Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
FUel injector cleaner?
Old 09-20-2005, 01:56 PM
Nomad's Avatar
Can some1 reccomen good inhector cleaner but not the one u pour in gas tank.
Thanks to all in advance
Nomad is offline
Old 09-20-2005, 02:42 PM
kcryan's Avatar
if you mean the kind you hook up to your fuel rail, 3m makes one i believe, but why wont techron and or FP work?
kcryan is offline
Old 09-20-2005, 05:36 PM
Nomad's Avatar
which one is better?
Nomad is offline
Old 09-20-2005, 11:40 PM
SilverMax_04's Avatar
I know that Chevron's techron works for me. I put it in my tank about 500 miles before each oil change so that it has been burned up and done it work before changing the oil. I do this because there are reports that it has a tendency to increase the viscosity of the motor oil. Not certain I believe this, but why take a chance. Following this practice also provides me with a benchmark for cleaning the injectors on a consistent basis.
SilverMax_04 is offline
Old 09-21-2005, 11:00 AM
DTinVA's Avatar
The stealership wants to clean my injectors. Should I let them do this or will the Chevron Techron or other products do the same thing?
DTinVA is offline
Old 09-21-2005, 12:05 PM
A dealer clean is more extensive. I hope you are getting this under warranty. If you are paying for this service, I then suggest you try Techron before paying the much higher cost of taking the injectors out for more extensive cleaning.
Old 09-21-2005, 12:37 PM
Nomad's Avatar
Thanks guys will try to look for it @ lockal auto store. But i was thinking about connecting container with cleaner/fuel (50/50) directly to fuel line (in engine bay) and cleaning it that way.
Nomad is offline
Old 09-21-2005, 06:59 PM
jaedaliu's Avatar
wow, that's really concentrated. Would you be plugging in before or after the gas filter? I can't imagine a need for running that concentrated. You could run your car until it dies, then drop a bottle of it into your tank, then run your engine until it dies again, then fill up on gas. and you still would have been more dilute than running 50/50
jaedaliu is offline
Old 09-21-2005, 09:24 PM
Nomad's Avatar
I was thinkimg to do it after fuel filter it's in gas tank unlike in 4th gen. To stay away from all that dirt i couldn't even imagine i have in my fuel lines and i always keep my needle not less than 1/4. Is that S8it so strong? K will just try to pour it in gas tank. BTW Is techron better for injectors than seafoam? Having issues with MPG. last time i got like 120miles/half tank.
Nomad is offline
Old 09-23-2005, 08:56 AM
Bobo's Avatar
I just recently ran a bottle of Chevron Techron through my tank. You can only buy FP through www.lubecontrol.com. I understand that Gumout Regane is also a decent product.
Bobo is offline
Old 10-02-2005, 03:23 PM
Nomad's Avatar
Ok here's finally update. After i poured chevron thechron in one half empty tank driving my max like crazy for one week. My gas mileage went from 16mpg all city up to 19.3 all city. 3 miles improvement!!! not bad BTW i had to change my air filter have on it more 15k. will see how filter will improve anything.
Nomad is offline
Old 10-02-2005, 03:33 PM
Bobo's Avatar
You should be able to get more than 15K out of an air filter. My maintenance schedule calls for 30K replacement, but mine was toast at 22,500 and 45,000, then about 7,500 miles into my 3rd filter I switched over to a K&N air filter.
Bobo is offline
Old 10-02-2005, 05:08 PM
flthere's Avatar
i cleaned the throttle body yestday and bought gumout regane ... let's see how it works for me well, i already get abt 350 miles on 16 gallons 70% city miles ...
also ready to put auto-rx in ...
flthere is offline
Old 10-02-2005, 06:18 PM
Ford Only.
dmontzsta's Avatar
Alot of people slam the kind you pour down the tank. I have been using it forever on all my vehicles. Every oil change it is mandatory to me. I dont know if it is a coincidence, but I have never had injector failure. The 92-94 SEs are prone to it also. I am at 297k and been using it since I bought the car years and years ago, no problems, no replacements.
dmontzsta is offline
Old 10-02-2005, 06:43 PM
Nomad's Avatar
I know that it's time to replace it because when i had K&n cone filter different was like 5-7 miles more w/k&n on 1/4 of the tank.
Nomad is offline
Old 10-02-2005, 06:46 PM
Nomad's Avatar
i think 4th gen usually has better mpg.
Nomad is offline
Old 10-28-2005, 01:28 PM
eyecon7's Avatar
Yea 5.5 drinks like crazy
eyecon7 is offline
Old 10-28-2005, 01:55 PM
Bobo's Avatar
BG44K is supposed to be an excellent fuel system cleaner but it's on the pricey side.
Bobo is offline
Old 11-16-2005, 07:12 AM
ebaker's Avatar
Techron has 10% amine cleaner according to the MSDS. Regane has 30 - 40%. Regane looks like a better deal.
ebaker is offline
Old 11-16-2005, 08:09 AM
CCS2k1Max's Avatar
Got any links to the MSDSs?
