Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 06-29-2008, 03:22 PM   #1
HOW MUCH COOLANT LOSS IS NORMAL IN THIS HOT WEATHER?
I just replaced my Rad and all the hoses. Is it normal for my Radiator Reservoir to be sinking 200mL per week?
After I filled the Rad up properly when it was new, a week after that I had to add another 400mL to bring the tub back to the MAX line.
I never remembered the level in the tub moving that much in the past, and I haven't detected any leaks so far.
Is this normal?
1993-VG30E-GXE is offline   Reply With Quote
Old 06-30-2008, 08:43 AM   #2
matty's Avatar
Send a message via AIM to matty
Shouldnt lose any
matty is offline   Reply With Quote
Old 07-01-2008, 02:05 PM   #3
Carbon Fiber addict
200ml = 6oz, or half a soda can. That's a lot to lose in a week, and is definitely not normal. Either you have a simple leak, or bigger issues.
Just keep an eye on it. Maybe you didn't "burp" the system and fill it properly when you installed the new radiator. Maybe you'll be ok now.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
The Wizard is offline   Reply With Quote
Old 07-02-2008, 11:39 AM   #4
Quote:
That would be my guess.
gizzsdad is offline   Reply With Quote
Old 07-04-2008, 07:37 AM   #5
Maxima.org Sponsor and Donating Maxima.org Member
Let us know if this (coolant loss) stablizes. I'm with The Wizard and gizzsdad...if you weren't losing coolant prior to the installation of the new radiator/hoses, you probably have/had some air trapped in the system and it's working it's way out.
I assume all your hose clamps and the radiator drain plug are tight? Did you happen to replace the radiator cap with one with a higher pressure release?
talkinghorse is offline   Reply With Quote
Old 07-05-2008, 07:18 PM   #6
Hi guys - i'll respond to all of you with an update.
I followed the burping technique as in the FSM - it took REALLY long to fill the radiator - it burped very slowly. So here are the amounts I have filled so far:
7.15L Into Radiator
700mL Into Reservoir
400mL Top Up 1st Week Into Reservoir
300mL Top Up Recently Into Reservoir
8.55L TOTAL SO FAR INCLUDING TOP UPS
FSM COOLANT CAPACITY
8.3L + 600mL Reservoir Tank = 8.9L TOTAL
I'll keep you posted in 1 more week to see the loss. Note that when doing the flush procedure, there may still have been a fair amount of tap water left in the RH Engine section, as I could only locate the LH Bolt for the engine block.
Old 07-07-2008, 09:05 PM   #7
You'll know if you have a loss.
More so if your dripping, you'll see white smoke and you can smell the thing.
FishyMan is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
