Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-30-2008, 04:30 PM   #1
04 max Oil quantity vs recommended?
Hey, for the 04, the recommended oil quantity is 4 liters with a filter change.
So I put in exactly 4 liters of oil, and when I check the oil, the level is at the bottom of the grid level (so it's low).
So what do you guys usually do? Since the grid is approx 1 liter from bottom to top, that would mean I need 500ml of oil, which seems alot compared to the recommended 4l.
What is your opinion on this?
Kryogen is offline   Reply With Quote
Old 07-30-2008, 04:34 PM   #2
Send a message via AIM to !PrjctMax!
When I change my oil I just put in about 4.5 quarts...
__________________
Stopped in on 10/29/09.
!PrjctMax! is offline   Reply With Quote
Old 07-30-2008, 04:47 PM   #3
Send a message via ICQ to Hilbe Send a message via AIM to Hilbe Send a message via Yahoo to Hilbe
I do 4.5 to 5 qts...
__________________
Hilbe
2004 Liquid Silver Maxima SE
Fujita CAI | NE Spacers | Cattman Y-Pipe | Nismo Exhaust | Cosmo UDP | VIAS Block | AT Grounding Kit | KYB GR2 | RacingLine FSTB / Endlinks | Drilled/Slotted Rotors | PBR Ultimate Pads | 2007 Rear Bumper | Black LED Tails | LED Switchbacks | 350z 35th Anniversary Rims | FormulaONE Tint | Sidemarker Overlays | Lund Grill | Viper 5900 | Pioneer AVIC-D3/BT/12 Disc Changer/iPod/SWI-PS | NESA NRM-7002 | SE-R Pedals | Clear Doors | LED Interior | AMSOIL 5W30
Hilbe is offline   Reply With Quote
Old 07-30-2008, 04:52 PM   #4
Ok so I'm not alone, it seemed like I really needed 4.5
Thx
Old 07-30-2008, 05:22 PM   #5
You put in 4 liters though...
__________________
Old 07-30-2008, 05:28 PM   #6
SuPeRmOd
NismoMax80's Avatar
liters /= quarts
NismoMax80 is offline   Reply With Quote
Old 07-30-2008, 05:40 PM   #7
My post was sarcasm...
__________________
Old 08-01-2008, 03:54 PM   #8
I am using the larger Mobil 1 oil filter and find that I need to put in 5 quarts to get the level to the top line on the dipstick. When I used the OEM filter it was 4.5 quarts.
A quart is .946 liters -- so its not quite a full liter.
__________________
SilverMax_04 is offline   Reply With Quote
Old 08-02-2008, 07:33 AM   #9
I would put th entire 5 quarts.I dont think its any harm. Done it twice now. 4th gen btw.
__________________
FOR SALE
97-99 Headlights $100 shipped obo
Snypa is offline   Reply With Quote
Old 08-02-2008, 11:39 AM   #10
Quote:
This is wrong. You should never over-fill your engine with motor oil. It can cause a number of problems like the crank shaft hitting the oil and causing it to develop foam.
You are much better underfilling the engine a half a quart than to over fill it by a half a quart.
Even though I know it will take about 5 quarts for my engine with the larger filter, I always start out with 4 quarts and then add extra oil to get the level up to the upper line on the dipstick. Better to be safe (and slow) than sorry (and fast).
__________________
Old 08-06-2008, 07:21 AM   #11
adding an extra half quart to the engine will not harm it, most engines are tested in pre-production phases with an extra quart and less a quart
with the extra half quart, unless you have only read technical data relating to an engine you would realize in the real world the oil only sits in the pan until start up but while running half the oil is probably now coating the engine, it's virtually impossible for every quart to constantly be in the pan while running.
when referring to overfilling, it's more then a quart, where this half quart myth came from is a little odd
I put 5 quarts in with the M1-110 filter, I used the 108 but switched
__________________
2009 SV Sport&Tech, Dark Slate
2006 SE Maxima, Onyx (traded)
only FS by sponsors in sigs.
STARR is offline   Reply With Quote
Old 08-06-2008, 10:36 AM   #12
Quote:
I need to put 5 quarts in my VQ when using the M1-110 filter just to get to the fill line on the dipstick.
I disagree with your points on there not being a problem by overfilling by 1/2 quart. The full line on the dipstick is set for the engine running and the oil flowing around the engine (while running). You don't want the oil sump while running to still be too full of oil. That is more likely to be the case if you overfill the engine (even by 1/2 a quart) when it is not running.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
