Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 04-30-2008, 12:15 AM   #1
Send a message via Yahoo to jimmypronet
Transmision fluid level?
OK i found the sticky in changing transmision fuid (automatic) .... my question now is.. i got a 04 max... how many quarts should i put after i cleaned and drain it.. and where will i see the level?
__________________
04 MAXIMA 3.5 SE FULLY LOADED
Check out my ride here http://www.cardomain.com/ride/2966571
jimmypronet is offline   Reply With Quote
Old 04-30-2008, 06:01 AM   #2
You will most likely be putting in the exact amount that you took out. In my case, however, some moron had overfilled it and I didn't know it and when I drained and put back what I took out, it was too high on the dipstick.
So, what I would do if I were you is measure what came out and if it was lets say 4.5 qts then maybe put in 3.5 or so and then the final amt just do a little at a time until it measures in the cool section on the stick (you then know it's atleast on the stick). Then start the car and run according to user's manual and gradually add the fluid and keep monitoring the level until it measures appropriately on the dipstick. IF you had checked the level before changing it, then you would be fine just to put back the same amt you took out. In my case, I "assumed" is was right because a trans shop had done it the time before and I was wrong because it was overfilled.
Hope this helps. Read the sticky you found, it will help a lot.
MichMaxFan is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
