Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 02-27-2006, 07:39 PM   #1
Nations 1st 6th Gen Turbo
chernmax's Avatar
Points: 21,076, Level: 91
Points: 21,076, Level: 91 Points: 21,076, Level: 91 Points: 21,076, Level: 91
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via Yahoo to chernmax
Need advice on an oil filter for a 2004 Nissan Max SE
Anyone have additional 411 on this type of filters for a 2004 Nissan Maxima 3.5L SE with a VQ35DE. Thanks
Click the image to open in full size.
ULTRA FILTER, lifetime direct replacement washable oil filter, designed from 6061 T6 billet aluminum, this housing has a 1500 lb crush rate. The washable filter is a deep pleated, duplex woven, 35 micron surgical T304 stainless steel filter for superior washablity. A self sufficient, environmentally friendly oil filter. That not only creates more horsepower, but extends oil change intervals from 3000 to 7000 miles. With all of todays aftermarket performance parts, Consumers should not forget about the most vital part of the engine, “the oil filter”. This is the lifeline of your engine. Adding performance parts to your vehicles engine creates more pressure in the oil filter, this causing your oil filter to swell and compress, damaging oil seals and putting large stress figures on your oil pump. Average HP gains are 5-6. Also with the engine running more efficient, you should see an average of 1-2 mpg. ULTRA FILTER, filters your oil an absolute 35 micron with one pass, utilizing our “quad flow technology”. With an average install time of 5-10 minutes this kit comes complete with everything you need to do the install. All filters carry a complete lifetime warranty and are good forever. This Filter is also transferable to any vehicle by changing the main insert. This insert is free of charge from the manufacture. ULTRA FILTER is truly the last oil filter you will ever buy!
ULTRA FILTERs revolutionary design is made with T304 stainless steel media therefore allowing it to be reusable and cleanable. Unlike paper filters, the Billet aluminum exterior gives a polished appearance to your motor.
Most paper filters only filter an average of 50-75 micron particles. ULTRA FILTER will stop anything to an absolute 35 micron. Remember, white blood cells are 25 micron.
Paper filters have a “Bypass” that opens at 12 lbs of pressure. Most motors idle at 11lbs of pressure. At 12 lbs, the bypass opens and filtering stops. All of the dirt and metals are then sent back into your motor. Paper filters only filter 10-20% of their actual life.
With ULTRA FILTER, oil changes can be extended to every 7,000 miles. This will save you time, energy and, most importantly, money.
__________________
Visit my Web Site at: http://www.cardomain.com/ride/668322 Stop Global Whining!!!
chernmax is offline   Reply With Quote
Old 02-28-2006, 04:10 AM   #2
JFP in PA
Waste of money. Pain in the butt to use. Biggest problems are leaks at the seals, and the tendancy for the thing to unscrew its sections when you try to remove it rather than coming off fully assembled. Just use a regular filter................
Old 02-28-2006, 04:38 AM   #3
chernmax's Avatar
Activity: 0%
Quote:
Thanks for the feedback...
__________________
Old 02-28-2006, 01:18 PM   #4
Points: 5,696, Level: 48
Points: 5,696, Level: 48 Points: 5,696, Level: 48 Points: 5,696, Level: 48
Activity: 0%
I'd also be leary of anyone claiming 5-6hp and 1-2 mpg from an oil filter. While I'm hardly a mechanic it doesnt seem possible.
RandyZ is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
