Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-15-2009, 08:07 PM   #1
Send a message via AIM to brandnew Send a message via Yahoo to brandnew
NEED a simple answer??
my 4th gen has 160k on it and i wanted to know what is the best oil to start using for my oil changes plain and simple... i dont really know about it so average joe terms would be appreciated!! thanks in advance!
__________________
IMG]http://img.photobucket.com/albums/v608/Aaronhl/avatarchris.jpg[/IMG]
brandnew is offline   Reply With Quote
Old 04-16-2009, 06:39 AM   #2
ne1?
__________________
Old 04-16-2009, 08:02 AM   #3
JwaxMax99's Avatar
Simple answer? Grab some Penzoil Platinum and a Purolator Pure One filter.
__________________
NO, my car does not burn a drop of oil, and after 5K the oil still LOOKS clean!
JwaxMax99 is offline   Reply With Quote
Old 04-16-2009, 01:19 PM   #4
Thanks for the help
__________________
Old 04-17-2009, 06:34 AM   #5
kgallerie's Avatar
Quote:
I agree that PP is a great oil....I use it myself.
But it really depends on what you have been running in it. I have heard many times that if you switch to synthetic with that many miles, things can start leaking because the synthetic runs a bit less viscous (thinner) than conventional.
So for the simple answer you were looking for, if you have been running synthetic, Pennzoil Platinum. If you have been using conventional oil, Castrol GTX.
kgallerie is offline   Reply With Quote
Old 04-17-2009, 01:39 PM   #6
Maxima.org Sponsor and Donating Maxima.org Member
Quote:
Leaks can sometimes occur, but not for the reason you state. Oil thickness is measured against an industry-wide standard. An oil rated as a 30-weight will fall within the thickness range of a 30-weight regardless of whether it is synthetic or petroleum-based.
If one were to introduce synthetics to a high mileage engine that had been neglected up to that point, the superior detergency of the synthetic oil could dissolve deposits left behind by the petroleum oil and potentially leak through defective gaskets, previously sealed by the deposits. Along those lines, the increased detergency of the synthetic oil could cause it to become contaminated quicker than normal if introduced to a "dirty" engine and result in increased oil consumption.
With that said, Nissan engines are typically not prone to sludge. I've change many high mileage engines over to synthetics without issue. If you do decide to go with synthetics, check the oil regularly and change it if consumption increases...increased consumption is a sign that the oil is becoming dirty/contaminated.
talkinghorse is offline   Reply With Quote
Old 04-17-2009, 03:09 PM   #7
kgallerie's Avatar
I stand corrected.....thanks Ed.
Old 04-22-2009, 12:40 PM   #8
If you dont like the price of full-syn, then at least use the syn-blend. It's usually only like 50 cents more a quart.
__________________
Oh.... just browsing. Thanks.
firebirdude is offline   Reply With Quote
Old 05-21-2009, 02:25 PM   #9
Pennzoil Platinum or Mobil 1 fully synthetic. After spending sometime looking at some previous posts, these 2 were the most recommended.
RaikkaF1 is offline   Reply With Quote
Old 06-04-2009, 07:23 PM   #10
Send a message via AIM to FRZ251
Eneos Synthetics.
FRZ251 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
