Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Just cleaned intake manifold +++
Old 10-24-2004, 04:34 PM
  #41
Mauja He Mauja
ZIPPIN's Avatar
A more clear pic of the hose::
ZIPPIN is offline
Old 10-24-2004, 10:38 PM
  #42
ThunderMaxi's Avatar
Originally Posted by soonerfan
Background
I regularly clean my throttle body by removing it so I can clean both sides and I use BG44K to clean injectors, etc. I have been wanting to clean the intake manifold since I was cleaning the two main things on either side of it.
I looked around to get info and pricing - dealership charges $100+ and most auto shops charge $80+
Well I found some stuff called Sea Foam for $6 and used it. It is supposed to "Clean carbon build up, Clean intake valves and pistons, Give smoother idle, Clean catalytic converter odors , Cure hesitations and pings, and Restore power and pickup" http://www.seafoamsales.com/motorTuneUp.htm
It is not carried by most auto part chains (advance, autozone, etc) I got it at a local place (for local N VA guys - Fairfax Auto Parts)
How to use it
1. Run car to normal operating temp.
2. Disconnect brake booster vacuum line (big hose that connects to brake master cylinder)
3. Pour liquid into a paper cup (makes it easier to handle)
4. Start car
5. Dip vacuum line into cup of fluid (do not just stick it in and leave it, it will kill the car. dip it it for a few seconds until you hear the car about to die then take it out. repeat this until you are done. i used the suggested amount which is 1/3 of the bottle)
6. Turn off the car
7. Let sit for five minutes (the liquid will eat away at all the dirt and carbon in the intake manifold, cylinders, valves, etc)
8. Reconnect brake booster vacuum line
9. Start car (you will see ALOT of white smoke coming out of the exhaust, that is all that nasty cr@p coming out. mine had 88K miles worth of nasty cr@p!!!)
10. let car run at about 3K RMPs for a few minutes to get everything out.
My opinion -
AMAZING. Throttle response is quicker then it ever was (car had 50K miles on it when I bought it) Start up is quicker and smoother. Idle is more smooth and quiet. Drives like a new car. I wish I could see the inside so I could see how clean it was.
I recommend that everyone do this. If you have any questions let me know.
Im going to do their Trans-Tune next!! http://www.seafoamsales.com/transTuneConsumer.htm
HAve you done the Trans yet? I just got my tranny fluid changed, but I am not sure how this would work for it...
ThunderMaxi is offline
Old 12-15-2004, 08:49 PM
  #43
Santa29's Avatar
Hi, just did it to my car, but the service engine soon light has came on, what should I do??? Should I just disconnect negative battery cable and let ECU restart, or did I do something wrong, HELP!!!!
Santa29 is offline
Old 12-16-2004, 12:39 PM
  #44
Jatan's Avatar
Did you unplug anything that you forgot to plug back? Check the codes to see what it is and then reset it
Jatan is offline
Old 01-02-2005, 01:12 PM
  #45
2000 Maximus's Avatar
thanx for the write up soonerfan,
i need to do this too but unfortuntly just did an oil change today.
hopefully it will clean out some crud from my car.
2000 Maximus is offline
Old 01-02-2005, 09:57 PM
  #46
dkotanto's Avatar
From bobistheoilguy.com forum:
"A part of the reason Seafoam "seems" to work is that it has volatile solvents in it....when they are absorbed by the carbon and other surfaces in the intake tract...they richen the mixture for awhile and make the car run smoother.
Not saying that Seafoam doesn't clean...but this is part of the reason it runs better right after it's put into the intake."
dkotanto is offline
Old 01-07-2005, 12:38 PM
  #47
Unsuccesful STL Coordinator
Epacy's Avatar
I am sure Seafoam isn't the only engine liquid product to have the "volatile" solvents.
Epacy is offline
Old 01-29-2005, 04:09 PM
  #48
TEEdotMAX's Avatar
stupid questions....
should i avoid using seafoam & a fuel system cleaner together??? maybe wait a couple thousand miles after using seafoam to use a fuel system cleaner??? which should i use first?? or does it not matter?
