AIM to nismology
I'd dump it and just take it as a lesson learned.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 11-04-2009, 10:06 PM   #14
I wouldn't dump it. It isn't THAT thin, and it is getting colder outside...which is better for thinner oil. There are people that swear by 0w-20 in cars just like the Max.
__________________
Black 04 Maxima SE 5AT
MaxEx is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
