Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 01-28-2008, 12:27 AM   #1
GM Syncromesh fluid?
I searched around couldn't find much info. I used to use this stuff in my Honda's and they shifted smoother after putting this fluid in. Has anyone tryed this stuff in their Maxima? How does it work with our trannies? It is the same stuff as the Pennzoil Syncromesh
watut is offline   Reply With Quote
Old 01-28-2008, 12:56 AM   #2
Quote:
Don't use any GM products. There not engineered for our cars It's pacifically GM and definetly not in our Trannies and other major engine components. If It's an auto tranny we they use the GL-4 and for the manuals they also use the GL-4 oil.
vqmaxman is offline   Reply With Quote
Old 01-28-2008, 06:32 AM   #3
Send a message via AIM to heynow
Quote:
Are you tyring to say that we use GL-4 in auto trannies as well?
__________________
'97 MAXIMA GLE FTW!!!
heynow is offline   Reply With Quote
Old 01-28-2008, 06:49 AM   #4
Quote:
Whoops! I meant to say the AUTO"s use the ATF type D.
Old 01-28-2008, 07:01 AM   #5
merlin2375's Avatar
Redline MT-90 or Amsoil MTF, both are GL-4 and work well with Maxima manual transmissions. A maxima.org user (talkinghorse) sells Amsoil in the "Group Deal" forums at a great price.
__________________
'01 A33 KV3 Maxima SE/5 speed MT | '99 KR4 P11 Infiniti G20/5 Speed MT
WTB:http://forums.maxima.org/5th-generation-classifieds-2000-2003/551777-wtb-5th-gen-interior-blank-switch-covers-belt-cover-pics-inside.html
merlin2375 is online now   Reply With Quote
Old 01-28-2008, 07:12 AM   #6
Send a message via AIM to black_maxed95
redline makes gl-4 fluids that is called shockproof. it is specially designed to protect the syncros and ive heard some people put the light shockproof in. (as opposed to the heavy)
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
black_maxed95 is offline   Reply With Quote
Old 01-28-2008, 10:55 AM   #7
Maintenance Monster
Quote:
Originally Posted by black_maxed95 View Post
redline makes gl-4 fluids that is called shockproof. it is specially designed to protect the syncors and ive heard some uses put the light shockproof in. (as opposed to the heavy)
The shockproofs have too low of a friction coefficient for the synchros to do their best. I don't have hard data, but I also expect they'll put more wear on the synchros too. But Shockproof is great for gear-only diffs and dog-mesh trannys. It also stinks even *worse* than regular gear oil.
I still prefer the MT-90 and Amsoil MTG GL-4 oils. Last I checked, the Pennszoil Synchromesh is a much lighter oil than the 75w-90 recommended by Nissan.
Dave
dgeesaman is offline   Reply With Quote
Old 01-28-2008, 11:18 AM   #8
ok thanks for the info, i have no experience with but ive heard from other people that the shockproof is suppose to add extra protection to the syncros. apparently its still not a good alternative.
i ordered a case of amsoil mtg gl-4 from talkinghorse so im looking forward to putting that in after i do my clutch work.
__________________
5MT SE 96er:
MOD LIST
Old 01-28-2008, 03:17 PM   #9
Maintenance Monster
Shockproofs give more protection to the gears and bearings, not the synchros.
While Maxima trannys have bearing issues, it's not the kind of problem that the shockproof oil will help.
Old 01-28-2008, 05:55 PM   #10
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
GM Synchromesh is the same fluid as Pennzoil Synchromesh and I've used it in my transmission and it worked just fine. MT-90 is a better fluid, but in a pinch the Synchromesh works just fine.
Shockproof is a bad idea in our transmissions. I know some people like to use it and would argue this with me till they're blue in the face, but they haven't taken apart over 700 transmissions in their time working at a high performance trans shop like I have. The results of a transmission that has been run with Shockproof for a long time are ugly. I've seen it time and time again. I would not run it in my trans.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is online now   Reply With Quote
Old 01-28-2008, 06:38 PM   #11
Send a message via AIM to f550maranello2
^^^^^^^so what kind of fluid is the best
__________________
f550maranello2 is offline   Reply With Quote
Old 01-28-2008, 06:45 PM   #12
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
MT-90
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 01-28-2008, 06:52 PM   #13
Redline MT-90 works killer, MTL for extreme cold but to each his own. All the info you need is in the fluids and lubricants forum.
jblinga is offline   Reply With Quote
Old 01-28-2008, 07:10 PM   #14
MT-90 gets my vote. However, I also own a subaru and use redline as part of a tranny cocktail. It is 2 parts Castrol HypoyC one part redline lightweight, and 1 part pennzoil synchromesh. It has been tested in subaru trannies for years and works great. But every car is different. With my max I have had the best luck with MT-90
__________________
Been loving my max since 01
cefiro80 is offline   Reply With Quote
Old 01-28-2008, 11:29 PM   #15
SLOW
Nealoc187's Avatar
MT-90 is what I put in my trans, the #1 oil we recommend for the transmissions we build at the shop, and what I tell my buddies to put in their transmission. It's very good stuff.
__________________
3.5L - I/Y/E - USIM
Old 01-29-2008, 07:44 PM   #16
Maxima.org Sponsor and Donating Maxima.org Member
Quote:
I would not recommend people use synchromesh fluid in Nissan or other transmissions that require a GL-4 lubricant. To the best of my knowledge, synchromesh fluids are light viscosity and contain no EP additives. GL-4 applications require a certain amount of EP additives. Synchromesh fluid might seem to work fine in the near-term, but probably won't provide adequate protection.
talkinghorse is offline   Reply With Quote
Old 07-10-2008, 07:11 PM   #17
drag racing is for wussies
BlackBIRDVQ's Avatar
Send a message via AIM to BlackBIRDVQ
80K miles on my ShockProof MEDIUM and I took the tranny apart to put in the Quaife and it still looked like brand new. There was no sludge, or wear anywhere inside the transmission. Car has been raced, and used as a DD also.
I nolonger have a Maxima, but I have changed that stuff every year and it was always clean and never gave me ANY issues.
__________________
Mike Jez
2004 Volkswagen R32.
OZ wheels, tons of suspension mods, brakes, go fast & light goodies.
BlackBIRDVQ is offline   Reply With Quote
Old 07-11-2008, 07:05 AM   #18
Maintenance Monster
I'm sure the annual changes helped a lot to keep it clean. The Shockproofs do contain suspended solids that grind down and eventually gunk things up. Of course, it's intended for racing so the end user should be changing it frequently anyway.
Dave
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
