Fluids and LubricantsMotor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
This morning while goind to work I noticed my break light on. Atr first I thought I still had my e-brake on, but it was all the way down. So as soon as I get to work I realized that I was a little low on break fluid so I borrowed some from a friend (DOT 3). I added and the light went off. My only concern is that I have blue break fluid that I purchased when I swapped my rottors, pads, and break lines. I think its called ATE Dot blue racing fluid. Is it bad to mix regular break fluid with the stuff I already have in the car?
__________________ 05 Smoke 6MT ICE: Blue neon/Blue L.E.D's, Avic Z2 HU, AQ HDC3 12" sub ported @ 37 Hz, AQ 2200D amp, Stinger wiring/cap, Custom Box/Amp Rack Performance: Nismo short ram, NWP spacers, Home made Grounding Kit. Mods: RPT cross dimpled/slotted rotors, PBR Ultimate pads, RPT SS brake lines, Progress springs/rear sway bar, GR2 struts and shocks, Racingline front & rear endlinks, Black headlights, Tinted tails, & Nismo gunmetal rims. Under construction http://www.cardomain.com/ride/2222452
No, other than probably lowering the boiling point of the ATE Super Blu ever so slightly and having green fluid.
The real question is, where did the fluid in the reservoir go? Do you have a leak or are the pads worn down so much that the reservoir got low?
That is a good question. I did replace my brake line a while back since it was leaking from the area it threads on to the line that goes into the engine bay. Since then I put about 10K miles on the car, so I'm assuming brake wear has to be the reason why I had low fluid. My fluid level was near the low line since I only a little bit of fluid left when I replaced the brake line. I did inspect the drive way for any leaks, but saw nothing. I'm sure my car is not leaking, otherwise I would see it on the driveway.
