Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-23-2004, 12:58 PM   #41
Evil Administrator - "The Problem"
bill99gxe's Avatar
$18.95????? Good grief.
bill99gxe is offline   Reply With Quote
Old 01-23-2004, 04:28 PM   #42
Quote:
Yup. That's right. My dealer rounded it off to an even $19. Thief!
I'm glad to hear about $12 Toyota red. May try it next.
knapp9 is offline   Reply With Quote
Old 01-24-2004, 10:39 AM   #43
bill99gxe's Avatar
Yeah, if Nissan coolant is nearing $20/gallon people here would be insane to give them that business.
Old 01-24-2004, 11:37 AM   #44
ME RWD FTW!
Colonel's Avatar
Send a message via MSN to Colonel
Ok
Just because this is now a sticky I am going to record time and materials so that people can gauge what they need.
1) 2 Gallons of Toyota Red OEM. 11.95 X 2 = 23.90
2) 5 Gallon Catch pan with drain = 5.99
3) AntiFreeze Tester 2.99 (Prestone) = 2.99
4) New funnel = .99
5) Easy pour spiggot = .99 (worth like a billion dollars..NO SPILL!!!) I used this on my 5 gallon drain to pour back into the gallon jugs my used AF/water.
6) 8 gallons of DISTILLED water @ .73 a gallon = 5.84
Total: 40.70 (youll have to add your local tax of course)
So far I have about 1.5 hours in it. I have
1) drained original til it does not drip
1a) while draining rad, I cleaned reserve tank with DISTILLED water only. No soap. Just heavy shaking and rinsing...used 1 gallon to complete this thoroughly.
2) ran some distilled water through with drain still open.
3) fill slowly...stopping periodically to squeeze lower rad host to burp it.
4) capped off and ran car with heat on.
5) cooled for 5 minuts
6) drained radiator until it does not drip.
7) repeated steps 3-6.
I will come back and update this when I am finished for total time.
UPDATE: I eventually ended up flushing 10 total gallons through the system to get it clear. (Anal retentive) Probably could have gotten away with 8.
I spent 3 hours doin this. Most of the time was spent waiting for the rad to drain so I could refill it, drive a bit and then drain it. Over all...VERY easy. Just time consuming as I had NO mess to clean up afterwards
Colonel is offline   Reply With Quote
Old 01-24-2004, 02:37 PM   #45
Send a message via AIM to packetattack Send a message via Yahoo to packetattack
I've been running Dex Cool (the orange colored one) for about 3 years now. Of course I did a complete flush before I switched over.
Didn't know that there are new coolants out. I'll have to take a look at them.
Quote:
Originally Posted by edwardh1
What goes into a 99 Maxima?
greeen ( old kind) antifreeze or red (new kind) antifreeze?
owner's manual says use only Nissan or equal - no spec given!!!!!
packetattack is offline   Reply With Quote
Old 01-25-2004, 04:04 PM   #46
ME RWD FTW!
Colonel's Avatar
It does not show a washer that I saw, did I miss it?
hey Ed...I did my flush and fill this weekend and the "o-ring" is incorporated into the drain neck. Its not on the plug itself. When you screw it back in, you can hear the "squinching" noise. I also took a flashlight and poked my head up there....Its in the neck.
Old 01-25-2004, 06:26 PM   #47
i heard thatgm is having problem with the dexcool
something about have it crystallized. shurgs?
outsider is offline   Reply With Quote
Old 01-25-2004, 08:27 PM   #48
Send a message via AIM to JaTaN Send a message via Yahoo to JaTaN
Straight from the link I posted:
Left: Install the rad drain plug. Make sure the rubber washer is in place. (indicated by arrow)
Right: Check the rad cap for any tears in the rubber. Using a clean rag, wipe off any foreign matter on the rubber seal. Gently lift up the metal "hat" as shown by the arrow, and wipe off the "hat" and rubber under the "hat" This is the valve the allows coolant to enter the rad, from the reservoir bottle as the car cools.
JaTaN is offline   Reply With Quote
Old 01-26-2004, 07:38 AM   #49
ME RWD FTW!
