Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Prestone silicate, phosphate, & borate free
Old 03-27-2012, 09:30 AM
asand1's Avatar
I got to thinking about coolant types and requirements, and decided to research a little bit. What I found online was that Prestone makes a coolant that fits the bill. Its called Prestone Extended Life Antifreeze/Coolant 150/5.
It's an ethylene glycol base, and silicate, phosphate, borate, and nitrite free.
I will be changing out the Dex cool in the Chevy Uplander as well with the same.
I changed out my coolant yesterday, flushing with six gallons of distilled water, and topping off with a seventh after adding the anti-freeze. Not sure the finished mix ratio but it took the whole gallon of Prestone plus the water.
As a side note, for those sitting on old coolant, afraid to harm the environment. http://www.cdphe.state.co.us/hm/hhw/...antifreeze.htm
I researched this and found that 95% of all treatment facilities are able to do this. dilute and flush down the toilet. Flush a few times to get it on its way and out of the pipes.
asand1 is offline
mkaresh
03-12-2018 06:48 PM
06-06-2017 02:01 PM
D Mason
06-21-2016 04:43 AM
RWCreative
09-21-2015 11:01 AM
Quick Reply: Prestone silicate, phosphate, & borate free
