Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Can i use automatic transmission fluid to put in my power steering?
Old 12-31-2013, 12:20 PM
Toaster514's Avatar
Hi, i am about to do all the fluids change on my automatic nisssan maxima 2001 and i saw that some people use transmission fluid in their power steering. I was wondering if it would be better to use real power steering fluid? or would the transmission fluid would to the same job? is there one that will last longer? is there one that will work better or is it the same thing?
Toaster514 is offline
Old 12-31-2013, 01:28 PM
ac max 92's Avatar
I believe in your case you can use ATF just make sure you are using the right one. Which would be the same as what your tranny takes. There should be a guide you can look at where you purchase it. Probably dex 3 but if your not sure use a multi vehicle. Mobil 1 is a good one or if you really want a good one to use just for the power steering fluid try the amsoil synthetic power steering fluid which is a multi vehicle application and is great stuff.
ac max 92 is offline
Old 12-31-2013, 01:46 PM
maxima.713's Avatar
I'm using auto tranny fluid in my power steering lol no problems at all. You do not need any special fancy ps fluid either the cheap stuff works just fine.
maxima.713 is offline
Old 12-31-2013, 02:41 PM
Toaster514's Avatar
very nice to know, im very happy hahaha since how long you running like this and how many km does your car have?
Old 12-31-2013, 03:02 PM
Fakie J Farkerton's Avatar
They are the same for Nissan. No worries.
Fakie J Farkerton is offline
Old 12-31-2013, 06:17 PM
Shift_A32B's Avatar
I used Nissan's ATF D-Matic on the transmission and power steering. Never had a problem.
Shift_A32B is offline
Old 12-31-2013, 06:34 PM
chrome91's Avatar
doesnt matter at all, ATF is a exact equivalent substitute for power steering fluid
chrome91 is offline
Old 01-01-2014, 12:16 AM
i8acobra's Avatar
Yes, you can use Dexron III (but not Dexron VI) as p/s fluid.
i8acobra is offline
Old 01-03-2014, 04:34 PM
Toaster514's Avatar
Perfect i'll do it thank you guys!
Old 01-03-2014, 08:47 PM
nsnrider's Avatar
yes you can, even states it in the owners manual. As mentioned before, use the cheap atf and you'll be fine. that is what I have running in my 99 right now.
nsnrider is offline
Old 10-21-2014, 06:08 PM
melonhed161's Avatar
Power steering went out after putting Atf in it.
A mechanic friend of mine put ATF in my power steering because it was leaking and I didn't have time that day to get hose replaced. After about 2 miles I lost all power steering. Please help. I don't know what is going on.
melonhed161 is offline
Old 10-21-2014, 07:47 PM
chrome91's Avatar
ATF had nothing to do with it. either all the fluid leaked out and you lost power steering, the pump is bad, or the serpentine belt broke off
chrome91 is offline
Old 06-13-2021, 02:44 PM
Lou2014's Avatar
Question
I accidentally put 4 oz of antifreeze in my power steering reservoir, I never started the can and siphoned the reservoir, and put the right fluid in. Should I be worried?
Lou2014 is offline
maxinout93
10-27-2015 01:29 PM
Jeffesernia11
08-23-2015 06:09 PM
Mrbizness1
08-18-2015 08:43 PM
scarletsosa
08-17-2015 09:09 PM
cmpowell86
08-10-2015 12:35 AM
Quick Reply: Can i use automatic transmission fluid to put in my power steering?
