Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Octane booster and fuel injecter cleaner
Old 12-15-2008, 10:58 AM
wirelessdude04's Avatar
Just curious to know if anyone has ever tried these and do they actually work?
wirelessdude04 is offline
Old 12-15-2008, 11:04 AM
99NightRiderMAX's Avatar
Ya they do work, if your using the better brands. Personally I go for a brand called ZMAX, get both the fuel formula and oil formula, they not only increase your gas mileage, but they also clean your engine. You can find ZMAX at most auto supply stores.
99NightRiderMAX is offline
Old 12-15-2008, 11:18 AM
djipka's Avatar
octane booster if it is LUCAS is goooood! It is street illegal though. For the injector cleaner LUCAS is good, so is Techron. Also there is one from Redline that is supposed to be good.
these are the only once I would use
djipka is offline
Old 12-15-2008, 09:29 PM
Ad·min·is·tra·tor
DanNY's Avatar
octane booster does nothing for your gas.
FI cleaner...Techron, redline.
you want to UP the octane then read up on toulene mixed in gas.
also on a stock car (no turbo, sc, nitrous) extra octane is a waste.
DanNY is offline
Ad·min·is·tra·tor
DanNY's Avatar
infomercial much?
DanNY is offline
Old 12-27-2008, 03:04 PM
just got a bottle of Techron free.99 lol. I should pour it in before i feel up right or is it ok if my tank is alread full?
Old 12-27-2008, 03:07 PM
Kevlo for President
Kevlo911's Avatar
There are instructions on the bottle
Kevlo911 is offline
Old 01-14-2009, 07:21 AM
That's Mr. Detail to you
Scottwax's Avatar
Lucas makes the best fuel injector cleaner I've used.
Scottwax is offline
Old 01-15-2009, 06:55 AM
MichMaxFan's Avatar
I've not had any life changing experiences w/ Techron FI cleaner, although I do use it and I hope it is actually doing something effectively.
However, I had AWESOME change in my van when I had an injector(s) act up and then it ran so rotten it was like it had 4 cylinders instead of 6 working. I used BG44K and it cleared it right up. Not that another good brand would have worked, but I wanted to take of it on the first try and not spend a bunch of money on injector replacement and had heard the stuff was very effective. It did the job. I know for a fact that that stuff works, but I've heard that one should use it sparingly and not regularly. It worked for me and solved my problem. If I have a problem like that again, I'll know the Techron does not "likely" work well, or at all, and would prob stop using it and just use the BG44K if I indeed had a big issue like that again.
For now, I keep using the Techron. No issues.
My $0.02.
MichMaxFan is offline
Old 01-15-2009, 08:25 AM
BigFonsz's Avatar
BG44K HERE!!!
BigFonsz is offline
Old 01-16-2009, 11:09 PM
SilverMax_04's Avatar
Originally Posted by DanNY
octane booster does nothing for your gas. FI cleaner...Techron, redline.
I can't speak to the quality of Redline FIC, but all of the other points above are right on the money -- especially the last point. The VQ engine is designed to burn 91 Octane premium gasoline. Unless you have mods or serious engine problems, any higher octane will not make any difference in performance.
SilverMax_04 is offline
Old 01-17-2009, 06:38 PM
G4nismo's Avatar
i loled
G4nismo is offline
Old 01-18-2009, 10:39 AM
Kamzilla's Avatar
I've been using Techron for years and would recommend it. I use it on both the car and moto.
Kamzilla is offline
Old 01-18-2009, 10:42 AM
alxdagreat1's Avatar
I've had good luck with Lucas
alxdagreat1 is offline
Old 01-30-2009, 09:18 AM
Addicted to the Org
maximized98's Avatar
http://www.ftc.gov/opa/2001/02/zmax1.shtm
Stuff doesn't work. You must not remember them getting sued for false advertisment
maximized98 is offline
Old 01-30-2009, 09:35 AM
Bobo's Avatar
Gumout Regane is also a good fuel injector cleaner at a reasonable price.
Bobo is offline
Old 02-20-2009, 02:59 PM
denbigh97's Avatar
I thought it's stated in the manual to NOT use any fuel injector cleaners or octane boosters?
denbigh97 is offline
Old 02-26-2009, 11:38 AM
Maxgig's Avatar
True, it does, but who reads the owners manual nowadays?
Maxgig is offline
Old 02-26-2009, 05:07 PM
detailerdaveb@gmail.com
maximadave's Avatar
Originally Posted by BigFonsz
BG44K HERE!!!
same here...
maximadave is offline
Old 02-27-2009, 12:57 AM
MIC5631's Avatar
i have had good luck with sea foam and trans valve fix (TVF) from Blaster
I would consider using Zmax too the next time i am in need of it
MIC5631 is offline
Old 02-27-2009, 01:11 AM
I thought it's stated in the manual to NOT use any fuel injector cleaners . . . ?
While this is true, I believe the reason for that statement is Nissan believes that the government mandated fuel-injector treatment level in commercial gasoline (yes, a minimum treatment level is mandated in gasoline) will be enough to keep the injectors clean.
History has shown that this is not the case. For most peoples' driving style, there is a need for additional cleaning -- from time to time -- to keep them clean and reduce engine deposits. I've had good luck using Chevron's Techron -- don't have any experience with the others, so can't comment on them. I stick with what has worked for me for over 20 years.
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
06-06-2017 02:01 PM
MichMaxFan
09-30-2015 09:18 AM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: Octane booster and fuel injecter cleaner
