Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-17-2008, 07:34 AM   #1
Looking to switch to synthetic
I will need an oil change very soon. I am looking to start using synthetic oil. Do I just ask for synthetic at the shop? Or is there a process that is needed to switch over to synthetic?
__________________
J RO 9 is offline   Reply With Quote
Old 12-17-2008, 11:21 AM   #2
Maxima.org Sponsor and Donating Maxima.org Member
If your car has been well maintained and if you intend to continue with conservative OCIs (within OEMs recommended service intervals) , there is no special process required when switching to a synthetic.
However, if the engine has high mileage; service history of your car is unknown; if it has not been serviced regularly; or if you suspect the crankcase contains abnormal deposits, you might want to consider using one of the various crankcase cleaning products available prior to installing the synthetic oil.
Recommend you monitor your oil level over the service interval to make sure there is no abnormal consumption. Synthetics typically contain more robust detergents and they will eventually clean deposits left behind by petroleum oils. If the synthetic oil becomes prematurely dirty from this cleaning process, oil consumption could increase. Should that happen, you would simply drain the oil and install a fresh fill of synthetics.
Bottom line is that you should be OK to do a direct switch providing your engine has been well maintained; stick with mfgr-recommended OCIs the first couple changes; and keep an eye on your oil level. Your engine will thank you for this :-)
talkinghorse is offline   Reply With Quote
Old 12-18-2008, 12:33 AM   #3
Send a message via AIM to michaelsevilla
get royal purple sir. You will be thankful. Just flush your motor out and drop in synthetic oil/royal purple.
michaelsevilla is offline   Reply With Quote
Old 12-22-2008, 12:27 AM   #4
Send a message via AIM to Zigg
Quote:
As much as I like Royal Purple, I really do, do NOT go over the recommended oil change interval with this oil. As with most synthetic oils, you can go well over the 3k interval, except with the Royal Purple. This sadly decreases greatly the cost efficiency of Royal Purple which is on the higher end of the price spectrum. Still, I love Royal Purple - I use it on ALL of my equipment at work.
Zigg is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
