05-09-2005, 09:54 PM
Best Brake Fluid Brand/Type
What is the best all-around brake fluid brand and type? I live in Florida and I drive somewhat aggressive on roads. Car is daily driver and I like to go fast and stop quick . What can you guys recommend?
05-11-2005, 03:55 AM
ATE super blue. Peroid.
05-11-2005, 11:35 AM
The Definitive AE Master
not true.... if you really want the best with high wet/dry boiling point you go race inspired
motul 600
ap racing brake fluid
but since you drive on the street, just go with prestone or ATE
__________________
AP Racing BBK, TS ECU, ES everything, HIDs, Frakencar b-pipe, 18x9 F, 18x9.5 R
Stillen Intake, Y-pipe, STS, FSTB, and RSB, Fidenza Flywheel, SPEC Alum. PP, AP Racing Clutch
5spd Urethane Shifter Bushings!
click HERE !!
05-11-2005, 03:38 PM
Valvoline Syn DOT3/DOT4 brake fluid which is avaiable OTC.
05-13-2005, 06:40 PM
retired moderator
Points: 68,316, Level: 100 |
ATE Super Blue.
you can get it here: www.ogracing.com
__________________
Quote:
Originally Posted by Jeff92se
Again Irish the voice of reason in this coversation.
2000 Maxima SE (sold)
2009 Subaru WRX 280awhp/280awtq
1985 BMW 318i MR Rallycrosser
1970 Triumph GT6+
2008 4Runner SportEdition
The final "mod list" for the maxima (or at least most of it) LINK
The current mod list for the WRXLINK
05-15-2005, 05:05 PM
Quote:
motul 600
What do you mean "since you drive on the street" ?
Are you saying just to get ATE because it is cheaper? Is Motul 600 actually better but it's just more money?
Also can you buy Motul 600 locally at auto parts stores?
05-24-2005, 11:00 PM
I miss my VE
dot3 STP brake fluid isn't bad. i've been havin a brake fluid leak for a long time, and i buy the cheapest stuff and works great
__________________
For Sale: 162k mile stock VE crank pulley, used HELLA horns, brand new aftermarket VG fuel pump, and a used right rear window motor. Also VE MAF sensor and mint VE fog light assembly. If you need any of these, please let me know
http://forums.maxima.org/1st-3rd-gen...-new-more.html
06-22-2005, 08:26 PM
retired moderator
ATE blue is a race fluid, technically...it has a very high boiling point. But...it's also good for street use because of low water absorption (many race fluids absorb water quickly)....I've used it for years for both daily drivers and for autocross/road racing cars, never a problem.
The brake fluid will not "make your car stop faster" for regular driving though...the boiling point only really comes into play with constant, repetitive high speed braking.
__________________
1970 Triumph GT6+
06-23-2005, 10:31 AM
Alright first off i agree with the vote for Valvoline Syn Dot3-4, i bet that will serve your needs great.
To adress the subject of water absorption, you want your brake fluid to absorb water, although it lowers your boiling point and makes you change it more often, without it your going to have mega rust in your expensive ABS (or non ABS but still expensive) parts.
06-23-2005, 12:06 PM
Do I get a tax break?
Please explain this further... how does water help prevent rust? I would think that as the brake fluid absorbs moisture (since its hygroscopic), the changes of rust is higher with the older fluid, not with fresh fluid... what am I missing
06-23-2005, 12:10 PM
I'm needing a caw
Points: 41,433, Level: 100 |
The better question is. If the fluid never absorbs water, how would it rust??
I think he's referring to other brake fluids make you change it often as they absorb more water. Thus always having newer fluid in. But he's reasoning is flawed regarding the rust issue.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
06-23-2005, 12:25 PM
Getting back to his roots
Points: 11,286, Level: 70 |
If the fluid didn't absorb water, then the water would form a second liquid phase in your brake lines, and that aqueous phase would probably be more apt to cause rust formation than if the water were absorbed into the brake fluid itself.
