Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-31-2008, 02:29 PM   #1
SHIFT_up
99se5speed's Avatar
Send a message via AIM to 99se5speed
New Mobile 0w30???
So i noticed mobile came out with a new oil. Green lable and Cap. It comes in a few variations but i'm interested in the 0w30. It claims to be better then the factory recommend 5w30 and 10w30. Its full syntetic and says it saves gas (yeah right....). Anyway I wanted to know if it would be alright if i switched/tried this oil. I have used nothing but 5w30 for the past 3 years with either oem or mobile filter. Car has over 170k, would this be alright? Thanks to all the oil gurus
__________________
Shift_A325SPD-SE
- Front Strut Bar - Rear Sway Bar - Y-pipe - Hi-flow Cat - Chassis Brace - B&M Short throw w/ WRX STI knob & Polyurethane Shifter Bushing - F/R Brembo's w/ Hawk HPS - New Raxles axles - 6k HID Headlights - 3k HID Fogs - De-badged & Stripped - Bezel w/ Chrome rings -
Future Mods! - Rebuilt 5spd/De-k swap w/ VAFC-2 - Cattman Headers/Exhaust - Coilovers
99se5speed is offline   Reply With Quote
Old 08-31-2008, 02:40 PM   #2
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
0w30 is actually really good. Try it and see for yourself.
__________________
http://www.cardomain.com/ride/3135334______http://www.cardomain.com/ride/3171620
4th gen. items FS:
-2 sets of 9004 bulbs ($10/set).
-1157 red LED bulbs ($5).
-OEM bumper lights ($20).
-License plate light assembly ($10).
-PM me if interested.
-Shipping/PayPal fee not included..
ChrisMan287 is offline   Reply With Quote
Old 09-01-2008, 04:23 PM   #3
Automagic Baby
johnnyd2k2's Avatar
I'm runnin it now and noticed a slight mpg improvement slight being the key word only like .5mpg 22 to 22.5mpg increase but anything helps with gas prices this high.
__________________
Megan Racing Catback NWP Spacers & Block Plate DR Mod
UR Pulley Custom Short Ram Intake SSIM Timing Advance
50% Tint Smoked Corners HID Fogs Debadged
SE-Rs Dropped on Vogtlands & Illuminas
14.48 1/4m
johnnyd2k2 is offline   Reply With Quote
Old 09-04-2008, 07:18 PM   #4
0W-20 Kendall
Okay - so, I got a bonified FREE Oil Change today: with Kendall FULL SYNTH 0W-20.
I couldn't pass it up....and I JUST happened to NEED it too.
I've never delved-into the "thinner" viscosity lube....but figured, what the hell.
Anybody have any comments about 0w-20 or Kendall full syn....please feel free to chime-in.
gr
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 09-04-2008, 08:53 PM   #5
Maxima.org Sponsor and Donating Maxima.org Member
gr
A 20-weight oil is fine if the engine were designed to run on it...I successfully used AMSOIL 5w-20 in our Honda for years...Ford also has gone to 5w-20 in many applications and I sell a lot of 0w-20 and 5w-20 for use in both Hondas and Fords.
A 20-weight is quite a bit thinner than a 30 weight oil is, and the thinner film of oil would cause me concern about the oil's ability to protect an engine designed for a 30-weight oil. Generally speaking, if the oil is too thin for the engine, bearing wear can increase...
If you're going to continue running it, I recommend you have the oil analyzed after a few thousand miles and see how it's doing
talkinghorse is offline   Reply With Quote
Old 09-04-2008, 10:17 PM   #6
0W 30
i have a 03 maxima that i just purchase about a month ago with 69k. would it be ok to use 0W 30 castrol or stick with 5w-30 mobil synt?. i live in the atlanta area.thanks
RASLOVFAR is offline   Reply With Quote
Old 09-04-2008, 10:35 PM   #7
Quote:
.5 increase?????? u sure that u didnt take piss and made the car lighter and got the increase from that.... lol
__________________
f550maranello2 is offline   Reply With Quote
Old 09-05-2008, 07:34 AM   #8
Quote:
You will be OK switching to a 0w-30 if that's what you want to do. Both 0w-30 and 5w-30 meet the requirements/offer the protection of a 30 weight oil when hot; so with everything else being equal, they should offer equal protection. 0w-30 will offer better performance in cold weather (it will pump at a lower temperature) than a 5w-30 will.
Your question was geared toward viscosity only, but different manufacturers formulate their oils differently. So depending on the formulation of the products you are considering, you may get performance benefits with one product over another that is not specifically linked to viscosity.
Old 09-06-2008, 07:35 AM   #9
I hear you, but such a small increase could be do to a number of factors including, but not limited to, how much gas you were able to pump into the tank on your previous fill, weather/temperature, traffic, speed, A/C on or off, etc. Assuming you ran your car 400 miles on the last tank, which would be essentially bone dry @ 22 mpg, a difference of only .4 gallons on the fill would give you a variation of .5 mpg. If you ran fewer miles before filling, it would take less of a variation in your fill to indicate a .5 mpg difference in your fuel economy...a variation of only .2 gallons on a 200 mile run would generate the same illusion. I regularly get a .5 mpg difference or more between tanks, and I check & record my gas consumption with each fill...I typically put ~450 miles per week/tank on my car.
IMO the best way to determine fuel economy is to record it over a long term and normalize/do a trend analysis of the readings. Unless you've done that, the difference could be due to a number of factors...
Old 09-06-2008, 04:38 PM   #10
Automagic Baby
johnnyd2k2's Avatar
I dont record my mpg but do calculate at every fill up and consistatly get around 21-22mpg. I travel the same route to and from work every day and go about 350 miles on a tank and fill about 16 gallons each time when the light comes on. This was with no highway miles at all thats why I noticed it and it has been consistant the past 4 fill ups with one exception where I drove about 100 miles highway and got 23.2mpg on that tank. It is a slight inprovement but the true test will be when I'm closer to needing an oil change I will see how it truely performs. Will keep posted on my results. I'm about 1500 miles in so with in the next few weeks I expect the milage to drop slightly but we will see.
Old 09-08-2008, 11:37 PM   #11
I get around the same mpg as Johnny and just tried it on my last oil change. Been like 6000 miles so far. ussually i used 5w30 mobil 1 full syn but gave it a shot. Its the same price at my walmart by my house. I really cannot tell any differnece.
pmi3096 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
