Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 04-08-2008, 07:36 PM   #1
Send a message via AIM to wyche89
Mobil1 synthetic 10w30 high mileage?
I picked up some of this stuff at auto zone and changed my oil with it on saturday. I'm hoping maybe this will alleviate some of my burning problems seeing as how i'm going with a thicker oil and one designed to decrease burnoff. I know with a oil burning 3.5, there's not much you can do short of changing the rings and valve covers, but I'm gonna try to lessen it as much as I can with my oil choice. I'll keep everybody updated on how much it burns in comparison with regular oil. What do you guys think?
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Cattman Headers, Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, 17* Timing Advance
Suspension: Tokico Illumina Struts, FSTB
"I feel the need... the need for speed!"
wyche89 is online now   Reply With Quote
Old 04-10-2008, 07:34 PM   #2
anybody?
__________________
2003 6 speed TE
Old 04-10-2008, 09:44 PM   #3
matty's Avatar
Send a message via AIM to matty
I would stick with regular synthetic but theres no harm in trying it. Probably just additives in the high mileage oil that cant really hurt.
-matt
matty is offline   Reply With Quote
Old 04-19-2008, 01:04 AM   #4
higher mileage usually means 10w30 vs 5w30 - somewhat thicker so older cars with higher mileage on dino oils will be less likely to burn it.
I personally use the reg mobil1 5w30 in my 04 maxima with k&n oil filters for longer life intervals. Switched to mobil1 5w30 truck and suv for hard working gasoline engines - slighty better @ the same cost.
messerchmidt is offline   Reply With Quote
Old 04-19-2008, 06:24 PM   #5
Maxima.org Sponsor and Donating Maxima.org Member
Quote:
10w-30 may or may not be thicker than a 5w-30...it depends when you compare measurements. At zero degrees, the 5w-30 should flow better (be thinner) than a 10w-rated oil will...but both are comparatively thick at this temperature anyway. However, at the other end of the spectrum (100 deg C), both oils should fall with the range of a 30-weight, and some 5w-30's are in fact marginally thicker than the same oil in 10w-30 formulation.
talkinghorse is offline   Reply With Quote
Old 05-15-2008, 09:00 PM   #6
Ive been using Mobil 1 10w-30 high mileage. Works great, no problems.
maxx0831 is offline   Reply With Quote
Old 05-20-2008, 02:13 PM   #7
if you are already running mobile 1 syn then i cant see it hurting anything but i dont think u will see a big(if any) improvement, but if u go tell us bc i might switch. i burn a bit of oil too but nothing im worry about.
maf2003111 is offline   Reply With Quote
Old 06-17-2008, 07:55 AM   #8
Wyche --
I've been using the high mileage M1 10-30w for two OCI's (10k mi) now. I cannot be certain it's the OIL, but i have DEFINITELY noticed a 50% drop in my oil consumption rate after switching to this oil.
I just had my Rear Valve cover AND PCV replaced - and I'm curious to see how this may effect my oil consumption rate.
As info: I was burning up to 1.5qts every 5k mi. now, I'm under .25qts in 2k miles....and those miles were HIGHWAY MILES, where I typically burn much more oil than in day-to-day city driving.
KEEP US POSTED!
gr
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 07-08-2008, 07:11 AM   #9
Send a message via AIM to '02_EMILBUS
I've been using Mobil1 5W-30 lately and I used the high mileage a time or two but I dont really monitor my oil burnage too closely. I keep oil in the trunk and add when needed.
Does anyone with the cold-startup tapping notice it more when their oil is low?
'02_EMILBUS is offline   Reply With Quote
Old 07-08-2008, 11:03 PM   #10
Quote:
Originally Posted by ghostrider17 View Post
Wyche --
KEEP US POSTED!
gr
yeah, it was probably the valve cover and PVC that did it... i noticed no difference in oil consumption
__________________
2003 6 speed TE
Old 07-11-2008, 09:49 PM   #11
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
I've been adding the high mileage version in between oil changes, don't notice any change in oil comsumption (a quart every 2000-2500 miles) but I may have to run only the high mileage version to see if it helps. High mileage oils have more detergents and seal conditioners (to prevent leaks) than regular versions.
I just picked up a new PCV at my Nissan dealer, I'll swap it out and see if it helps. Plus, I will probably do plugs and intake spacers in the near future, minus whale change the rear valve cover while I am at it.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 07-16-2008, 08:53 AM   #12
Not the oil -- it's the FUEL!!!
False Alarm!
I had been using 89 Octane E-10 ethanol blend for the past 3k miles, and JUST swtched-back....and VOILA! -- i started burning oil AGAIN!!--
Somebody who knows more than me about BTu values, and compression ratios needs to try this one...because I don't get it!!!
I was burning practically no oil on the E-10, but getting less fuel economy, and some knock.
But the numbers didn't add-up for cost vs. fuel-economy so I switched back to Premium...and as SOON as I did -- I started burning oil again!!
Fuk me and this crazy-ass VQ engine!!!
gr
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
