Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-07-2009, 09:40 PM   #1
Send a message via AIM to xkazik
First Mobil 1 5W-30 synthetic oil change
Well its time to change my oil in my 1999 max i just bough and the previous owner told me he used synthetic Mobil 1 5W-30, so i decided to put same oil in, my only guest ion is what oil filter should i use ? is there special kind for synthetic oil ? and how many bottles of Mobil 1 5W-30 will i need ?
xkazik is offline   Reply With Quote
Old 06-07-2009, 09:48 PM   #2
use a nissan filter... car takes 4.25 quarts.... fixed
__________________
f550maranello2 is offline   Reply With Quote
Old 06-07-2009, 10:01 PM   #3
4.5 quarters is much....if you're gonna replace the filter only 4 quarters are enough
mahanddeem is offline   Reply With Quote
Old 06-07-2009, 10:23 PM   #4
Send a message via AIM to Reece616
Quote:
actually, im pretty sure the owners manual says that with an oil change and replacing the filter, that 4.25 quarts is needed...
__________________
Reece616 is offline   Reply With Quote
Old 06-07-2009, 10:29 PM   #5
Quote:
yea i forgot to put the 2 in front of the 5...
__________________
Old 06-07-2009, 11:10 PM   #6
Walmart has mobil1 5qt jugs for ~$22 and I attached a current $10 mobil1 rebate
http://uploading.com/files/Q5G4VVKQ/mobil1.pdf.html
haydeno is offline   Reply With Quote
Old 06-07-2009, 11:20 PM   #7
Is synthetic oil really needed for the higher mileage VQ30 engines ?
I dont know alot about max's so im asking here.
defiance is offline   Reply With Quote
Old 06-07-2009, 11:32 PM   #8
waste of money if you ask me... i stopped using it cuz it made my semi leaking rear valve cover leak like a mofo...
__________________
Old 06-08-2009, 12:12 AM   #9
The Dirty Pearl
pmohr's Avatar
It doesn't matter.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 06-08-2009, 01:02 AM   #10
Why are talking about oils and filters again? I personally have posted in many other threads with the same questions.
__________________
Proud 4th Gen Owner!
djipka is offline   Reply With Quote
Old 06-08-2009, 07:15 AM   #11
One more question , how many miles can i put on the synthetic oil before changing it? Whats the average people change it on?
Old 06-08-2009, 07:17 AM   #12
The Dirty Pearl
pmohr's Avatar
Quote:
Have you considered actually reading through the subforum that's designed for these questions?
They've been asked time and again, and all it takes is a little reading...
__________________
Old 06-08-2009, 07:48 AM   #13
The Golden One
IlyaK's Avatar
aka 5,000 miles.
hahaha.
IlyaK is offline   Reply With Quote
Old 06-08-2009, 01:06 PM   #14
Quote:
4.25 quarters is much....if you're gonna replace the filter only 4 quarters are enough
4-5/8 quarts (w/filter) per the FSM
allensteiner21 is offline   Reply With Quote
Old 06-08-2009, 01:13 PM   #15
The Dirty Pearl
pmohr's Avatar
Quote:
FTR, only the '95 FSM shows 4 5/8. '96-'08 show the above (well, 4.2 for '05-'08, but same thing).
'09 is up to 4 7/8 quarts, interesting.
__________________
Old 06-09-2009, 08:34 AM   #16
this is crazy. 95/9 is the same motor but the fsms have different info between years - just like the cold/hot plug use description
Old 06-14-2009, 01:06 PM   #17
Send a message via AIM to JAMAICANLOVRBOY Send a message via Yahoo to JAMAICANLOVRBOY
i seem to be the only one that cant use 5W-30 oil, or my engine will make a ticking sound until i switch to 10W-30
__________________
98 gxse, de-k swap, vlsd, apexi II, I/H/E, stillen kit, NEX coilovers
http://boredmder.com/ecucodes/index.php?year=
http://forums.maxima.org/general-max...niti-fsms.html
JAMAICANLOVRBOY is offline   Reply With Quote
Old 06-20-2009, 01:36 AM   #18
SuPeRmOd
NismoMax80's Avatar
depends. my manual states 4.25 as well.
