Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 01-13-2008, 04:30 PM   #1
The process of switching over to synthetic?
Hey my max has 128k and I just got it about a year ago. Ive changed the oil with Mobile 1 supersyn, but prior to my ownership I doubt synthetic was used. I have been hearing people say there is a certain process you have to follow in order to go from non-synthetic to synthetic? Does this "process" exist or is it as simple at putting the new oil in the crankcase? Also, do you think it is fine that I am using synthetic at 128k?
__________________
5MT- 9007 Rewire - Yellow Fogs - Full Exhaust- 2k Wheels
Mctwist77 is offline   Reply With Quote
Old 01-13-2008, 05:47 PM   #2
I also just switched about a month ago, straight forward, change preferably to a Mobil1 filter and pour the synthetic oil.
From what I've read, it doesn't really matter. What you have to make sure, is probably to change your oil the 2 or 3 first times about at 3k miles, then 5k and then you're good to go.
Again, I'm no expert, so let's see what they say when they add to this thread.
BTW, your Maxi looks nice, they kept it up really good, what year is that?
__________________
04 Maxima SE love this car!!!
SuperMario is offline   Reply With Quote
Old 01-13-2008, 08:37 PM   #3
Its a 1995, it has it flaws some dents here and there. Im getting it lowered this week actually so I hope to get some pics up of it. Thanks, I wish I had a 3.5L any day though, you are lucky my friend.
__________________
Old 01-13-2008, 11:11 PM   #4
The thing with switching to synthetic from dino oil is the fact that it cleans ****. After 128k miles, your oil seals will deteriorate and the dino oil will build up in the deteriorated seals. When you switch to a synthetic, it will clean those nasty old seals and sometimes leaks will occur. Thats the reason I just stick with regular oil on higher mileage cars. Not like synthetic makes a huge difference anyway in an older engine.
SKarpenz is offline   Reply With Quote
Old 01-14-2008, 03:55 PM   #5
Prior to switching to synthetic, run 2 trials of AutoRX. See www.autorx.com and the additives formum of www.bobistheoilguy.com.
This product is only available over the internet and gets rave reviews on BITOG.
I used it prior to switching to synthetic oil.
It will rejuvenate the seals, clean the combustion chamber, and clean the ring packs.
It strikes me that you are a logical candidate to use AutoRX, given your mileage and lack of knowledge of how the vehicle was maintained prior to you owning it.
Bobo is offline   Reply With Quote
Old 01-15-2008, 06:26 AM   #6
One game at a time
Colonel's Avatar
Send a message via MSN to Colonel
The link above for AutoRX sends you to a pharmacy.
You want http://www.auto-rx.com/
__________________
2001 Maxima SE VQ30DE-K (5 Spd)
1991 MR2 3S-GTE (Gen III, 5 Spd)
2007 Rav 4 2AZ-FE (Auto )
Colonel is offline   Reply With Quote
Old 01-15-2008, 11:13 AM   #7
Send a message via AIM to ChaosMonkey187
Is there any difference between Auto-Rx and Seafoam? Sounds about the same, to me.
ChaosMonkey187 is offline   Reply With Quote
Old 01-17-2008, 09:17 AM   #8
To do the Auto-Rx treatment you put the regular 4 quarts of Mobile 1 then add one bottle of the auto-rx?
__________________
Old 01-19-2008, 09:17 AM   #9
www.auto-rx.com
Use 2 ounces per quart. Nine ounces in the case of a 4th Gen. I used the enitre 12 ounce bottle.
You can not run synthetic oil when you do the AutoRX trial. Follow the instructions precisely.
Old 02-01-2008, 10:32 PM   #10
Send a message via AIM to heynow
Better do the Auto-RX treatment prior to the switch over. Don't just switch to it like i did @ 128K. I developed bad leaks within months.
__________________
'97 MAXIMA GLE FTW!!!
heynow is offline   Reply With Quote
Old 02-26-2008, 11:33 PM   #11
Send a message via MSN to adrenaline_rush_fanatic
the double dose, 1/2 application mileage procedure (ARX trial)
should NOT be done prior to synthetic switch.
Correct?
__________________
A33B 6MT SE | debadged | 25% tint | ES motor mounts, LCA bushings, & 6spd bushings | Mobil 1 SS | GAB w/K&N | OSCAI | Progress drop pending..
adrenaline_rush_fanatic is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
