Fluids and LubricantsMotor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
With my car approaching 90k miles soon, I'm thinking about replacing the fluid. When I got this car, it had 68k on it and I have no clue if the car had any drain and refill or flushes before. My question is, should I do several drain and refills? OR should I replace all of the fluid at the same time using the radiator cooler line method? OR should I drop the pan and take all of the fluid out that way? Also, would it be a risk to drop the pan and cleaning the magnets and changing the filter? I've been told that people experience problems when they do flushes and/or change the filter, cleaning the magnets, etc. What route go you guys recommend?
__________________
"Those guys are good, but Al and I, we're good, too," Charles Woodson snapped. "Last time I checked, none of those receivers could fly. They run routes, we run with them. Their feet are all on the ground, just like ours."
I'm assuming you are you talking about the transmission fluid. Get it flushed since you don't know the history of the car. Personally I would take it somewhere where they have a machine to do it. Get the pan dropped and cleaned. Make sure they put on a new gasket when the put the pan back together.
I assume you want to DIY. However, if I were you I would have the dealership do it because the fact you are uncertain if the trans was ever flushed before. That way you just drain and refill every 10-15K thereafter and won't have to worry about dropping the pan and cleaning the magnets. That's just me.
Try looking at the back page if you're having trouble searching. There's bound to be a post about transmissions within the last couple of days.
My ATF fluid was really dirty when I bought the car but still smelled like ATF is supposed to smell. I did a drain and fill and another one a week later. Since then, the shifting has noticably improved as the fresh fluid with fresh detergent cleans all the passages. Probably do another one when it warms up a bit, then do them every 20,000 miles or so from then on.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
__________________ 2000 Maxima SE (sold but still on the org) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
im paranoid and broke. i dont have 2k to buy a new tranny if the flush happens to move some deposits into the wrong place.
my car only got 45k on the engine, but im going to do a series of drain/refills with magnet cleaning. after 3 or 4 flushes the fluid is pretty much all new (93%)
follow my sig if you want to do the flush dropping the pan
Quote:
Originally Posted by nsnrider
+1 on tranny flush via dropping the pan.
Quote:
Originally Posted by 02slead
flush it,
SO you guyes recommend dropping the pan, cleanign the magnets and the screen then repalce the fluid by using the Radiator line method?
__________________
If drop the pan and change the filter I would ONLY use an OEM nissan filter.
Don't buy an Autozone filter it can screw with the line pressure of the transmission due to the aftermarket tranny filter not having the same flow chacteristics as the OEM transmission filter was designed to have by nissan.
__________________
2003 Nissan Maxima SE 6 speed Ti edtion
2005 Acura RSX Type-S FOR SALE $17,300 PM me
It is well worth it, not difficult and not expensive either.
I pulled the return line; drianed some/filled some until the fluid started to run nice and pink. Since then just pulling the drian plug and refill each spring. My tranny shifts like brand new and I have 103k; of course I have a vb mod so that helps.
__________________
02 6spd, Cattman genIII w-megan Bpipe and stock axel back/OTTO Fstb/Progress RSB/Progress-Illumina/32%Tint
I would suggest an easy flush method. Drain and refill the tranny, and two weeks later repeat.
__________________
Visit my website and watch my friend run his full weight stock MKV GTI to a record 14.2 @ 96. Record time for a stock VW 2.0T FSI! LINK
