Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 02-10-2008, 10:57 AM   #1
coolant disapearing slowly
hey guys/gals,
my wife got a '96 gxe with ~148k miles. since last summer, her max has been losing coolant slowly and needing coolant refilled (~1/3 qrt) to the reservoir once a month to bring the level close to the max mark (cold engine). since i only do drain & refill every year with prestone LF coolant for about 5 years, we recently had the whole cooling system flushed and filled with Nissan LF coolant at a dealership. the situation doesn't getting any better - still losing coolant slowly. is this normal or i am worrying too much? the service guy said pressure test is ok, and there is no leak. as far as i can tell, there is no evidence that coolant got sucked in and mixed with oil - no white stuff on oil filler cap - as others told us to check. the max still has its original water pump in it (and no leak near the cover). if the wp is going bad, would it cause coolant loss? i will appreciate any of your insights.
Max96-97 is offline   Reply With Quote
Old 02-10-2008, 04:34 PM   #2
Coolant loss is NOT normal. My 2000 max has zero loss, but my Caravan, well, that's a diff story.
Seems odd that a pressure test checks ok w/ that much coolant loss....Hmmmm. Maybe burning it? Get an oil sample analyzed? I'm no pro on this, but you might check into an oil sample. I think that you could poss be burning it. Somebody w/ more knowledge on this will be of more help, but if I were you I'd get an oil sample tested and dont rely on just visual indicators in the oil (i.e. foaming).
MichMaxFan is offline   Reply With Quote
Old 02-10-2008, 09:41 PM   #3
i would give it a try as the next oil change is coming soon. thanks.
Old 02-11-2008, 12:23 AM   #4
I think minimal amounts of the coolant lowering especially looking at the resoivor is normal. But if it drinks it crazy, then it's not right. Also, if you see white smoke, then that's bad as well.
FishyMan is offline   Reply With Quote
Old 02-11-2008, 10:53 AM   #5
I would suspect either a small leak in the water pump, a bad head gasket, or a water hose leak.
__________________
winter beater: 2003 Maxima GXE
fun toy: 2002 JR supercharged Miata
twiggy144 is offline   Reply With Quote
Old 02-14-2008, 01:59 AM   #6
water pump failed
thanks for the replies.
i went to an independent shop to get an second opinion today.
the tech showed me that when he increased the radiator pressure, there was coolant dripping to the floor from the water pump. but the wp cover area was still dry; the coolant has been disappearing slowing un-detected. obviously the previous tech missed that or he didn't do the job right. so i went ahead with the water pump replacement.
Old 02-15-2008, 01:46 AM   #7
Get an oil sample analyzed? ... if I were you I'd get an oil sample tested and dont rely on just visual indicators in the oil (i.e. foaming).
You seem to have found your problem. But this suggestion remains a good one -- if you care about your vehicle.
I sent an oil sample in on my pickup truck (Dodge) and found that although the oil was good, there was antifreeze in the oil. Turns out that the heads had cracks that were allowing antifreeze to leak into the motor oil. Not enough to cause foaming, but enough to mess up the motor oil and eventually the whole engine. If I had not had this test done, I would still be driving with antifreeze in my oil -- and the engine would be wearing out much faster.
The cost of the lab test is not that much, and the knowledge that the oil is OK is certainly worth the price.
__________________
SilverMax_04 is offline   Reply With Quote
Old 02-17-2008, 02:30 PM   #8
that's a good point. knowing a coolant might get mixed with the oil, i also asked the shop to replace the motor oil after the wp job. my wife and i really enjoy driving this car, even with our 2-year-old on long trips, and we try to keep it for some time. given the car has almost clocked 150k, i will request an oil sample kit from Blackstone.
Old 03-16-2008, 03:17 PM   #9
Where can you get a sample analyzed?
martells2 is offline   Reply With Quote
Old 03-16-2008, 03:34 PM   #10
Try sending them an e-mail message at this address:
Blackstone Labs <bstone@blackstone-labs.com>
INFO SHEETS: To view an information sheet explaining our report, click on the
following link: http://www.blackstone-labs.com/report_explanation.html
QUESTIONS: Feel free to call us with any questions you have at (260) 744-2380.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
