Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-25-2008, 06:59 AM   #281
One thing I learned from talking to a repair shop once, and it worked great for me, was to just skip the rad drain plug and just pull the lwr hose. Fast, easy, and don't have to worry about stripping the plug or anything. Can make a little mess, but after doing it this way a few times you'll get the hang of it to do it w/out a mess.
Also, if you do it this way, keep in in mind that if you just idle the car a bit between drain/fills then you don't have to put the hose all the way on...just put it on like 1/2 way or less, and it holds water just fine while you're just idling in the garage. Of course, put it on all the way when finished, but it makes it easier pulling the hose off/on since it sort of sticks to the plastic rad outlet thingy quite a bit.
MichMaxFan is offline   Reply With Quote
Old 06-25-2008, 08:35 AM   #282
kgallerie's Avatar
Yeah, I have heard that.....but that also involves removing those f***ing plastic splash guards under there which I avoid at all costs.....those things are the biggest PITA ever......
kgallerie is offline   Reply With Quote
Old 06-26-2008, 06:19 AM   #283
Quote:
LOL, yes, they are a pain, but it's less risk/pain to me than messing w/ the rad plug. I've heard too many stories of them going bad/leaking and at least for me, it's just easier to pull the plastic trim and do it via the hose.
Old 09-10-2008, 01:44 PM   #284
Burn Dust. Eat my rubber.
SgtSchulze's Avatar
86k on my 02 and the radiator finally cracked. The plastic tank cracked at a seam in the plastic. I am replacing it with an OEM all metal (Aluminum) and dumping the plastic tank version. Dealer wanted $400 for a new radiator. Found it online for less than $200.
I plan to use either Toyota Red or Nissan Green. This thread was a ton of help. Thanks!
__________________
Go: FSTB, GAB w/ K&N, Tein H-Techs, Tokico Illuminas (3F/4R), Slotted/Drilled Irotors, 6th Gen BBK, Frankencar B-Pipe, Cattman Rear Section, Blehmco Hypergrounding, NWP Spacers
Show: AE Sills & Pedals, 350Z Dead Pedal, 350Z Horn Mod, 18x8 Axis Spiders w/ Nitto 555's (FOR SALE), G2 Painted Calipers, Rewired Fogs, Alpine 9835, Alpine Amps, Rainbow SLC's, Infinity Basslink, KnuKonceptz Wires, Blacked Out HID's
SgtSchulze is offline   Reply With Quote
Old 09-11-2008, 10:19 AM   #285
Pointy Elbows
00MaxSE's Avatar
Send a message via AIM to 00MaxSE
Heya Chuck.
Did you ever flush your coolant beforehand? I'm at 80.5k. Using the Toyota Red. I should probalby flush it this year. It's been 2 years since I did it.
00MaxSE is online now   Reply With Quote
Old 09-11-2008, 11:03 AM   #286
SgtSchulze's Avatar
Quote:
Originally Posted by 00MaxSE View Post
Heya Chuck.
Flush?? Nope....one part of the preventive maintenance that I neglected. That could explain the crack or it could have been the Nismo rad cap.
I picked up a gallon of the Toyota Red. $ 22.00 a gallon here in C-bus. Nissan Green @ a local dealer was also $22.00 a gallon. Toyota dealer was closer.
I'm replacing the radiator tonight.
__________________
Old 09-11-2008, 07:45 PM   #287
Pointy Elbows
00MaxSE's Avatar
Ah nice. I have the same cap.
Yeah the coolant was pricey. I think I paid around that too.
I'll hit you up if I need to replace mine. You replacing your hoses too?
Old 09-11-2008, 08:31 PM   #288
SgtSchulze's Avatar
No...everything else looked fine. The tranny cooler lines are a pain. Took me 7 gallons or so to flush the entire system.
The radiator is pretty easy to pull. Once you pull the fans....it's a cake walk.