CCS2k1Max is offline
Old 11-19-2005, 08:58 PM
99grnmaxgxe's Avatar
I just poured in a bottle of Chevron w/ Techron Fuel System cleaner in my Max, so far, I can feel a little bit more power, I'll post if there are any gas mileage differences later.
99grnmaxgxe is offline
Old 11-19-2005, 10:49 PM
VIP Maxima
i usually use lucas since its much cheaper. any experience with those?
Old 11-20-2005, 08:45 AM
Bobo's Avatar
I don't believe its spoken of very highly on BITOG. Stick with Chevron Techron, LubeControl FP60, BG44K or Gumout Regane.
You always get what you pay for in life!
Bobo is offline
Old 11-20-2005, 11:16 AM
Driving is the next best thing
DrKlop's Avatar
Has anybody used Nissan’s genuine fuel system cleaner?
DrKlop is offline
Old 11-20-2005, 04:29 PM
Bobo's Avatar
I've never heard of it. I don't go to the stealership any more, but they put a two-part fuel system cleaner in twice, a BG product called BG02.
Bobo is offline
Old 11-20-2005, 07:48 PM
Just calculated my mileage and with the Chevron w/ Techron cleaner, I got about 1/2 mile more. 21.5 mpg, before it was at 21, oh yeah, dunno if I'm crazy, but I think the cleaner made my car sound louder.
Old 11-21-2005, 06:51 AM
Bobo's Avatar
A 0.5 mpg increase in mpg is not statistically relevant. Report back after about 5 or 6 tanks of gas.
Bobo is offline
Old 11-23-2005, 04:39 PM
Burny's Avatar
I use Lucas and it does a great job.
Burny is offline
Old 11-23-2005, 05:19 PM
konak85's Avatar
Lucas and Chevron Techron work great. Just bought a bottle of Techron today at Autozone with a 3.00 mail in rebate, woohoo.
konak85 is offline
Old 11-23-2005, 07:43 PM
CCS2k1Max's Avatar
Speaking of Chevron rebates. I am still waiting for the ones I sent in about three months ago. I may have to file a complaint with Lisa Madigan.
Old 11-24-2005, 09:58 AM
RIP '98 Maxima SE
BlackCat's Avatar
Here's another question: I always use Chevron 92 octane with Techron. Is it still worthwhile to add in Chevron fuel injector cleaner?
BlackCat is offline
Old 11-24-2005, 12:06 PM
Probably not worth it, but it won't hurt.
Most major oil companies (like Chevron) put a larger dose of fuel injector cleaner in their premium gasoline than in the other grades, so you are probably OK.
Old 11-24-2005, 12:22 PM
Bobo's Avatar
I just used Chevron Techron before my last oil change for the first time. I ran Chevron 92 all last winter, but am now using Husky 90 octane at 87 octane prices and can't say I notice any difference in performance or fuel economy.
I may use Chevron Techron before every 2nd oil change going forward. Too much in the way of fuel additives is overkill, IMHO.
When I bought my tires at National Tire, I noticed they have a corner of the building that markets various products and they in fact do vehicle maintenance there now. They stock BG44K which is about $28, IIRC, and I might give that a whirl down the road. I haven't seen BG44K anywhere else locally and know its spoken of quite highly on BITOG. Perhaps this is a product that could be used say every 2 years.
Bobo is offline
Old 11-24-2005, 12:38 PM
RIP '98 Maxima SE
BlackCat's Avatar
Since I'm SC'ed I can't go lower than 92 octane or else it'll go kablooey.
BlackCat is offline
Old 11-24-2005, 12:44 PM
Bobo's Avatar
We wouldn't what you to go kablooey, lol! Stick with the Chevron 92. I'm not sure what 94 octane would do for you.
Bobo is offline
Old 11-24-2005, 02:00 PM
RIP '98 Maxima SE
BlackCat's Avatar
I can tell you that there's not much difference in feel.
BlackCat is offline
Old 11-25-2005, 03:00 PM
Virus's Avatar
If you want to spend the money, BG44K is about the best fuel cleaner available. Your probably looking at the $17-20 range for a bottle.
Virus is offline
Old 11-25-2005, 08:49 PM
Wow that's a lot! I paid for a bottle of Chev w/ Tech for $3 after rebate, lol.
Old 11-27-2005, 05:16 AM
CCS2k1Max's Avatar
If this info is still correct, BG44K is a waste of money.
OTOH, this is the "rebuttal" from a BG rep. Back in the day of PEA in the MSDS, it worked wonders for me. Have not tried it since.
Old 11-29-2005, 12:30 PM
Lives in a Maxima
Phoenix's Avatar
Isn't the Husky 90 ethanol-doped??
Phoenix is offline
Quick Reply: FUel injector cleaner?
