Actually yes! It is that easy.
I've not loosened the radiator plug at all the last few times I've changed the coolant. Simply pulled the lower hose instead. Drains faster too. However, this does not drain the coolant from the engine block. Nor will running a garden hose in the radiator the way you described clean the old coolant out of the engine either. To do that you must refill the radiator with clear water, run the engine until the thermostat opens, and then drain the radiator once again. Do this 2 or 3 times and you should have practically all of the old coolant flushed out. Simply add 5 quarts of new coolant, and you've got a 50/50 mixture of coolant in the total system once the new coolant mixes with the water remaining in the engine block. I've never seen a post on this site where someone was able to open the engine block drain plugs without 1st taking off the exhaust pipes. So you have to do some sort of drain/refill routine to clean out the engine coolant.
Now, if you feel real frisky, and I've done this a couple of times ... drive the car about 3-4 miles (no more) after refilling the radiator with clean water the 1st time ... just long enough for the thermostart to open. Then remove the lower radiator hose and let the radiator drain again. Then open the radiator cap. Syphon action will pull the coolant out of the engine since the thermostat and radiator cap is open inaddition to draining the radiator. This is dangerous. You have to move fast. Work from the top of the engine compartment reaching down with your arm ... not from under the car reaching up.... and wear rubber gloves to protect your hands from getting scalded by the hot coolant coming out as you pull off the lower hose.
I've found that this takes so much fluid out of the engine that I only have to do 2 refills with clean water to have totally clear fluid coming out of the radiator. Then I refill with new coolant. I always use distilled water for the flushes, not the garden hose, and I clean the resevoir as you describe as well. Lastly, I recommend Nissan's expensive coolant. No other brand.
If this sounds too dangerous, just wait for the engine to cool off a little before pulling the lower hose, and the do the radiator drain/refill routine a couple of times. No syphon action of coolant out of the engine this way, but the drain/refill/run-the-engine routine eventually cleans out the engine coolant just as effectively. Takes a little longer, thats all.
Good luck.