Colonel's Avatar
But if its like mine its NOT on the drain plug. Mine was stuck inside the neck. Since he did not see it, that was the clarification he was looking for.
Old 03-06-2004, 09:54 AM   #50
Here is why the 2002 - 2003 (possibly other models) do not have the same rubber washer as on motovate.com.
There is a rubber o-ring on our plugs.
2002 Maxima SE is offline   Reply With Quote
Old 03-07-2004, 03:55 PM   #51
Send a message via AIM to DMad8724
Does anyone have a picture of the Toyota Red/Honda Blue? This way when I go to get some I'll know I'm getting what I need.
DMad8724 is offline   Reply With Quote
Old 03-07-2004, 04:09 PM   #52
Toyota says Toyota on the bottle.
Old 03-07-2004, 04:33 PM   #53
Quote:
Look up bob is the oil guy
they have a section on coolants
one or two of the topics have pix of the toyota red factory jug
edwardh1 is offline   Reply With Quote
Old 03-12-2004, 07:38 AM   #54
Do it the right way
My two-cents:
I prefer to utilize a Prestone "drain and fill" adaptor. It allows you to flush the system via a water hose (t-adaptor) connected in-line with the heater hose. This gets all the nasties out andd you can actullay see the water run clear as it is forced out of the radiator filler. I like to add a concentrated cleaner in with tap water and run the engine for about 5-10 min. After that, drain. Fill with 2 to 3 changes of distilled water (as mentioned above). After final drain, add 100 percent coolant. The Prestone kit is $9-10 at Wal-mart. You can monitor concetration via a coolant gage (AntiFreeze Tester) to check if its reached your desired percent. To modify, drain a little and add back di water or coolant depending on which way you want to go. Run engine 5 min check again.
Maybe anal, but I frickin' hate changing water pumps in late model maximas.
So is it Zerex G05 that most like? I wasn't aware of the Dex Cool problems
Joe
joecraps is offline   Reply With Quote
Old 03-12-2004, 08:34 AM   #55
[quote=joecraps]My two-cents:
II put in nissan green OE stuff.
the old one after 5 years look great
so keep using it
$15 a gal
used 1 gal
Old 03-12-2004, 10:25 AM   #56
[quote=edwardh1]
Quote:
Originally Posted by joecraps
My two-cents:
so keep using it
$15 a gal
used 1 gal
Where did you buy it from? Is it in a Nissan bottle? I went to my local dealer and they only had orange Nissan AF. For green they use Prestone.
Zero Deuce SE is offline   Reply With Quote
Old 07-24-2004, 12:52 AM   #57
Not a GM sack rider...
Do not run 70/30 or any other mix ratio, only 50/50. I noticed that the 96 max was the last one that had the 70/30 mixture mentioned in the FSM. In the 97 FSM and up it says to only use 50/50 and other mixture may cause damage.
__________________
1996 5spd w/DE-K/HotShot headers/Apexi WS
JWT Short Ram/VAFC2
KYB AGX/Eibach SportLine/97+ front end...
Quote:
Originally Posted by nismology View Post
You can subscribe to a thread without posting.
DAVE Sz is offline   Reply With Quote
Old 07-24-2004, 10:55 AM   #58
Chassis Freak
VQuick's Avatar
Send a message via ICQ to VQuick Send a message via AIM to VQuick Send a message via MSN to VQuick
Would you need to buy 2 gallons of antifreeze for a 4th gen (8-9 quart capacity)? Seems to me you'd need only one gallon, which is 4 quarts, so you have about 50/50 right there.
I read another thread (FP and LC) which seemed to conclude that taking it to a shop is the best bet. Bill99gxe, is your method as good as a shop which uses a machine to thoroughly flush and pressure test the system? I called around and Meineke will do it for $49.99 but I don't know if they'll take anything off that if I supply a gallon of Toyota Red. I might also put in a half quart of Redline Water Wetter if I can find some locally. So maybe $20 more (than Colonel's $41 estimated cost to do it yourself) for them to do it much faster and possibly more thoroughly than I could.
I am a DIYer but time is money...if this flush takes me all afternoon, I think it's not worth it. Thoughts?
