Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thread Tools Display Modes
Old 01-07-2008, 07:19 PM   #1
Send a message via AIM to wyche89
Amsoil Signature Series Oil
Right now, I have castrol GTX in my engine. I have a 5.5 gen with 50,000 miles, and no oil burning as of yet. I would like to switch to synthetic oil for the added protection since I like to drive in high RPMs, but I am afraid a synthetic may cause an oil burning issue. I am considering switching to the amisol signature series oil, which is supposed to have superior burnoff protection compared to other synthetics. Has anybody had this oil with an oil burning issue in their 3.5? If so, how does it stand up?
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Cattman Headers, Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, 17* Timing Advance
Suspension: Tokico Illumina Struts, FSTB
"I feel the need... the need for speed!"
wyche89 is online now   Reply With Quote
Old 01-08-2008, 01:53 AM   #2
pedo .. howls at the moon
redmaxpa007's Avatar
Send a message via AIM to redmaxpa007 Send a message via MSN to redmaxpa007 Send a message via Yahoo to redmaxpa007
Quote:
Originally Posted by wyche89 View Post
I have a 5.5 gen with 50,000 miles, and no oil burning as of yet. I would like to switch to synthetic oil for the added protection since I like to drive in high RPMs, but I am afraid it may cause an oil burning issue. This oil is supposed to have superior burnoff protection compared to other synthetics. Has anybody had this oil with an oil burning issue in their 3.5? If so, how does it stand up?
wrong forum......
mods need to move this
and yes.. there are lots of us with burning oil... install a catch can.. it will help a little...
__________________
RIP DBL07
redmaxpa007 is offline   Reply With Quote
Old 01-08-2008, 11:59 AM   #3
Old enuf to pick his own gears
d00df00d's Avatar
Send a message via AIM to d00df00d
Why would switching to synthetic cause oil burning?
Most good synthetics will actually reduce or eliminate oil consumption because they resist burn-off better. Amsoil is top-of-the-class in this department.
Amsoil's Signature Series oil is definitely going to be one of your best choices (if not the best choice) in every way. If I still had a Maxima, I'd be all over it.
__________________
SHIFT_yourowndamnself
Quote:
Originally Posted by BlackBIRDVQ
M3- doesnt have anything OVER a Maxima.
Click here and buy my stuff.
d00df00d is offline   Reply With Quote
Old 01-08-2008, 09:33 PM   #4
I owned a 1987 Celica that I bought used. The oil consumption in that car went up when I switched to synthetic (an oil brand no longer available). So I went back to dino and the consumption decreased -- but the engine still burned oil. I believe the engine had been abused by the previous owner, which is why it burned oil at all.
I think you will be fine switching to synthetic at your mileage.
__________________
SilverMax_04 is offline   Reply With Quote
Old 01-09-2008, 05:33 PM   #5
Send a message via AIM to Tippy Toes Send a message via Yahoo to Tippy Toes Send a message via Skype™ to Tippy Toes
I'm trying to install the amsoil transmission oil. I'm wondering where the oil needs to be drained and what kind of funnel to get to funnel down into the right area. Any pictures would be great. Thanks
Tippy Toes is online now   Reply With Quote
Old 01-10-2008, 12:59 AM   #6
Check out the Sticky on this site on Changing Manual Transmission Oil. There is a post there on the 6-speed trannie with a link to pictures (I believe of an 03). This was a great help when I changed my fluid in June of 06.
I bought a funnel and a long extension for that funnel at an auto supply store.
__________________
Old 01-15-2008, 09:19 PM   #7
Just realized today that i'm already burning oil at 50k miles! wtf? i just did a change with castrol GTX less than 1,000 miles ago, and i'm already 3/4 quart down... something is wrong
__________________
2003 6 speed TE
Old 01-16-2008, 10:58 AM   #8
d00df00d's Avatar
Don't panic yet.
First, check for leaks. Check everywhere. It might be something as silly as a washer you forgot to put back in or the oil filter not being tightened down properly.
Second, monitor it for at least another 2,000 miles. Oil consumption doesn't always appear linearly: sometimes it fluctuates, and you can't be sure what you see on the dipstick one day is real because there's no guarantee that the circumstances are exactly the same every time you check your oil (how hot is the engine? how long did you wait before stopping? etc.). Just keep checking it for a while and see what the pattern is.
Oil consumption is unfortunately a fact of life with a low-friction engine design like yours. The piston rings have to fit a little more loosely in the cylinders, so they're not going to seal as well. The low internal friction is a big part of what makes the VQ smooth and powerful, but of course there's no free lunch. The good news is that switching to a better oil will probably help things tremendously. High quality synthetics tend to have high flash points and low volatility, which means they won't cook off as easily. Also, don't forget that higher quality oil will be able to run longer between changes, so "having" to switch isn't too bad when all is said and done.
Hell, even if you can't get rid of your oil consumption, it's not as bad as it seems. Oil consumption is a little unsettling at first, but don't forget that you're partially replenishing the oil every time you top off, which will help keep your MPG up and let you run longer between changes.
I definitely think Amsoil SSO would be a great idea in your engine. If that doesn't work, or if you just want alternatives, here are some others:
- Redline 5w-30
- German Castrol 0w-30
- Any Motul xw-30
- Any RLI BioSyn xw-30
RLI would probably be the best option. Those oils have incredibly high flash points and apparently do some really funky stuff to help seal piston rings better. I'm actually trying to get a group deal together on that, so let me know if you're interested.
__________________
Old 01-16-2008, 08:36 PM   #9
i would be interested, but i'd like to read some data or reviews on the RLI before i purchase it.. i'm guessing it's expensive?
__________________
2003 6 speed TE
Old 01-16-2008, 11:28 PM   #10
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Oddly enough, concerning oil consumption with synthetics, I used to use Royal Purple in my 626 (for the first two years) and at 1500 miles, it would be down close to a quart. Switched to Mobil1 and it was 2000-2500 miles before I had similar consumption. With either oil though, oil consumption never increased.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 01-17-2008, 12:16 PM   #11
d00df00d's Avatar
Here's RLI's claim to fame:
http://www.bobistheoilguy.com/forums...&Number=893022
That thread covers pretty much everything.
You can also search on that site for more used oil analyses with RLI.
As for price, IIRC it's $30-$40 per gallon depending on the grade; if you need quart bottles, it's like $9-$10 per quart. Considering it's made from renewable resources on a farm in Ohio, that's pretty damn good IMO. It's more expensive than the off-the-shelf stuff, similar to Amsoil SSO, and cheaper than most Motul oils.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
