Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-14-2007, 07:35 PM   #41
Quote:
Originally Posted by dannodotcom
I have been doing oil changes on my vehicles for 30 years and have never replaced a washer, never had oil leak from the drain plug either. Had my Max (2000 SE) for 7 months now and have done 2 oil changes and have not replaced the washer and there is NO leak. When I do an oil change, I make sure to clean both mating surfaces (plug and pan). If a leak develops there then maybe I'll change my position on changing washe
x2 I only change the crush washer when I see a leak, which is rare.
peace is offline   Reply With Quote
Old 10-31-2007, 06:10 PM   #42
Send a message via AIM to wyche89
Quote:
Originally Posted by dannodotcom View Post
I have been doing oil changes on my vehicles for 30 years and have never replaced a washer, never had oil leak from the drain plug either. Had my Max (2000 SE) for 7 months now and have done 2 oil changes and have not replaced the washer and there is NO leak. When I do an oil change, I make sure to clean both mating surfaces (plug and pan). If a leak develops there then maybe I'll change my position on changing washers.http://forums.maxima.org/newreply.ph...ply&p=2484781#
Dannodotcom
changing the washer isn't a big deal.. i've never had a leak.. change it if you want, but if not... YOUR CAR WILL EXPLODE!! j/k.. nothing will happen.. no bid deal
wyche89 is offline   Reply With Quote
Old 05-08-2008, 04:22 PM   #43
They sold me one but I wasnt sure how to install it so I just used the one that's on the plug already. It's a thick 1/16 copper washer. The one the dealership sold me is a thin, donut with no external side shaped copper washer, that had a notch in it. Really not sure how to install it.
Any of you have a solid copper washer like that?
Kryogen is offline   Reply With Quote
Old 05-08-2008, 04:59 PM   #44
2961cc
VEvolution's Avatar
Send a message via AIM to VEvolution
Yeah they are all the same. It's not hard to figure out how it goes. Common sense works here. Just imagine which side up(crushed) would serve as a better gasket. Which ever you decide will do the trick
__________________
FS: My black 92' VE 5spd
http://forums.maxima.org/maximas-sal...2-ve-5spd.html
VEvolution is offline   Reply With Quote
Old 02-15-2009, 02:24 PM   #45
Thinking about this, could it have to do with vacuum in the engine?
Heres what I mean: Ive noticed on the VQ, if you remove the oil cap, the idle drops, signifying vacuum change.
My 3vz-fe does this very pronounced.
So the question would be, does the gasket have a vacuum seal purpose.
Rob_0126 is offline   Reply With Quote
Old 02-15-2009, 04:23 PM   #46
Rob_0126
I understand what you are saying, but the valve cover where the oil cap is has a slightly negative air pressure due to the PCV valve which is why when you take off the oil cap when the engine is running, the engine will stumble a bit, I think there are sensor(s) that get messed up if you do that too. The oil system, below the heads, has a pressure of about 30-70 PSI, so is kind of separate from the valve cover, even though some oil does get forced into that area. The oil plug on the oil pan on the bottom of the engine must be a tight enough seal to prevent oil from leaking out, it doesn't have to stop air getting in. So, the answer to your question is no.
__________________
Dannodotcom
Winnipeg Canada
My Ride: 2000 Pearl White SE
Ming Paint Protection
Ming Window Tint 50/35 (Legal Max in Manitoba Canada)
dannodotcom is offline   Reply With Quote
Old 02-15-2009, 06:56 PM   #47
Rob_0126
I wasn't sure, just a thought. The camry was the first engine I saw that taking the oil cap off affected the vacuum. Ive worked on chevys mostly.
Does it do permanent damage to sensors if the cap is off for a short time, or does it just trip um?
Old 02-15-2009, 10:47 PM   #48
Nope, won't do any damage to sensors, probably won't even trip them, unless you drive off without the oil cap. Then you would probably see a check engine light within a few minutes, not sure how well the engine would run either.
Old 03-11-2009, 03:37 PM   #49
Send a message via ICQ to NIKV69 Send a message via AIM to NIKV69 Send a message via Yahoo to NIKV69
Quote:
My local dealer Rothrock Nissan charge $2.40 each. That was insane!!!Ya, Bob Moore Nissan here in Norman charged me $1.25 each and I thought that was a bit steep.
Get your parts from nissanpartsonline, great prices and free shipping.
I change my every oil change. Cheap insurance against leaks.
__________________
"Live free or Die"
NIKV69 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