VQuick is offline   Reply With Quote
Old 07-24-2004, 07:21 PM   #59
anybody got picks of toyota red coolant?
the jug pick?
so i can go to any toyota dealer and inquire about the OEM coolant?
thanks
FishyMan is offline   Reply With Quote
Old 07-24-2004, 08:11 PM   #60
Here's a jug pic: http://theoildrop.server101.com/cgi/...;f=37;t=000025
scroll down for the pic.
Old 07-26-2004, 05:25 PM   #61
can some one rank the order of which coolant is best and why? what is the real reason behind using the OEM? so can i just call a dealer and ask them? there isn't any special number, or name for them?
honda-blue, toyota-red, nissan-green
Old 07-26-2004, 06:26 PM   #62
The Definitive AE Master
Larrio's Avatar
tsk tsk.. you should at least try reading the thread first.
your answer is on the first page:
other domestic brands contain: "silicates and phosphates" in their antifreeze
run the OEM stuff because its either free of those or low content. If you asked the dealer for OEM coolant fluid i'm sure they will know what your talking about. If you've been there before, you'll find that you don't need specific part numbers just to order parts.
Larrio is offline   Reply With Quote
Old 07-27-2004, 07:08 PM   #63
Lebanese By Birth
panda_1's Avatar
Send a message via AIM to panda_1
im getting ready to do my flush, first thing where can i get distilled water from? what is so good about the toyota red stuff?
__________________
********OFFICIALLY THE 1ST 5TH GEN WITH NWP ENGINEERING IM SPACERS INSTALLED!!!!********
PR CAI / Exedy Stage 1 / Pacesetter STS / Larrio's Shifter Bushing / Fidanza / Cattman Headers & Exhaust / Custom Enterprise Test Pipe / All ES Bushings / SS Brake and Clutch / S-techs with Illuminas / Blehmco 300zx Brake Upgrade / FSTB / RSTB / RSB / Walbro / Autometer / Emanage Ultimate / Innovative Motorsports LM-1 Wideband / AE VLSD Tranny / Rev-up Oil Pump / Scan Gauge II / Home Depot Catch Can / JB Welded VI / KOYO Rad./ 350Z Thermostat / 19" Forged G35 Rims
211 HP
204 TQ
More Powah Coming Soon!!
panda_1 is offline   Reply With Quote
Old 07-27-2004, 07:17 PM   #64
You can buy distilled H2O at any grocery store that sells bottled water.
Old 07-28-2004, 04:31 AM   #65
Send a message via AIM to NYC TAR
What is so good about the Toyota red stuff?
1) it is Japanese coolant made / design for Japan cars (silicate free) better for the system
2) it cheap only 11- 12 bucks (Nissan / Honda cost about 17-80 a gallon)
3) the Toyota supra swear guys swear by them
4) It gives off a nice reddish -- pink color.
NYC TAR is offline   Reply With Quote
Old 08-01-2004, 09:32 PM   #66
Send a message via AIM to NYC_Maxima97
I flushed my cooling system today, real easy. I used the Toyota red. BTW it wasn't 11.99, those guys charged me $16.99 plus tax. Gotta love the hungry dealers.
I did 50/50 and added a bottle of redline water wetter.
__________________
NYC_Maxima97 is offline   Reply With Quote
Old 08-02-2004, 12:11 PM   #67
Did you flush the cooling system or just the radiator?
Old 08-05-2004, 12:17 PM   #68
Send a message via AIM to RichSpidizzy Send a message via MSN to RichSpidizzy
etc
etc
etc
Thanks for the time and material breakdown Colonel. One question though, what's the antifreeze tester for?
RichSpidizzy is offline   Reply With Quote
Old 08-05-2004, 06:10 PM   #69
Send a message via ICQ to Maxi113 Send a message via AIM to Maxi113 Send a message via MSN to Maxi113 Send a message via Yahoo to Maxi113
I have orange :P
Maxi113 is offline   Reply With Quote
Old 08-05-2004, 06:23 PM   #70
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Heads up if you've got A LOT of mileage.
