Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
how often we have to do fuel injection cleaning?
Old 05-05-2006, 04:56 PM
2002 maxima se
OC guy's Avatar
I drive 01 max and I am curious to know how often do we have to have fuel injection clean? is it after 60k or 30k....please help.
and adding a fuel cleaning treatment in tank helps anything to improve?
OC guy is offline
Old 05-06-2006, 12:11 PM
Need A Light?
steven88's Avatar
they say to add a bottle of fuel injection cleaner every 3k miles....i dunno if its real or just a marketing technique...
and i believe every 60k u should get your injectors serviced by a professional
steven88 is offline
Old 05-06-2006, 10:52 PM
SilverMax_04's Avatar
I put in a bottle of Techron before every oil change -- which for me using Mobil 1 is every 7.5 K miles. There have been some technical reports that fuel-injector cleaners have a tendency to increase the viscosity of motor oil in the car being treated. Not certain I believe that, but it is easy to use the same mileage as an oil change to also do a fuel-injector cleaning routine. And in the event that these cleaners do increase the motor-oil viscosity, I'm covered.
I would only pay for the injectors to be removed and cleaned if I were having problems with them. I personally believe that using Techron on a consistent basis, I will never need to have the injectors removed for cleaning. Time will tell.
SilverMax_04 is offline
Old 05-06-2006, 11:15 PM
Need A Light?
steven88's Avatar
yeah, you shouldn't have to worry too much about injectors...i mean modern day injectors are pretty reliable...they don't have the tendancy to just break down....it takes quite alot of miles for them to actually need servicing....thats assuming u keep good gasoline in the tank...and u keep up with other regular maintenance...like fuel filters especially...a bottle of techron wouldn't hurt either...bg44k if u wanna go ***** out
steven88 is offline
Old 05-07-2006, 03:32 PM
kcryan's Avatar
Fuel power or techron, FP=3 out of 5 tanks, but its priced right to do that, techron=every 3-5k miles depending
kcryan is offline
Old 05-09-2006, 06:52 PM
eric93SE's Avatar
Originally Posted by vparekh0885
I work at a oil change place. We do oil changes (we use mobil motor oil), trans drain and fills, fuel injector cleaning, radiator flushes, tire ro's, and so on...
We recommened cleaning your fuel injectors every 12-15k. The way we do it is we have a bottle of intake fluid and get the booster cable, stick it in there and let it run till the fluid in the bottle runs out...we then rev the car up to about 3k rpm and you see all the smoke come out the exhaust....
See, that why I never go to places like that, b/c there are idiots working/running the place. If you knew which end was up you would know that your feeding that cleaner through the air intake and not the fuel injectors, that may clean the valves, but it sure won't clean the injectors.
Good news however for people with 10% ethanol in the gas. There should be no need to add injector cleaner anymore, since the ethanol already does a good job of cleaning them. Why do I know this? I'm using a K&N fuel filter that I take apart to clean every so often, and since we've switched to an ethanol additive my filter has been spotless! Chances are the filter on our injectors will also be clear.
eric93SE is offline
Old 05-10-2006, 08:09 PM
sky jumper
if you use Techron or Gumout Regane (or really any solvent based FI cleaner) be sure to use them about 500 miles before an oil change. these are strong solvents and some will blow by into your crankcase, which is hard on the bearings. so best to use it, and then dump the oil.
Old 05-11-2006, 09:23 AM
2002 maxima se
OC guy's Avatar
I use maxlife (valvoline) is this any better?
OC guy is offline
Old 05-11-2006, 09:52 AM
'Trynna' is not a word
mtrai760's Avatar
I just use fuel power in every tank.
mtrai760 is offline
Old 05-11-2006, 03:33 PM
HallKemar
Anything that involves "valvoline" isnt good.
Old 05-11-2006, 03:34 PM
Need A Light?
steven88's Avatar
valvoline synthetic brake fluid is good...
so wut u gotta say about that?
steven88 is offline
Old 05-11-2006, 05:43 PM
JwaxMax99's Avatar
Ya, and Valvoline Racing 60 weight oil is good too, it's used by NHRA Top Fuel and Funny Cars, anything to say about that?
Never used Valvoline in my cars though
JwaxMax99 is offline
Old 05-12-2006, 09:18 AM
2002 maxima se
OC guy's Avatar
I've already used maxlife (valvoline) fuel injector cleaner twice....should I continue with MAXLIFE VALVOLINE or can i switch it to somthing better in brand and performance if yes then what would u recommend? if u say (techron) then does it has to be added before the oil change or after?
OC guy is offline
Old 05-12-2006, 09:42 AM
JwaxMax99's Avatar
Add the Techron, run out the full tank of gas, then do the oil change. by Silvermax.
Old 05-16-2006, 04:41 PM
TurTLe*'s Avatar
i throw in a BG 44k can whenever i feel like it. And also use the BG professial cleaning whenever i feel like it as well. It really doesn't do crap. I never did it before and then when i started i used it heavily to clean out w/e was there. I get the same MPG, i get the same idle, no change. I just feel a little better when i do it. Plus it free for me.
TurTLe* is offline
Old 05-21-2006, 09:37 PM
Correct. There are some reports that fuel injector cleaners change the viscosity of the motor oil, which is why you should use them just before an oil change.
There are other reports that when some of the cleaner fluid ends up in the motor oil they cause other problems.
So be safe and change your oil after you have run out most of the tank of gasoline that you put in your tank after adding the fuel injector cleaner. Also wait until you have filled that tank up again with fresh gasoline. Then do your oil change.
Old 05-24-2006, 10:38 AM
hellfyre's Avatar
I did the BG44k a few times when i got my car used. BG44k grave me slightly better mpg the first time. But I only use 93+ petrol and I agree with TurTLe, it hasn't made a difference since then that I could notice. I just feel like I did something good for the maxima.
My flatmate used it on his corolla and those guys fill in the cheapest petrol they can find. He put in a can of BG44K and his car was much more responsive. Better starting and MPG.
hellfyre is offline
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
fx4five
10-01-2015 04:58 AM
Quick Reply: how often we have to do fuel injection cleaning?