BUT i always require 4.5 to get it to the full line on the dipstick.
I even fill the filter and let it soak in. you'll be surprised how much you can fit in it.
__________________
NismoMax80 is offline   Reply With Quote
Old 06-20-2009, 01:38 AM   #19
SuPeRmOd
NismoMax80's Avatar
you understand this is because the synthetic cleans away the crud that hid your leak right?
synthetic isn't the problem, it simply showed you the problem.
__________________
Old 07-02-2009, 07:39 PM   #20
I just dump in 4.0q each time I change the oil & filter. This fills it to between 3/4 and Full on the dipstick.
As a side note, FWIW, I've had a 10W-30 fill of Pennz Plat Syn w/ M1-110 filter since 12/2007. It now has only ~3000 miles on the oil. This car has been mostly in storage. This is why I haven't changed it out yet. Will probably change it out at 2 years.
So far 19+ months...oh the humanity!
Sleeping very well at night, and the sun will still rise w/ that old oil in there..
A33Black is offline   Reply With Quote
Old 07-09-2009, 11:39 AM   #21
MaxLoverAz's Avatar
Thank god for rust inhibitors...
__________________
09 Maxima SV, Winter Frost
09 370Z, Chicane Yellow, and yes it's a manual!
http://www.youtube.com/watch?v=ELiAo...eature=related
http://www.youtube.com/watch?v=E2fvT...eature=related
MaxLoverAz is offline   Reply With Quote
Old 07-11-2009, 01:09 PM   #22
Don't use a nissan OEM filter. That's just a Fram in disguise. I've seen many teardowns online just go to google and type in Mobil 1 vs Nissan OEM filter teardown. If you use mobil 1 oil, use mobil 1 oil filters too.
Col Ronson is offline   Reply With Quote
Old 07-14-2009, 10:07 AM   #23
ME RWD FTW!
Colonel's Avatar
Send a message via MSN to Colonel
Quote:
No, use Mobil1 filters because its a better filter. Not just because you are using Mobil1 oil. They are mutually exclusive and are not tied to each other.
It is nice that several auto supply places around here bundle Syn Oils with Mobil1 filters like Penz, Mobil1 and Castrol. Couple bucks off per quart and a "free" filter.
__________________
2001 Maxima SE VQ30DE-K (5 Spd)
1991 MR2 3S-GTE (Gen III, 5 Spd)
2007 Rav 4 2AZ-FE (Auto )
Colonel is offline   Reply With Quote
Old 07-30-2009, 10:32 PM   #24
Another vote for the mobil 1 filter. I started buying them because they have the check valve that keeps the oil from draining after you turnoff the engine. Thjis ensure oil will be in the engine at start.
I've been told the Mobil 1 is specially designed for synthetic oils, but I don't know if that's just manufacturer's hype.
eluther3 is offline   Reply With Quote
Old 07-30-2009, 10:33 PM   #25
p.s. regarding oil change interval - I shoot for 5K on each oil change, but usually I look at the oil around that time and if it's not dirty, I might drive another 1-2K on it.
Old 08-01-2009, 08:24 PM   #26
well you can use it with any oil you want. i use it because although expensive, its the best filter out there, although the amsoil drones will argue theirs is better. it has synthetic filter material instead of plain paper, so supposedly there are smaller fibers that allow for more filtering area. so less sludge floating around your engine. i immediately saw a difference in the oil drains from my dyno drain to my syn drain 4000 miles later.
Old 08-05-2009, 11:16 AM   #27
ME RWD FTW!
Colonel's Avatar
Oh, what was it that you visually noted?
__________________
Old 08-07-2009, 09:23 PM   #28
For both my 95 and 2001 Maximas, I simply poured an entire jug of Mobil 1 synthetic in (5 qts). I know they took a little less according to the manuals, but a little extra oil never caused a problem...
dandjjohnson is offline   Reply With Quote
Old 08-07-2009, 09:24 PM   #29
Ohhh, and any filter other than FRAM seems to work fine...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