I followed the hot/cold drain-fill method above on my 150K mile car except I also used a bottle of Prestone radiator flush first. After a few days the radiator started leaking along the endtanks and 4-days later overheated/blew.
I'm not sure if it was the hot/cold cycling of the flushing or that the bottle of Prestone cleaner knocked all the crap that was holding the radiator together loose, but definitely SOMETHING happened as a result. Just a bit of advice incase you're going to get aggressive on an older high mileage vehicle.....find a spare radiator ahead of time.
IceY2K1 is offline   Reply With Quote
Old 08-20-2004, 09:30 AM   #71
ME RWD FTW!
Colonel's Avatar
Quote:
First time I have flushed a radiator this way without pre mixed 50/50. Wanted to make sure (I tested a few times over next couple weeks) that my mixture was good.
Old 08-20-2004, 09:31 AM   #72
ME RWD FTW!
Colonel's Avatar
OH MY!!!! radiator!
Old 08-22-2004, 12:42 PM   #73
Pointy Elbows
00MaxSE's Avatar
Send a message via AIM to 00MaxSE
Well I'm in the process of flushing mine now. I bought the Toyota Red coolant. They charged me $15.99/gallon.
I also just put in the Prestone radiator flush.
Hope the same thing doesn't happen to me, Alex.
I'm waiting for it to cool down before I run all the distilled water through it.
Oh, when I drained all the coolant out of the radiator and overflow tank, I got almost exactly ONE gallon out.
I think I'm gonna premix the coolant 50/50 before I put it in.
J.
00MaxSE is offline   Reply With Quote
Old 10-01-2004, 02:14 PM   #74
Riding the BMW Bandwagon
Send a message via AIM to Mizeree_X Send a message via Yahoo to Mizeree_X
I was going to use the flush as well, but I called my mechanic and he told me that the flush uses a pretty strong acid and it is VERY difficult to completely remove it from the system, and so the remaining acid just sits in your cooling system, slowly eating away at the seals. So I just went the whole distilled water route, though I didn't flush until the drainage was clear, because I have to pay to dispose of the waste (yes, I'm a tree hugger and refused to dump it into a storm drain).
Mizeree_X is offline   Reply With Quote
Old 10-03-2004, 07:05 PM   #75
Chassis Freak
VQuick's Avatar
Old 10-14-2004, 11:29 AM   #76
bill99gxe's Avatar
I fail to see why a flush should be used unless your system was clogged to begin with, which you would know by having sporadic overheating.
The Toyota Red Coolant is recommended because of my personal experience on it with my 99 Maxima. After two years, I flushed it, and it looked the same way it did when I put it in....very little soot/residue had been generated.
Old 10-14-2004, 12:05 PM   #77
IceY2K1's Avatar
I flushed because I figured it would help efficiency by cleaning out years of built up gunk, which could have helped my detonation issue. It didn't and I regretted the impulse buy, however the new radiator seems to make a difference in coolant temps/detonation although NOT indicated by the crude idiot temp gauge.
Old 10-14-2004, 02:21 PM   #78
Send a message via ICQ to Cheezwiz Send a message via AIM to Cheezwiz Send a message via MSN to Cheezwiz Send a message via Yahoo to Cheezwiz
Avoid DexCool.
Cheezwiz is offline   Reply With Quote
Old 10-14-2004, 04:37 PM   #79
where would you go to recycle or process the used antifreeze? would any old gas station take it or do i have to take it to a processing plant?
??? is offline   Reply With Quote
Old 10-15-2004, 04:34 PM   #80
"Nissan Long Life" vs "Nissan Genuine Antifreeze"
Is there a difference between Nissan Long Life Antifreeze and Nissan Genuine Antifreeze?
I have a 2001 Maxima. The manual says to use "Nissan Genuine Antifreeze". I know that the newer manuals say to use Nissan Long Life Antifreeze. Are they the same? It looks like the antifreeze my car came with is red. Is that long life? I plan to do a radiator flush without draining the engine block, so I don't think it is good to mix different kinds of antifreeze.
I went to the dealer and they only sell Nissan Long Life Antifreeze and Shell antifreeze, so I bought the Nissan Long Life.
phirps is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
