Check page CL-6 and CL-10 of the FSM. The lower air bleeder valve is located on the operating cylinder which sits on top of the clutch housing. Pull off the air box and follow the hydraulic line from the master cylinder - it terminates close to the release lever (throwout bearing fork). If you still can't find it then ask someone to push the clutch in while you are looking at the top of the transmission/clutch housing and you will see the release lever move back and forth. The operating cylinder is right there.
__________________
HLSD // Intake Spacers // UDP // Progress RSB & Springs // Illuminas // RTP Xdrill/slotted F/R // SS lines w/ Super Blue // Warpspeed Y-pipe // Megan Catback // FSTB // MT Lip // Hella Supertones // NT555 on 18x8 SE-R rims // 221 WHP - 232 TQ // 9.994 1/8th mile