06-23-2005, 12:46 PM
I'm needing a caw
Well assuming he's using Dot3,4 or 5.5, it will absorb water. Unless you are refering to the all silicone dot 5, which is a no no
And as long as the additives on the fluid are new, it's not a problem. But as the fluid gets old, the additives wear out and can no longer prevent rust/corrision from occuring
Quote:
06-23-2005, 09:05 PM
Thats what i meant, sorry for the confusion.
06-23-2005, 09:43 PM
STFU n00b!
Points: 40,020, Level: 100 |
hard and fast numbers, so people can stop pissing in the wind:
Wagner 21B DOT 3
Dry, 401 F
no data on wet
Wagner ABS Blend DOT 4
"exceeds DOT 4 standard of 446 F"
Castrol GT-LMA DOT 3/4
Dry, 446 F
Wet, 311 F
Valvoline Synthetic DOT 3/4
Dry, 480 F
wet, 330F
Wagner Severe Duty DOT 5.1
Dry, "over 500 F"
AP Racing AP551 DOT 3
Dry, 527 F
Wet, 302 F
AP Racing DOT 5.1 fluid
Dry, 527 F
Wet, 363 F
(non-silicone based. WILL mix with dOT 3 and DOT 4 fluids)
ATE Superblue DOT3/4
Dry, 536 F
wet, 392 F
AP Racing AP550 "exceeds DOT standards"
Dry 550 F
no data on wet.
Ferodo Formula Racing - DSF 050A DOT 5.1
Dry, 572 F
"WARNING: FERODO FORMULA RACING IS NOT RECOMMENDED FOR NORMAL ROAD USE."
AP Racing AP600 (no info on DOT certification)
Dry, 590 F
Wet, 410 F
NOT suitable for systems with magnesium parts. chemically reacts with magnesium to produce gas. All old fluid must be purged from system and then system flushed with AP600 before being filled completely and bled.
Motul RBF 600 DOT 3/4
Dry, 594 F
Wet, 421 F
Castrol SRF DOT 3/4
Dry, 590 F
Wet, 518 F
AP Racing PRF660 DOT 4
Dry, 608 F
Wet, 390 F
Prospeed GS610 DOT 4
Dry, 610 F
Wet, 421 F
Sources:
http://www.apracing.com/car/brakefluid/dataselect.asp
http://www.speedwaremotorsports.com/access/fluid.asp
http://www.saferacer.com/gsrabrfl.html
http://www.federal-mogul.com/vgn/ima...ageback.OL.pdf
also have several bottles of various brands on hand to read the labels.
06-23-2005, 10:18 PM
STFU n00b!
Now for a translation of all those numbers..
for street driving, ANY of those fluids will be fine.
for agressive street driving, the Castrol GT-LMA would be the lowest temps I suggest.
for track use, the Castrol GT-LMA is also usually going to be fine for stock calipers and streetable pads (Axxis MM, Hawk HPS, Porterfield R4S, Bendix, Wagner, Raybestos).
for higher temp use where you start to experience pad fade on the above mentioned pads, then I suggest bumping up to the Valvoline Synthetic fluid. for any true BBK or race pad (Hawk HP+ or Black, Axxis Ultimate, Carbotech, Ferodo, Wilwood, AP, Brembo, Porterfield R4 or R4E, etc), then the minimum I suggest is the Valvoline.
I used the valvoline a couple weekends ago at TWS. My 13" wilwood setup had the brakes hot enough to turn my rotor hat mounting bolts blue and melt the wheelweights off the inside of my wheels, and I never experienced brake fade of any sort. They just kept getting better. So honestly, there's not much a Maxima can do on street tires that will need anything above the Valvoline.
If you can boil that fluid on anything but a full blown road course and NOT get arrested doing it, then I'll buy you a can of ATE superblue.
06-24-2005, 06:57 AM
Matt,
I think this needs to be added to the fluids/lubricants stickies across all the forums - your last two posts are very informative (to put it lightly).
Thanks!
06-24-2005, 07:59 AM
STFU n00b!
Just bored last night and didn't want to go to sleep.
MaximaOrg
Nissan Maxima
Paid Advertisement
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
