Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 04-16-2008, 03:23 AM   #1
04_Maxima
quick oil question!
Ok let me know what you think.i changed my oil last nite.drained it all out and put a new filter on.i put 4 qts in and then i checked the oil level.it was way above high.normal?
Old 04-16-2008, 08:19 AM   #2
Send a message via AIM to mynameispee
did you turn the car on for a few seconds to let the oil circulate then check the oil?
__________________
mynameispee is offline   Reply With Quote
Old 04-16-2008, 08:22 AM   #3
Send a message via MSN to Thanatos
Thanatos is offline   Reply With Quote
Old 04-16-2008, 11:39 AM   #4
Maxima.org Sponsor and Donating Maxima.org Member
If you drained the oil and changed the filter as you say you did (and I'm sure you did) it can't be overfilled with 4-qts, unless the car was seriously unlevel and you didn't drain all the old oil out. The dipsticks sometimes give goofy readings. Make sure you have the stick inserted the right way and check it again. Wipe the dipstick clean with a towel the first time you pull it, then check it again. And of course the car has to be level to get an accurate reading.
talkinghorse is offline   Reply With Quote
Old 04-16-2008, 01:21 PM   #5
spec says 4 1/2 so put the other half in
__________________
2006 SE Maxima, Onyx
OEM All-Weather Mats
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
RTP Cross drilled/Slotted, F&R
Hawk HPS pads
AT Grounding Kit
STARR is offline   Reply With Quote
Old 04-16-2008, 01:30 PM   #6
Quote:
I disagree with this.
After running your engine for a few miles, you should check the dipstick following Talkinghorse's advice. I also like to let the oil settle in the engine, so I check my oil in the morning before I start the engine. Add more oil based on that dipstick reading.
In my case I have to put more motor oil in my Max than the "spec says" because the oil filter I use is larger than the Nissan filter.
__________________
SilverMax_04 is offline   Reply With Quote
Old 04-17-2008, 10:18 AM   #7
Quote:
if you change the oil and filter with the specified oil and filter recommendations then 4 1/2 quarts should be fine, if your gonna switch to a bigger filter and put less oil in thats just no common sense.
To check the oil Nissan says to check it on a cold engine, the FSM even says that.
I use 5 quarts with an M1-110, the M1-110 was by accident cause they had no 108 and I just looked at the diameter not the length
__________________
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
Hawk HPS pads
AT Grounding Kit
Old 04-17-2008, 12:57 PM   #8
My point is "why blindly put in a certain abount of motor oil." Put in enough to get the oil to the end of the dipstick and then add enough oil to get to the full line on the stick. Then you absolutely know that you have the correct amount of motor oil in your engine. The difference between the two marks on the dipstick is essentially 1 liter or almost 1 quart of oil.
What you don't want is too much oil in the engine. Doing it my way, you substantially reduce the chance of overfilling your engine.
__________________
Old 04-20-2008, 10:37 PM   #9
i just changed my oil today and i put all 5 qrts in. and it still runs fine. what are your thoughts
__________________
20 INCH CHROME //BERK INTAKE//FRONT CLEAR CORNERS //AVIC-N3//FOSGATE P3//ALPINE MONO 650 RMS//SIRIUS SATELLITE RADIO//INTERIOR DOOR LEDS //TOCKICO ILLUMINAS F3/R4//H&R SPRINGS//TUSANMI CAPACITOR 1.2F// PIAA WHITE LIGHTS LICENSE PLATE......
http://www.cardomain.com/ride/2336457
LEAVE A COMMENT
playboi21617 is offline   Reply With Quote
Old 04-20-2008, 11:44 PM   #10
It is much worse to overfill you oil pan by 1/2 a quart than to underfill it by the same amount. You can do real damage to your engine by overfilling, and essentially no damage by underfilling. So check the dipstick to be certain that you did not overfill her.
__________________
Old 04-25-2008, 04:32 PM   #11
I never thought of this. I don't use the OEM Nissan filter - so this could skew the capacities, but by how much?
1993-VG30E-GXE is offline   Reply With Quote
Old 04-25-2008, 04:33 PM   #12
Do you think it's possible the dipstick could go wrong in the older maximas?
We measured out the exact amount of oil as per the manual, and put that in, and my dip stick still shows that it's overfilled?
Old 04-25-2008, 04:52 PM   #13
I use the larger Mobil 1 oil filter and put in about 1/2 a quart more than spec.
I have never heard of a "dipstick going wrong" -- but I suppose it could happen. However, given the difference between slightly overfilling and slightly underfilling your engine, I would tend to believe the dipstick reading and not put in so much motor oil. Thus, by following the dipstick you, in fact, end up slightly underfilled, you will certainly be better off than putting in the spec amount and, in fact, ending up slightly overfilled.
__________________
Old 04-25-2008, 05:16 PM   #14
This engine takes a larger filter than the VQ engines do. If the aftermarket filter you use is the correct model for your engine, the filter shoudn't be a factor...but if you're using a smaller filter then it could cause the oil level to register high. What filter are you using, and I'll tell you if it's the correct one?
I believe your engine is essentially the same one that was used in the Quest during this time period. The dipstick on the Quest was a semi-flexible braided cable with a little bobber on the end. If yours is like that, I don't believe you can install it incorrectly. The VQ engines, however, have a more traditional blade-type dipstick...my experience is that you will get significantly different readings depending on which side you insert upwards.
How much oil did you put in, and what filter are you using?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
