Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
where are my spark plugs?
Old 06-02-2006, 09:08 PM
t0mmyr's Avatar
i got a set of ngk iridiums for my VQ30DE 5th gen, but i'm used to engine bays of v8 fords, i can easily spot the coils and spark plugs, but my maxima engine is way different, i think i can see 3, but i don't know where the other three are, whats the proper way to change my plugs? also, do i have to gap them? what is gapping them and how should i do this? or should i just wait till monday and have my mechanic do it since he promissed he would if i bought him lunch, i want to do it this sunday so i can change the oil too at the same time
t0mmyr is offline
Old 06-02-2006, 11:51 PM
10 psi
glenmoormax's Avatar
first this should be in 5th gen forum as spark plugs aren't a fluid or a lubricant
second you have a VQ30DEK
Third you said you "can easily spot the coils and spark plugs, but my maxima engine is way different, i think i can see 3, but i don't know where the other three are" but your asking where they are at... hmmmm.....
Fourth they are pregapped if they have a -11 after the part number. I would go with NGK's BKR5E-11. (recommended gap is .44)
Search around there are a million threads about spark plugs for our cars, maybe you should read your 5th gen stickies....
glenmoormax is offline
Old 06-03-2006, 09:01 AM
99grnmaxgxe's Avatar
http://www.picshed.com/tanman/
You're welcome
99grnmaxgxe is offline
Old 06-03-2006, 02:56 PM
t0mmyr's Avatar
thanks!! that helps a ton, now i just have to borrow or buy a torque wrench, i dont want to over tighten, nor do i want to leave them loose, is it really necessary?
btw, i got 6 NGK BKR5EIX-11 5464 spark plugs for $5.95 each, are these the right ones and already gapped right? the guide says to gap at .44? but looking at the model number am i to understand they are at .11?
t0mmyr is offline
Old 06-04-2006, 02:26 AM
10 psi
no you multiply the the 4mm by the -11 or whatever it may be in our case, elelven and that equals .44
Old 06-04-2006, 07:10 PM
THT
Throbbing member
THT's Avatar
Buy the regapping tool anyway. I know the NGK's are coming with the plastic collar to prevent the gap from changing in transit but of the last six I bought, I had to regap two of them. The tool is a buck and it's worth it for the piece of mind of knowing you have properly gapped plugs.
THT is offline
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
Need help
23
10-02-2015 08:56 AM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: where are my spark plugs?