__________________
Old 09-11-2008, 08:37 PM   #289
Pointy Elbows
00MaxSE's Avatar
Ah yeah I remember I had to flush quite a few gallons of distilled water when i did mine.
Good to hear that it's easy to do though. Did your boyz help out?
Old 12-06-2008, 01:17 PM   #290
What's the major pain of removing the splash guards?
What's the worst part of removing those? Is it just time consuming, or tricky? I have a slow antifreeze leak I can't readily see, so I was planning to take those off to find it...until I saw this post. In 35-45 degree weather, I might let a pro look for it instead, if it's that frustrating.
Lizziebeth13 is offline   Reply With Quote
Old 12-06-2008, 01:25 PM   #291
Pointy Elbows
00MaxSE's Avatar
Quote:
It's getting those snap in fasteners to go back in like they're supposed to without breaking any.
Old 12-06-2008, 01:42 PM   #292
Ahhhh...
Heh. I know exactly what you mean from working on my "old" 240sx. Different area of the vehicle, same kind of frustration! Somebody else seems to have had that problem already, as there's only a couple remaining. Sheesh. Guess I'll have to be extra careful.
Thanks for the quick response. Sigh, will get started on it in the morning.
Old 12-06-2008, 03:07 PM   #293
Pointy Elbows
00MaxSE's Avatar
Sure np. Good luck
Old 12-27-2008, 11:54 PM   #294
I'm a newbee here, but this what I did. Run the car , put the heater on , drain the coolant from the bottom ,while the car is running with the heater on I put the hose on the radiator flushing the coolant for at least five minutes. turn off the car & let the rest of the coolant drain from the radiator ,close the the plug from the bottom of the radiator & fill it up with the 50/50 antifreeze(prestone) drive the car & tap it off later.
maxkid is offline   Reply With Quote
Old 06-09-2009, 10:27 PM   #295
I found Nissan coolant for 19.99
Hayward Nissan in Hayward, CA has it for 19.99
I went to Carquest for Toyota Coolant - they wanted 39 USD for it.
I recall having paid 30 or so bucks 2 years back.
mbhang is offline   Reply With Quote
Old 06-11-2009, 10:21 AM   #296
Zerex Extremelife seems silicate free
http://www.whitfieldoil.com/download...ineupChart.pdf
The Extreme Life coolant seems to be the kind that will be a good substitute for OE. Napa stores stock this coolant.
Old 08-29-2009, 06:47 PM   #297
Quote:
you can buy it at nissanpartsonline dot net for $17-$18 per gallon - just ordered myself.
at the local dealer (NJ) it costs around $31.
fessa is offline   Reply With Quote
Old 09-21-2009, 12:31 PM   #298
Quote:
Originally Posted by bill99gxe View Post
I would go with Toyota or Honda OEM on a foreign vehicle. Yeah, you pay $14/gallon, but you don't worry about issues down the road.
More importantly, flush the system REAL well with distilled water first, then drain the entire radiator and fill with 100% antifreeze. This guarantees you the 50/50 recommended mix.
I have a 98 Max original rad that has been flushed every two years with the Prestone regular stuff. I want to use the Toyota Red, so should I be more diligent in clearing out the old Prestone?
Drain the old anti-freeze and substitute with distilled water or
How about running your hose continuously until it appears all clear?
And once clear, its assumed 50% capacity is already just water and just topping up with Toyota Red brings to about 50/50?
holymoly is offline   Reply With Quote
Old 10-06-2009, 11:48 PM   #299
Just a note you guys can buy nissan coolant online from courtesyparts or any nissan dealer that sells parts online. You'll never find it listed as "coolant" or "antifreeze" though so you have to look it up by part number 999MP-AF000P
its listed as "LONG LIFE ANTIF"
courestyparts.com sells it for $18ish
so does infinitipartsusa.com
if you are just flushing with distilled water and then filling the radiator with 100% antifreeze, you just need one bottle.
Col Ronson is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