TEEdotMAX is offline
Old 02-27-2005, 04:28 PM
  #49
danyboie's Avatar
like santa29, i used seafoam and my "check engine soon" light came on. the light came on after driving about 10 miles. can anyone offer any suggestions as to what the problem is? i changed my oil and filter after using seafoam as well. any help would be appreciated!
danyboie is offline
Old 02-27-2006, 08:17 PM
  #50
6spd Swapped
OHH NOES's Avatar
The only thing anyone can really tell you at this point is to get the codes pulled, without the codes no one can know why the light came on.
OHH NOES is offline
Old 02-27-2006, 10:35 PM
  #51
1FSTMX
I'm not sure some little cleaning will make a noticeable difference in engine response. Preventative maintenance is good though.
Old 03-01-2006, 09:04 AM
  #52
vsamoylov
seems very interesting. question about pouring this into the gas tank. how much?
Old 03-01-2006, 02:34 PM
  #53
THIS IS...
alpinestars™'s Avatar
Ok, I just got my can Of Seafoam from Autozone. I want to to this treatment now, but how long can you wait until you need to change your oil? Can I wait a few days or should I do it immediately?
alpinestars™ is offline
Old 03-01-2006, 03:48 PM
  #54
Jatan's Avatar
If you're putting it in your oil then change the oil within 100-200 miles (everyone has diff opinion on how long you should keep it in there)
If you're sucking it into the brake booster then why change the oil?
Jatan is offline
Old 03-03-2006, 01:21 PM
  #55
RR5
RR5's Avatar
Oh man not the horrible ICS idle rpm higher than expected DTC. That would be code P0507.
I got this BS after someone told me to clean the throttle body. I ended up having nissan look at it, they made it worse and just finally bought a used throttle body. Nissan had to run the Idle air volume learn with consult II.
I am worried about trying this and ending up having to replace the throttle body again.
- No updates about what DTCs are being pulled after trying the sea foam? I imagine it might be something along the lines of an O2 sensor not reading right because the Air/fuel ratio might be off from using the sea foam.
RR5 is offline
Old 03-07-2006, 09:58 AM
  #56
danger300z's Avatar
can wait to try this
danger300z is offline
Old 03-07-2006, 10:02 AM
  #57
It's business time.
Progress's Avatar
It should bypass your TB if you run it through the brake booster.
Progress is offline
Old 03-07-2006, 02:32 PM
  #58
STFU n00b!
Matt93SE's Avatar
don't waste your time dumping it into the intake manifold unless you have EGR or IACV problems. the stuff just rinses off deposits that normally accumulate in the IM and don't really cause any difference in performance. if your IACV, TB, EGR, etc have problems sticking because of deposits, then you need to look at the health of the engine anyway.. you will probably have an issue with excess oil blow-by causing the PCV valve to dump tons of oil into the intake tubing. that stuff is what causes the big issues..
Cliff's Notes:
If your engine is healthy and running okay, don't waste your time.
Matt93SE is offline
Old 03-07-2006, 03:58 PM
  #59
Driving is the next best thing
DrKlop's Avatar
Cliff's Notes:
are you saying that all those people who tried it and saw an increase in performance had engine problems?
DrKlop is offline
Old 03-24-2006, 06:17 AM
  #60
It's business time.
Progress's Avatar
Cliff's Notes:
Yes, please unpack this more. It seems your opinion is the only one that is in disagreement with the rest and it disturbs me because you are quite knowledgeable.
Progress is offline
Old 03-24-2006, 07:01 AM
  #61
nismology's Avatar
Just for everyone's info, seafoam doesn't even come close to cleaning the inside of the intake manifold, at all. The only way to really clean it is to hot tank it some other parts cleaner that shops have using heated mineral spirits. Ditto intake valves...
And in case your wondering, yes i'm speaking from experience. I used it, removed the upper manifold and it looked dirty as ever. Same with the lower manifold and intake valves when i flashed a light down there.
nismology is offline
Old 03-24-2006, 08:31 AM
  #62
It's business time.
Progress's Avatar
So what carbon does seafoam clean up? Also, is the white smoke out of the exhaust just Seafoam and not "dirt"? Are all improvements placebo?
