Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-28-2009, 12:25 AM   #1
Send a message via AIM to shadyonedeath
Oil Cleanup - How do you clean your Oil change materials?
Ive been wondering after a few oil changes what the best "eco friendly" method is to clean my oil change materials such as the oil pan, rags, funnel, etc. Specifically things that have oil residue remaining.
In the past, i have a area of my year full of gravel, i just rinse everything off in there. But i feel like its still bad to do it regardless if anything grows there, oil seeps through...
Any ideas?
__________________
Paying a man to work on your car is like paying another man to sleep with your wife.
-Hank Hill
99 SE-L - 00vi - Y/E
shadyonedeath is offline   Reply With Quote
Old 08-28-2009, 10:49 AM   #2
Send a message via AIM to Revo75 Send a message via MSN to Revo75
I'd like to know too!
Revo75 is offline   Reply With Quote
Old 08-28-2009, 04:58 PM   #3
Not a GM sack rider...
Honestly, beyond recycling the oil what else can you do? Seems no matter what, as long as you dispose of the materials yourself and not take them to someone who recycles them, it's all the same thing...
__________________
1996 5spd w/DE-K/HotShot headers/Apexi WS
JWT Short Ram/VAFC2
KYB AGX/Eibach SportLine/97+ front end...
Quote:
Originally Posted by nismology View Post
You can subscribe to a thread without posting.
DAVE Sz is offline   Reply With Quote
Old 08-30-2009, 12:15 AM   #4
As long as you dispose of the volume of used oil properly, that's the best you can do from an environmental standpoint.
I thought this thread involved cleaning up the used motor oil that spills in the garage or on the driveway. This is particularly needed on concrete pavement -- the oil is not so visable on black top pavement. I have two answers for cleaning that spill after you have used a paper towel to wipe up as much as possible of this spilled oil:
- Use a good grade of paste hand cleaner (like Goop) and rub it in well into the oil spot on the pavement (do not wet the pavement first). Allow it to do its work for a few minutes and then hose it off with water -- the faster the water flow the better. Allow the area to thoroughly dry. If there is any remaining oil on the pavement, repeat the above steps again.
- For really tough (or old dried-on oil spots) use a can of starting fluid (ether). Spray the starting fluid on the oil spot and immediately begin rubbing the area with a cloth. Be certain there is ample ventilation so that you are not affected by the ether. Repeat this step as many times as needed to remove the spot.
__________________
SilverMax_04 is offline   Reply With Quote
Old 08-30-2009, 01:53 PM   #5
if you mean how to clean funnels and crap like that
well= atf fluid funnels i throw out because i want those to be fresh and clean
oil change funnels= i usually just leave them on top of the milk jug and let it drain all the way out and then wipe it down with a few paper towels and toss those.
my oil pan i dont really change because no reason for it to be clean it just collects dirty oil. i just drain, shut closed and wait another 5 months. if you have one of those that don't close (open ones) you probably can just keep up the draining, and i think autozone has like some powder that absorbs motor oil
Col Ronson is offline   Reply With Quote
Old 09-24-2009, 03:33 PM   #6
Just wanted to add, I used to clean the oil catch basin with a rag before putting it away. But for a while now I've been using a catch basin with a neck on it to empty it out, I'm able to position the basin vertically so that it gravity feeds into a can. I let it sit for a few hours and its basically perfectly empty, and there is no need to wipe it with a rag. Definitely makes a difference.
__________________
FS: VE TB for auto
FS: VE lower intake manifold
eric93SE is offline   Reply With Quote
Old 09-26-2009, 02:14 AM   #7
pans and funnels, i just wipe them off with a clean cloth and let it drizzel off the remaining oil to a jug.
oil spots, i usually put some cardboard on the pavement while performing the change. if oil gets on the gravel, use lift sand to avoid spots.
oldsnail is offline   Reply With Quote
Old 09-29-2009, 09:23 AM   #8
This is a great answer. Worked in automotive service for 5 years.
side is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
