Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
3qts?
Old 04-26-2007, 04:57 PM
djfris's Avatar
3qts?
04 MAXIMA, I just hit 30k I want to change the Manual Trans Fluid. Anyone now how many quarts it takes(2004 MAXIMA 6spd)
PS
Where is the Cabin Filter Located?
THanks
djfris is offline
Old 04-26-2007, 07:02 PM
Maxima.org Sponsor and Donating Maxima.org Member
talkinghorse's Avatar
PS
THanks
You will need 3 quarts of GL-4 Gear oil (capacity is 4.9 pints).
The cabin filter is behind the glove box, and you will have to remove the glove box to gain access to it. Typically there are instructions packed with the filter, but if not, let me know and perhaps I can find/send you a link.
talkinghorse is offline
Old 04-27-2007, 12:42 AM
SilverMax_04's Avatar
Talkinghorse did not say it, but he is your best (and cheapest) source for Amsoil GL-4 gear oil. He impresses me because he would not sell me a product that did not have quite the correct spec for the use I wanted to use it for. I trust him.
SilverMax_04 is offline
Old 04-27-2007, 08:14 AM
sky jumper
+1 on talkinghorse. you will not find a better lubricant dealer.
streetzlegend
10-13-2010 01:51 AM
akurtzer57
05-12-2009 11:15 AM
achebee4you
10-20-2007 08:22 PM
SurraTT
08-01-2006 01:48 PM
NJ Devils Fan
12-23-2005 08:03 PM
Quick Reply: 3qts?