Progress is offline
Old 03-24-2006, 01:05 PM
  #63
Shiver me timbers.
maxfanfromohio's Avatar
Oh yeah that's it! Tell me I'm knowledgeable again. Tell me while I'm sticking this in your azz.
maxfanfromohio is offline
Old 03-24-2006, 01:19 PM
  #64
It's business time.
Progress's Avatar
Oh man. You made me just about lose it.
Progress is offline
Old 04-30-2006, 06:04 PM
  #65
HallKemar
I Just Bought Some Sea Foam And I Can Not Wait To Do This Tomorrowwwwwwwwwwwwwwwwwwwwww
Old 05-01-2006, 12:28 PM
  #66
HallKemar
i did the treatment, my car runs orgasmicallyyyyyyyyyyyyyyyyyy
Old 03-01-2007, 06:16 AM
  #67
Cletus
SoonerFan's Avatar
bringing this to the top since there have been a lot of seafoam threads in the 5th gen forum lately.
SoonerFan is offline
Old 06-07-2007, 09:39 AM
  #68
overbo0st2k4's Avatar
runs great
I just did this yesterday on my 98 SE with 155k on it and my buddy's integra and they both run great! I could feel a smoother idle after the first startup and a slight difference in the throttle response.
Thanks for the tips!
overbo0st2k4 is offline
Old 06-14-2007, 06:43 PM
  #69
jattdemaxima's Avatar
whats the best intake, injen or berk?
jattdemaxima is offline
Old 07-24-2007, 01:22 PM
  #70
pyroz's Avatar
when you say let the car run at 3k, do i put it in park and rev it up to 3k? if that is the case, will it damage the engine?
pyroz is offline
Old 07-24-2007, 04:37 PM
  #71
spdfreak's Avatar
First: Does driving up a big hill on the highway at 3k RPM break your engine?
Is the moon whole?
Well it's not great for the engine, but if thats what it take, then thats what you do.
I haven't realized a great differance in anything so far. I think it's more in the head than in the car, not that I'm saying that theres no differance, there is, but minimal.
spdfreak is offline
Old 07-24-2007, 07:32 PM
  #72
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 07-24-2007, 08:04 PM
  #73
spdfreak's Avatar
In addition to what you said:
:attention
spdfreak is offline
Old 06-08-2008, 01:44 PM
  #74
Solebreaker's Avatar
i know this is a old thread but can you repost the pictures so i know where to put the stuff?
Solebreaker is offline
Old 06-08-2008, 10:16 PM
  #75
hi-tek22's Avatar
im bringing this thread back because i just purchased some sea foam to run through my 01 max with 102k miles........
Hey sooner or ANYONE, where is the break booster line i need to look for on my 2001?
hi-tek22 is offline
Old 06-09-2008, 08:04 AM
  #76
ajcool2's Avatar
Look on the passenger side rear of your intake manifold theres a hose connected to a nipple on the corner of it.
ajcool2 is offline
Old 06-09-2008, 06:52 PM
  #77
hi-tek22's Avatar
AHHHH, ok gotcha....i appreciate it...will do this tomorrow
hi-tek22 is offline
Old 07-03-2008, 06:50 AM
  #78
rhonster's Avatar
SeaFoam is available in Canada at CarQuest. Other places may have it, but, more expensive for the same tin.
rhonster is offline
Old 07-03-2008, 08:41 AM
  #79
wyche89's Avatar
to everybody considering seafoam... i'm not saying it doesn't work, because i've never tried it.. but just BE CAREFUL and make SURE you do it right.. LOTS of people have had problems in doing this seafoam incorrectly and having their car run poorly
wyche89 is offline
Old 07-03-2008, 08:47 AM
  #80
rhonster's Avatar
maybe the issue is where do you disconnect the vacuum line? is it at the Brake Booster itself so the SF goes back into the line away from the booster or do you disconnect the line where there is enough hose to allow the SF to go into the Booster? My thoughts are the former, but, a mistake could be made...
rhonster is offline
Quick Reply: Just cleaned intake manifold +++
