Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Sign in using an external account
Register Forgot Password?
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
View Poll Results: Better MPGs With Summer Blend?
No Change in MPGs 3 21.43%
Slight Increse less than 10% 6 42.86%
Increse of 10% + 4 28.57%
I Don't Calculate my MPGs 1 7.14%
Voters: 14. You may not vote on this poll
Thread Tools Search this Thread Display Modes
Old 05-12-2009, 05:19 PM   #1
Points: 4,675, Level: 43
Points: 4,675, Level: 43 Points: 4,675, Level: 43 Points: 4,675, Level: 43
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
X 10soft2hard X
Summer Gas Blend & Better MPGs
Now that we should all be getting the summer gas blend I was curious if people are getting better MPGs. I've noticed over the last 4 tanks about a 10% increase over what I got durring the winter months. I know there are a lot of variables involved here but I know once the winter blend came out my MPGs dropped noticably. So am I crazy or am correct to think that the max likes the summer blend or maby just the warmer weather?
__________________
| 04 6MT | BC Coilovers Berk HFCs X02 Exhaust Z-Tube Roof Overlay 40% Tint LED Int./Ext Motordyne Spacer 19" Five: AD S5:F w/ 245/35 & 275/35
Get Your Shine On!!!
johnnyd2k2 is offline   Reply With Quote
Old 05-13-2009, 09:36 AM   #2
Points: 3,426, Level: 36
Points: 3,426, Level: 36 Points: 3,426, Level: 36 Points: 3,426, Level: 36
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
What is a Winter Blend? I'm from FL, is this a northerner thing?
MadMax07SL is offline   Reply With Quote
Old 05-13-2009, 12:04 PM   #3
SuPeRmOd
NismoMax80's Avatar
Points: 17,010, Level: 83
Points: 17,010, Level: 83 Points: 17,010, Level: 83 Points: 17,010, Level: 83
Activity: 3.3%
Activity: 3.3% Activity: 3.3% Activity: 3.3%
what blend?
warmer air temps provide higher MPG. i thought that ethanol was 10% pretty much all around now. heard "they" were pushing to increase it though
__________________
Tint in PA look up Jason at http://www.accenttint.com/
NismoMax80 is offline   Reply With Quote
Old 05-13-2009, 02:40 PM   #4
Points: 4,331, Level: 41
Points: 4,331, Level: 41 Points: 4,331, Level: 41 Points: 4,331, Level: 41
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Maybe to shine a little light in here...maybe not
Quote:
The term "summer blend" is shorthand for a menu of federally and locally mandated summertime fuel recipes that are designed to cut down on smog. The gasoline we use is always refined from an intricate blend of ingredients; the process combines coffee-dark crude oil with various additives that increase performance or make fuel burn more cleanly. Because overlapping federal and local requirements call for different recipes in different locales and seasons, there are approximately 20 distinct "boutique blends" of gasoline sold in the United States. Some Americans end up pumping a blend called Carb (named for the California Air Resources Board) while others burn Atlanta (named for Georgia's capital, where it's sold).
Refineries brew their summer blends by removing hydrocarbons that are more prone to evaporate in hot weather. These chemicals, called volatile organic compounds, react with airborne pollutants in the summer sun to form ozone, one of the main components of smog. From June 1 to Sept. 15, the EPA mandates that pumps in 12 high-ozone urban areas—such as Los Angeles, New York City, and Baton Rouge—deliver gasoline that meets special low-evaporation standards. Several states have voluntarily adopted the rules, and 15 have enacted their own seasonal-blend regulations on top of the EPA's. For example, pollution-conscious California has mandated that service stations must start selling its summer blend in May.
