Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-01-2009, 08:42 PM   #1
Send a message via AIM to Y2k2maxse
diff. oil visc for a 3.5 that burns oil?
using 5w30 synthetic...would it be logical to use 10w30 to possibly slow the oil usage?? its not leaking on the floor...just burning i believe. 133,000 miles... i use the larger oil filter always..change the oil every 6k..add a few quarts in between
__________________
00 Sterling Mist SE 5MT (14.9 1/4) --- Sold @ 118K
02 Sterling Mist SE Meridian ed. 4AT (14.76 1/4) --- Traded @ 88K
04 Liq Silver SE 6MT --- LOVIN IT
Berk Intake, Progress springs+KYB GR2's, tints, tail tints, 6K HIDs, Mobil1 syn., painted calipers, debadged, 6MT , driver preferred package, new rebuilt trans
Y2k2maxse is offline   Reply With Quote
Old 04-02-2009, 03:52 AM   #2
Yeah, you can do that but you are better of finding out where you are losing oil. Also, you might have to switch back to 5w30 when winter comes since you are in NJ.
Also, I am not sure why you are changing the oil @ 6k....I change mine every 3K. I change every 3K not because the oil breaks down, but because particles get into the engine through the air intake. If you don't get rid of them by changing the oil, then they cause microscopic damage which increases the tolerances between the parts in your engine. This might be why you are losing so much oil.....
Terrentius is offline   Reply With Quote
Old 04-02-2009, 05:15 AM   #3
GrandPa
ramberg's Avatar
As stated above I would check to find out why you are the burning that much oil. Are you adding oil within the 3,000 miles or after? I use Royal Purple oil and their filter. I change my oil every 3,000 miles even though its synthetic. I also have over 100,000 miles on my car.
__________________
Custom made by ChinoX
ramberg is offline   Reply With Quote
Old 04-02-2009, 05:49 AM   #4
Send a message via AIM to JAMAICANLOVRBOY Send a message via Yahoo to JAMAICANLOVRBOY
hmmmm, well the 3.5 motors are known for oil burning, might find a selected few who dont have that problem with their 3.5. but ask around and most people will agree that those motors eat oil. i thought u had to use 10w30 oil. i tried 5w30 and my engine had a ticking sound, thought my motor was messed up. so i switched back to 10w30, smooth. try changing your oil more often even though you use syn, like Ram, i use syn oil, but i change every 3k
__________________
98 gxse, de-k swap, vlsd, apexi II, I/H/E, stillen kit, NEX coilovers
http://boredmder.com/ecucodes/index.php?year=
http://forums.maxima.org/general-max...niti-fsms.html
JAMAICANLOVRBOY is offline   Reply With Quote
Old 04-04-2009, 10:23 PM   #5
um well first of all it wont matter even if you used 15W30
the 5W you see is the cold temp viscosity when the engine cranks then when it warms up it goes to being a 30 weight
So if you want a heavier oil you need to look at 5W40 NOT 10W30
Also what kind of oil are you using
Just to point one more fact Mobil 1 is not a true synthetic base its a hydrocracked group III type
Forgot one thing, Why are you changing at 6K?
I change mine before 3K and thats with me using German Castrol [not regular ones you find at autozone] Its made in germany and yes true IV base
Nissan2005 is offline   Reply With Quote
Old 04-04-2009, 11:07 PM   #6
Send a message via Yahoo to po8pimp
I had the same issue. Now I use Mobile 1 0w40 no more burning of oil as of yet. The vq35de is known for this issue and well changing the weight won't fix the problem just temp ease your mind a bit knowing you won't run out of oil as fast. Also like the guy above said doesn't matter if you change to 10w30, the 10 is for weather and the 30 is for weight. 10 is used in warm/ hot climates. 5 is for colder climates and 0 is for freezing climates. all have a temp range. 0 has the best range. Also the manual says you can use 5w30, 10w30 and Nissan service rep told me to try a heavier weight oil and see if it stops the burning.
__________________
po8pimp is offline   Reply With Quote
Old 04-05-2009, 09:24 AM   #7
I use GC and change my oil every 5k, my used oil analysis says my engine is strong
__________________
2009 SV Sport&Tech, Dark Slate
2006 SE Maxima, Onyx (traded)
only FS by sponsors in sigs.
STARR is offline   Reply With Quote
Old 04-05-2009, 10:20 AM   #8
Send a message via AIM to nene503 Send a message via Skype™ to nene503
Which is the German Castrol? Is it the 0W-30? How can you tell it appart from the stuff you buy at Autzone and places like that?
__________________
K&N filter, Stillen FSTB, Progress RSB, Pioneer AVIC-F700BT, JL A6450, Polk speakers, and Daytime running lights (DTRL)
nene503 is offline   Reply With Quote
Old 04-05-2009, 03:31 PM   #9
GC will say on the back
Made in Germany
and in the front it says
European Formula
Old 04-06-2009, 09:40 AM   #10
Quote:
Apart from European Formula on the front and made in Germany on the back, it's 0w30, if you buy 5w30 it's made in the USA
__________________
Old 04-15-2009, 01:03 PM   #11
You're prob. better off trying a high-mileage variant rather than changing the viscosity rating....
I experimented with M1 high mileage variant during one 5k OCI, with limited (less-burning) results.
But - I'm thinking of trying it again. Heck, what do I have to lose?!?!?
I'm STILL burning about 1-1.5 qts every 3k miles or less.
Nissan would NOT help me, but they DID warranty change my rear valve cover due to leaking.
Didn't help.
Compression test was GOOD -- so I'm just gonna dump oil in it until it BLOWS!
...thus the saga continues...
SURE wish I knew where ALL that oil was going to>!!?!?!?!?!?
gr
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 04-16-2009, 11:04 AM   #12
You can't friend yourself
Kevlo911's Avatar
Tell them to do a leak down test
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 04-16-2009, 12:30 PM   #13
Quote:
Yeah - i know...they convinced me that I didn't need one last time.
I have to be honest and say -- the mechanic WAS very honest. Just a kid.
But now I'm thinking that I should have done that.
i still have some of my ext. warranty left -- i think I'm going to try and get them to honour it.
gr
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
