Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Castrol Syntec..ask the expert gobbledy gook
Old 02-12-2004, 10:18 AM
rcy
rcy's Avatar
So...I went to castrol.ca and they have a link called 'ask the expert'. I'll bite, I thought, and asked if Castrol 0W30 was a true synthetic. Specifically, in my question I asked if the 0W30 was a PAO oil or a 'hydrocracked' oil. Here is the 'expert' answer: Your guess is as good as mine as to whether the 0W30 (made in Germany) Syntec is a PAO or not.
___________
Castrol Syntec is a 100% fully-synthetic motor oil, as is the Syntec
0w-30 available from Germany. Synthetic motor oil starts with synthetic
base oil. There are many different chemical processes available to make
synthetic base oil due to advances in the technology of synthetics.
These chemical processes are different than the simple refining
techniques used to make conventional base oils. For conventional base
oils the process is simply a separation and subtraction process. Once
the base oil is separated, the subtraction process cleans and removes
impurities and undesirable compounds, such as wax and sulfur.
Synthetic processing uses select crude components that are chemically
converted to create molecules that are different from the starting
material. Synthetic processing rearranges, builds up and breaks apart
molecules.
This chemical processing produces synthetic base oils that are
engineered to provide consistent and predictable superior performance
over conventional base oil counterparts. Synthetic base oils exhibit
superior performance at both extreme hot and cold temperatures.
Synthetic base oils are then mixed with specialized additive systems
that can be engineered to meet more demanding performance specifications
than what is achievable from conventional motor oils. The combination
of synthetic base oils and choice additive systems offers many benefits
for your engine.
Consumer Relations
Castrol North America
1-800-462-0835
castrol@idea-factor.com
-----Original Message-----
Sent: February 10, 2004 6:15 AM
To: castrol@idea-factor.com
Subject: Ask The Expert
Date Created:
2/10/2004
Prefix:
Mr
Year, make , model, and mileage of your car (optional):
Year:
1992
Make:
Nissan
Model:
Maxima
Current mileage:
184000km
Comments:
Can you tell me if the 0W30 Syntec that states 'made in Germany' on the
back is a true synthetic. That is to say, is it a PAO oil, or a Type
III hydrocracked oil? If it's not, does Castrol make any
'true' (PAO) synthetic oils?
Thanks.
Who changes the oil in your car:
DIY
Do you currently use any Castrol products:
yes
Which of the following products have you purchased in the last 12
months:
Syntec, Superclean
rcy is offline
Old 02-12-2004, 10:57 AM
Getting back to his roots
Mizeree_X's Avatar
Sounds to me that they take a cut of the crude and react it to produce a more consistent set of molecules in the mix, whereas a conventional oil is merely a very-refined cut of the crude (aka no reactions involved). My feeling is that this is inferior to taking pure PAOs and then adding additives, but I'm not an oil expert, just a chemical engineer.
Mizeree_X is offline
Old 02-12-2004, 01:35 PM
iwannabmw's Avatar
PAO's are better.
iwannabmw is offline
litch
123
01-04-2024 07:01 PM
Pnjboyzz
11-16-2015 12:27 PM
Pnjboyzz
09-21-2015 12:41 PM
robtroxel
09-08-2015 08:15 PM
Quick Reply: Castrol Syntec..ask the expert gobbledy gook