Summer-blend gas isn't new. It was first sold in 1995, as required by the Clean Air Act's 1990 amendments, and the current, even cleaner, concoction was phased in for the summer of 2000. Since then, there have been sharp spikes in fuel prices every spring as summer blends get rolled out. This is not so much because it's expensive to make the gas—the added cost per gallon is only 1 or 2 cents—but because refineries generally try to sell every last bit of winter fuel before mixing in the slightly more expensive summer batch. Sometimes they draw down the stock too far, creating shortages before the first deliveries of summer blend enter the supply chain. The return to normal blends in the fall causes a far less pronounced spike because the industry, free from summer standards, doesn't bother selling off the summer gas before mixing in the less pricey stuff.
So why not use the summer blend year-round? The main reason—apart from the fact that the 1990 law isn't written that way—is that summer-blend gas doesn't work as well in the winter. Summer blend's low-evaporation rate makes engines less likely to stall in hot weather but can make them difficult to start in the cold.
i learned something...and thats why i hang out here
__________________
'01 GLE Pearl White|Stillen Strut Bar|GAB2|Rotora Drilled&Slotted Rotors|Hawk HPS Pads|Cooper Zeons|Angel Eye Fogs
'02 SE Sterling Mist|Nokya Hyper Yellow Fogs|Orion V2's|GAB2|Vibrant FSTB|Progress Springs|Illuminas|EBC Slotted Rotors|Hawk HPS Pads
nissandrvr98 is offline   Reply With Quote
Old 05-13-2009, 02:46 PM   #5
Send a message via AIM to xWasX08 Send a message via Yahoo to xWasX08
Im noticing more MPGs 2... I live here in MA and the winter MPGs suck.. at least for me. Summer for gas is great, although theres a hike in prices. Theres always a plus/negative side.
And +1. ^ Ever since I joined this site and even before (browsed as a guest for a LONG time.) Ive learned so much about cars in general and also my Max. Love it.
__________________
2000 Black Nissan Maxima GLE
- Current Mods -
|Injen CAI | Bosch Platinum Spark Plugs | 20% Window Tint |
- Upcoming Mods -
| 18" DBL G 505 Black Rims | Cattman 2.5" Exhaust | Yellow 3000K Fogs | MagnaFlow Y Pipe | 6000K Headlights | 2" Drop Springs |
xWasX08 is offline   Reply With Quote
Old 05-30-2009, 06:03 PM   #6
SuPeRmOd
NismoMax80's Avatar
Activity: 3.3%
I just spent half an hour cleaning my stuffed K&N filter... hope that helps a little
__________________
Old 06-10-2009, 01:05 AM   #7
Points: 9,339, Level: 64
Points: 9,339, Level: 64 Points: 9,339, Level: 64 Points: 9,339, Level: 64
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
The information in the 4th post seems to be reasonably accurate, but not complete. I worked in the oil industry for 35 years before retiring in 1998. Points I would make:
- The posting implies that "coffed-dark crude" is blended with additives. In fact, the crude is first refined into hydrocarbon components and these different components are then blended with additieves to meet a range of different specifications - in addition to volitility. Also, not all crude oil is "coffed-dark" - it comes in all different shades from "cow-piss" yellow to black.
- There were winter and summer grades of gasoline before the law was passed in 1990 (or so). Before the law, oil companies worked to make the cheapest gasoline without having customers with vapor lock (which occurs with carburators and winter grade gasoline on a warm day).
- It is cheaper to make winter grade gasoline because it is possible to blend more butane into the fuel than you can in the summer, when you essentially can not use any Butane in gasoline. Butane is relatively cheap and has good octane properties. It also greatly helps an engine start when the temperature is 10 degrees below zero.
- I believe there are more than 20 different mandated gasoline blends across the USA in the summer time. One reason the prices get so high - too many politicians getting into the act and making production of gasoline more difficult and expensive with all of the slightly different specifications by political district.
- I suspect, but can't prove, that it costs more than 1 to 2 cents more per gallon to make summer grade versus winter grade gasoline.
Hope this helps clarify some to the points in post # 4.
__________________
SilverMax_04 is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Contact Us - Maxima Forums - Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
