Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 05-02-2008, 03:37 PM   #1
How Do I Change Brake Fluid?
Can anybody give me instructions?
1993-VG30E-GXE is offline   Reply With Quote
Old 05-02-2008, 03:50 PM   #2
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
Download the FSM or purchase a Haynes/Chiltons manual.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 05-02-2008, 06:55 PM   #3
I had a helper when I did mine for the first time, and it was easy. BUT, I'd never do it myself w/out proper teaching. I watched carefully and understood what was going on, but i really dont know that I would do it by myself, having only the one experience w/ it. A shop will do it for $60-80 bucks around here. I'd stay away from it if I were you.
MichMaxFan is offline   Reply With Quote
Old 05-02-2008, 09:35 PM   #4
Quote:
I'm beginning to think this too. I can't find any information on it. Even if I tried to suck the fluid out of the reservoir, there's no access to the fluid..there's some screen blocking AND the reservoir is so tiny my guess is all the fluid is in the system.
Do you remember how much fluid you drained out and replaced when you did do it? I'm curious.
Old 05-03-2008, 08:25 AM   #5
When we did mine, we drained all the lines and it took less than 1 qt to purge out all the old fluid until the only thing coming out was fresh fluid. Mine had never been done, and was quite dark...it is darker near the calipers than it is in the reservoir because the heat transforms the color and degrades its properties. It's far easier than changing the coolant or spark plugs for that matter, but the concern is getting all the air out of the system properly (bleeding the brakes) and following the proper procedures.
Dont open the fill cap unless necessary because air is absorbed into the fluid and degrades the system. Keep it closed at all times unless its getting serviced. I would recommend getting the fluid changed by a mechanic friend or a shop because (I recently learned this) most problems w/ brake lines are due to lack of changing the fluid. It doesnt circulate like oil/coolant/ps fluid and so the stuff at the ends of the lines just sits there and gets old w/ the heat and pressure at the calipers. I think they recommend every 2 yrs or so.
Old 05-03-2008, 09:55 PM   #6
Send a message via AIM to Anuj
i just did mine today! i'll write up a quick diy.
__________________
2002 Nissan Maxima Sterling Mist
2000 Honda S2000 New Formula Red
Anuj is offline   Reply With Quote
Old 05-08-2008, 10:18 AM   #7
GO BUCKS!!
00MaxSE's Avatar
Send a message via AIM to 00MaxSE Send a message via Yahoo to 00MaxSE Send a message via Skype™ to 00MaxSE
I have yet to do this as well. There's gotta be a generic write up we can follow.
EDIT: found yours
__________________
00MaxSE is offline   Reply With Quote
Old 06-08-2008, 01:16 PM   #8
does brake fluid have shelf life? probably not for UNOPENED bottles right?
FishyMan is offline   Reply With Quote
Old 06-23-2008, 02:33 PM   #9
Send a message via AIM to wyche89
Quote:
did you do the writeup yet? i'm gonna need to change mine eventually
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Cattman Headers, Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, 17* Timing Advance
Suspension: Tokico Illumina Struts, FSTB
"I feel the need... the need for speed!"
wyche89 is online now   Reply With Quote
Old 07-06-2008, 09:30 PM   #10
The procedure seems pretty straight forward, it's all in the BR section of the service manual. All you need is a crowfoot and some vinyl tubing, plus the tools to get the odds & ends off, and a torque wrench. I'm going to do it with a second person, just makes it easier. There is a tool that makes it easier to do it with 1 person. While you have everything off, you may as well inspect your brakes too.
The only thing that confuses me, is that they say to clean out the master cylinder, but I don't see how this would be possible without removing all the fluid. Prior to this statement the manual says to not allow the fluid to go too low in the cylinder, so this confuses me.
They also say to clean the cylinder with clean brake fluid and nothing else.
Old 07-07-2008, 11:18 AM   #11
MAXIN' ON
Send a message via AIM to redls1
I guess you could let it get low/but not empty and then take a rag and wipe it out.
__________________
2007 Maxima 3.5 SE
! 20" CHROME Katana Desire ! MTX MONO AMP !
! MTX 10" SUB ! BILLET GRILL !
redls1 is online now   Reply With Quote
Old 07-07-2008, 09:04 PM   #12
I don't think you should tinker with it. There's a screen in the master cylinder to filter out particles that'll ruin the lines. The brake fluid system is closed as says and does not circulate. It will drop as brake pad wears down amongst other ways to indicate.
Just bleed the system good and you'll be fine. You don't want it to be empty where it sucks in air and becomes more of a hassle. You'd actually need 3 people. 1 to top off the fluid, one at the brake pedal and 1 at the caliper lol.
Old 07-09-2008, 08:42 PM   #13
Guys I need to empty the cylinder completely. I have to replace the ABS Actuator - it's bursting at the seems literally. I was driving last week on the main road and I practically completely lost my brakes - I had to use the emergency brake but it doesn't work so fast, the fluid ended up on the street and the level was below the MIN line by the time I got in the driveway, although not completely empty. Luckily I was only 5-min from home at not on the highway.
I'm going to the JY next week to find one - Nissan quotes me around $800.00 for the replacement.
I think according to the manual I have to remove all the fluid from the hydraulic lines when removing the Actuator..I just need to make sure to do the Air Bleed procedure at the end.
Does anyone know if it would be dangerous to use anti-sieze on those brake tubing line nuts when I install the new part?
Old 07-10-2008, 02:26 AM   #14
for some reason i thought i just bleed the brakes til the old is out, no?
__________________
We're always together
maxximaa is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
